RSE: Create Remote Project [message #16647] |
Mon, 10 December 2007 14:54 |
Originally posted by: tatsudoshi.criion.net
If I right-click a folder on my server in RSE and 'Create Remote
Project', it shows up in my PhP Explorer. If I then try to open a file I
get a java.lang.NullPointerException.
Any suggestions?
I am using JDK6u3 and Eclipse PDT all-in-one 1.0-R20070917
--- Error log ---
at
org.eclipse.wst.sse.core.internal.FileBufferModelManager.cre ateURIResolver(FileBufferModelManager.java:419)
at
org.eclipse.wst.sse.core.internal.FileBufferModelManager.get Model(FileBufferModelManager.java:656)
at
org.eclipse.wst.sse.core.internal.model.ModelManagerImpl._ge tModelFor(ModelManagerImpl.java:393)
at
org.eclipse.wst.sse.core.internal.model.ModelManagerImpl.get ModelForEdit(ModelManagerImpl.java:1020)
at
org.eclipse.wst.sse.ui.StructuredTextEditor.doSetInput(Struc turedTextEditor.java:2113)
at
org.eclipse.php.internal.ui.editor.PHPStructuredEditor.doSet Input(Unknown
Source)
at
org.eclipse.ui.texteditor.AbstractTextEditor$19.run(Abstract TextEditor.java:2994)
at
org.eclipse.jface.operation.ModalContext.runInCurrentThread( ModalContext.java:369)
at org.eclipse.jface.operation.ModalContext.run(ModalContext.ja va:313)
at
org.eclipse.jface.window.ApplicationWindow$1.run(Application Window.java:758)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:67)
at
org.eclipse.jface.window.ApplicationWindow.run(ApplicationWi ndow.java:755)
at org.eclipse.ui.internal.WorkbenchWindow.run(WorkbenchWindow. java:2451)
at
org.eclipse.ui.texteditor.AbstractTextEditor.internalInit(Ab stractTextEditor.java:3012)
at
org.eclipse.ui.texteditor.AbstractTextEditor.init(AbstractTe xtEditor.java:3039)
at
org.eclipse.wst.sse.ui.StructuredTextEditor.init(StructuredT extEditor.java:2615)
at org.eclipse.php.internal.ui.editor.PHPStructuredEditor.init( Unknown
Source)
at org.eclipse.ui.internal.EditorManager.createSite(EditorManag er.java:794)
at
org.eclipse.ui.internal.EditorReference.createPartHelper(Edi torReference.java:643)
at
org.eclipse.ui.internal.EditorReference.createPart(EditorRef erence.java:426)
at
org.eclipse.ui.internal.WorkbenchPartReference.getPart(Workb enchPartReference.java:592)
at org.eclipse.ui.internal.PartPane.setVisible(PartPane.java:29 9)
at
org.eclipse.ui.internal.presentations.PresentablePart.setVis ible(PresentablePart.java:179)
at
org.eclipse.ui.internal.presentations.util.PresentablePartFo lder.select(PresentablePartFolder.java:268)
at
org.eclipse.ui.internal.presentations.util.LeftToRightTabOrd er.select(LeftToRightTabOrder.java:65)
at
org.eclipse.ui.internal.presentations.util.TabbedStackPresen tation.selectPart(TabbedStackPresentation.java:400)
at
org.eclipse.ui.internal.PartStack.refreshPresentationSelecti on(PartStack.java:1256)
at org.eclipse.ui.internal.PartStack.setSelection(PartStack.jav a:1209)
at org.eclipse.ui.internal.PartStack.showPart(PartStack.java:16 04)
at org.eclipse.ui.internal.PartStack.add(PartStack.java:499)
at org.eclipse.ui.internal.EditorStack.add(EditorStack.java:103 )
at org.eclipse.ui.internal.PartStack.add(PartStack.java:485)
at org.eclipse.ui.internal.EditorStack.add(EditorStack.java:112 )
at
org.eclipse.ui.internal.EditorSashContainer.addEditor(Editor SashContainer.java:63)
at
org.eclipse.ui.internal.EditorAreaHelper.addToLayout(EditorA reaHelper.java:217)
at
org.eclipse.ui.internal.EditorAreaHelper.addEditor(EditorAre aHelper.java:207)
at
org.eclipse.ui.internal.EditorManager.createEditorTab(Editor Manager.java:774)
at
org.eclipse.ui.internal.EditorManager.openEditorFromDescript or(EditorManager.java:673)
at org.eclipse.ui.internal.EditorManager.openEditor(EditorManag er.java:634)
at
org.eclipse.ui.internal.WorkbenchPage.busyOpenEditorBatched( WorkbenchPage.java:2719)
at
org.eclipse.ui.internal.WorkbenchPage.busyOpenEditor(Workben chPage.java:2633)
at org.eclipse.ui.internal.WorkbenchPage.access$12(WorkbenchPag e.java:2625)
at org.eclipse.ui.internal.WorkbenchPage$10.run(WorkbenchPage.j ava:2577)
at
org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:2572)
at
org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:2556)
at
org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:2547)
at org.eclipse.ui.ide.IDE.openEditor(IDE.java:644)
at org.eclipse.ui.ide.IDE.openEditor(IDE.java:603)
at org.eclipse.php.internal.ui.util.EditorUtility.openInEditor( Unknown
Source)
Source)
at org.eclipse.php.internal.ui.actions.OpenActionUtil.open(Unkn own Source)
at org.eclipse.php.internal.ui.actions.OpenAction.run(Unknown Source)
at
org.eclipse.php.internal.ui.actions.SelectionDispatchAction. dispatchRun(Unknown
Source)
at
org.eclipse.php.internal.ui.actions.SelectionDispatchAction. run(Unknown
Source)
at
org.eclipse.php.internal.ui.explorer.ExplorerActionGroup.han dleOpen(Unknown
Source)
at org.eclipse.php.internal.ui.explorer.ExplorerPart$5.open(Unk nown Source)
at
org.eclipse.jface.viewers.StructuredViewer$2.run(StructuredV iewer.java:820)
at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:37)
at org.eclipse.core.runtime.Platform.run(Platform.java:857)
at org.eclipse.ui.internal.JFaceUtil$1.run(JFaceUtil.java:46)
at org.eclipse.jface.util.SafeRunnable.run(SafeRunnable.java:19 3)
at
org.eclipse.jface.viewers.StructuredViewer.fireOpen(Structur edViewer.java:818)
at
org.eclipse.jface.viewers.StructuredViewer.handleOpen(Struct uredViewer.java:1079)
at
org.eclipse.jface.viewers.StructuredViewer$6.handleOpen(Stru cturedViewer.java:1183)
at org.eclipse.jface.util.OpenStrategy.fireOpenEvent(OpenStrate gy.java:263)
at org.eclipse.jface.util.OpenStrategy.access$2(OpenStrategy.ja va:257)
at org.eclipse.jface.util.OpenStrategy$1.handleEvent(OpenStrate gy.java:297)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :66)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:938)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3682)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3293)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2389)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2353)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:22 19)
at org.eclipse.ui.internal.Workbench$4.run(Workbench.java:466)
at
org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:289)
at
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:461)
at
org.eclipse.ui.internal.ide.application.IDEApplication.start (IDEApplication.java:106)
at
org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:153)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:106)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:76)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:363)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:176)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 504)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:443)
at org.eclipse.equinox.launcher.Main.run(Main.java:1169)
FUDForum. Page generated in 0.03024 seconds
