Home » Language IDEs » C / C++ IDE (CDT) » Intel Mac support status?
Re: Intel Mac support status? [message #176333 is a reply to message #176280] |
Mon, 11 September 2006 11:32 |
Originally posted by: jamesblackburn+ngnospam.gmail.com
I've used it, it works.
Keath Milligan wrote:
> Can anyone comment on the status of Eclipse CDT support for Intel-based
> Macs?
> Thanks
Re: Intel Mac support status? [message #178245 is a reply to message #177350] |
Thu, 12 October 2006 03:45 |
Mike Jackson Messages: 23 Registered: July 2009 |
On 2006-09-26 00:47:11 -0400, Yuen Ho Wong <wyuenho@gmail.com> said:
> I've tried CDT on a Mactel, it doesn't work, and CDT 3.1 doesn't
> support the mac/intel architecture yet as far as I know. You can
> actually see that only the Mac/PPC architecture is supported from their
> download page.
> CDT most certainly can't be 100% Java. CDT can't possibly be able to
> communicate with the native debugger using pure Java.
> Yuen-Ho Wong
>>>>> Can anyone comment on the status of Eclipse CDT support for Intel-based Macs?
>>> Out of curosity I assume Eclipse 3.2 with CDT 3.1?
>>> It should be noted that Eclipse 3.2 is marked as supporting Power
>>> PC/Intel for MacOS X, see:
>>> http://www.eclipse.org/eclipse/development/eclipse_project_p lan_3_2.html#TargetOperatingEnvironments
CDT
>>> is I believe 100% Java.
>>> Andre
>> Thanks, I'm going to be upgrading my PowerBook soon and I recall
>> reading a while back that Intel Mac support wasn't ready yet.
Eclipse 3.2.x is Universal Binary. I was just exploring the CDT
distribution (3.1.1 I believe) and sure enough, the small JNI libs are
both PPC. It was easy enough to find the sources, type "make" in a
terminal in the directory and have i386 jni libs produced.
I changed the Makefile to now create Universal Binaries of the jni
libraries. You will need OS X 10.4.8 and Xcode 2.4 to build them.
# makefile for libspawner.so
# See
http://developer.apple.com/documentation/Java/Conceptual/Jav a141Development/Core_APIs/chapter_6_section_4.html
JAVA_HOME
= /Library/Java/Home
ifeq ($(JAVA_HOME),)
$(warning JAVA_HOME not set in environment)
endif
# Defaults which can be overridden.
OS = macosx
ARCH = Universal
SYS_ROOT=/Developer/SDKs/MacOSX10.4u.sdk
JDK_INCLUDES= $(SYS_ROOT)/System/Library/Frameworks/JavaVM.framework/Heade rs
CC=gcc
LD=libtool
CPPFLAGS = -I. -I$(JDK_INCLUDES)
CFLAGS +=-fPIC -D_REENTRANT -O -g \
-isysroot $(SYS_ROOT) -arch i386 -arch ppc
LDFLAGS=-arch ppc -arch i386 -isysroot $(SYS_ROOT)
INSTALL_DIR = ../os/$(OS)/$(ARCH)
LIB_NAME_SPAWNER = libspawner.dylib
LIB_NAME_FULL_SPAWNER = $(INSTALL_DIR)/libspawner.jnilib
OBJS_SPAWNER=spawner.o io.o exec_unix.o exec_pty.o openpty.o pfind.o
LIB_NAME_PTY = libpty.so
LIB_NAME_FULL_PTY = $(INSTALL_DIR)/libpty.jnilib
OBJS_PTY= openpty.o pty.o ptyio.o
OBJS = $(OBJS_SPAWNER) $(OBJS_PTY)
all: $(LIB_NAME_FULL_SPAWNER) $(LIB_NAME_FULL_PTY)
rebuild: clean all
$(LIB_NAME_FULL_SPAWNER) : $(OBJS_SPAWNER)
mkdir -p $(INSTALL_DIR)
$(CC) -dynamiclib -o $(LIB_NAME_FULL_SPAWNER) $(OBJS_SPAWNER) -lc
-framework JavaVM $(LDFLAGS)
$(LIB_NAME_FULL_PTY): $(OBJS_PTY)
$(CC) -dynamiclib -o $(LIB_NAME_FULL_PTY) $(OBJS_PTY) -lc -framework
JavaVM $(LDFLAGS)
clean :
$(RM) $(OBJS_SPAWNER) $(LIB_NAME_FULL_SPAWNER)
$(RM) $(OBJS_PTY) $(LIB_NAME_FULL_PTY)
Re: Intel Mac support status? [message #178274 is a reply to message #178245] |
Thu, 12 October 2006 08:05 |
Wong Yuen Ho Messages: 11 Registered: July 2009 |
If this is tested and works as it should, maybe you should file a bug
and contribute this change back to the source.
Thanks dude!
Yuen Ho Wong
>> their download page.
>> Yuen-Ho Wong
>>>>>> Intel-based Macs?
> CDT
>>>> Andre
> # See
> JAVA_HOME
> endif
> OS = macosx
> ARCH = Universal
> JDK_INCLUDES=
> CC=gcc
> LD=libtool
> rebuild: clean all
> JavaVM $(LDFLAGS)
> clean :
Re: Intel Mac support status? [message #178314 is a reply to message #178274] |
Thu, 12 October 2006 12:46 |
I tested this on a MacBook Pro and a Powerbook G4 both running OS X
10.4.8 and Xcode 2.4. Both Built a universal Binary library
successfully. However these are the unknowns:
Where do I "install" the jni libraries so that I know they are working
correctly?
Where do I file a bug report? Is that with the Main Eclipse bug tracking site?
Due to the way I built the libs, I may have put a minimal system
requirement of OS X 10.4.x on them.
I Do not know what OS X versions CDT, and for that matter Eclipse
itself, wants to support.
We actually need some others to test this to see if it really does
work. Just because it works on my system doesn't mean it will work
everywhere.
Mike Jackson
> Thanks dude!
> Yuen Ho Wong
>>> download page.
>>> Yuen-Ho Wong
CDT
is
>>>>> Andre
>> # See
JAVA_HOME
>> /Library/Java/Home
>> endif
>> OS = macosx
>> ARCH = Universal
>> CC=gcc
>> LD=libtool
>> rebuild: clean all
>> clean :
Re: Intel Mac support status? [message #178344 is a reply to message #178314] |
Thu, 12 October 2006 16:27 |
Yes you can use the bugzilla on eclipse.org. According to eclipse.org,
Eclipse 3.2 currently only supports OS X 10.4, so I guess that's the
same for CDT. I have idea what to do with the JNI libs, I've never built
them before, if only the CDT Devs will respond... If you file a bug, I'm
sure the CDT team will advise you what to do on Bugzilla, although I'm
fairly certain they'll tell you to run the JUnit test cases that come
with CDT SDK to check for regressions.
Yuen Ho Wong
> correctly?
> site?
> We actually need some others to test this to see if it really does work.
> Just because it works on my system doesn't mean it will work everywhere.
> Thanks
> Mike Jackson
>> Thanks dude!
>> Yuen Ho Wong
>>>> Yuen-Ho Wong
>>>>>>>> Intel-based Macs?
> CDT
> is
>>>>>> Andre
>>> are both PPC. It was easy enough to find the sources, type "make" in
>>> a terminal in the directory and have i386 jni libs produced.
>>> # See
> JAVA_HOME
>>> /Library/Java/Home
>>> endif
>>> OS = macosx
>>> ARCH = Universal
>>> JDK_INCLUDES=
>>> CC=gcc
>>> LD=libtool
>>> rebuild: clean all
>>> clean :
Re: Intel Mac support status? [message #178374 is a reply to message #178344] |
Fri, 13 October 2006 04:02 |
Bug number 160799
has been filed...
Mike Jackson
> built them before, if only the CDT Devs will respond... If you file a
> bug, I'm sure the CDT team will advise you what to do on Bugzilla,
> although I'm fairly certain they'll tell you to run the JUnit test
> cases that come with CDT SDK to check for regressions.
> Yuen Ho Wong
>> correctly?
>> everywhere.
>> Thanks
>> Mike Jackson
>>> Thanks dude!
>>> Yuen Ho Wong
>>>>> download page.
>>>>> Yuen-Ho Wong
CDT
is
I
>>>>>>> believe 100% Java.
>>>>>>> Andre
>>>> # See
JAVA_HOME
/Library/Java/Home
ifeq
>>>> ($(JAVA_HOME),)
>>>> endif
>>>> OS = macosx
>>>> ARCH = Universal
>>>> CC=gcc
>>>> LD=libtool
>>>> rebuild: clean all
>>>> clean :
Current Time: Fri Apr 19 14:37:56 GMT 2024
Powered by FUDForum. Page generated in 0.02422 seconds
