Home » Eclipse Projects » EclipseLink » [Solved] Eclipselink 2.5 + MSSQL (jtds) escaping table names
[Solved] Eclipselink 2.5 + MSSQL (jtds) escaping table names [message #1140383] Wed, 16 October 2013 10:13 Go to next message
Neikius Mising name is currently offline Neikius Mising nameFriend
Member
I've noticed that Eclipselink automatically escapes table names in MSSQL also. BUT it will escape the table names in double quotes.
As far as I know this is the source of my problem : [dbo].[table name] should work, while "[dbo]"."[table name]" does not.
It could be something else, but I want to try this first. How would I turn off automatic escaping in double quotes? Actually, even better would be if it escaped names using [] instead of double quotes no? When user sets property <property name="eclipselink.target-database" value="SQLServer"/> for example?
[Updated on: Wed, 06 November 2013 12:09]
Report message to a moderator
Re: Eclipselink 2.5 + MSSQL (jtds) escaping table names [message #1142212 is a reply to message #1140383] Thu, 17 October 2013 13:19 Go to previous messageGo to next message
Chris Delahunt is currently offline Chris DelahuntFriend
It should not escape table names by default, so check your settings - specifically for a delimited-identifiers tag in an orm.xml file, or that the table name definitions do not include '/"' escapes. The " delimiter is the default on DatabasePlatform, and can be changed using the setStartDelimiter and setEndDelimiter methods via a session customizer http://wiki.eclipse.org/EclipseLink/UserGuide/JPA/Advanced_JPA_Development/Customizers
Re: Eclipselink 2.5 + MSSQL (jtds) escaping table names [message #1142213 is a reply to message #1140383] Thu, 17 October 2013 13:20 Go to previous messageGo to next message
[Updated on: Thu, 17 October 2013 14:47]
Re: Eclipselink 2.5 + MSSQL (jtds) escaping table names [message #1142214 is a reply to message #1140383] Thu, 17 October 2013 13:20 Go to previous messageGo to next message
Re: Eclipselink 2.5 + MSSQL (jtds) escaping table names [message #1173277 is a reply to message #1140383] Wed, 06 November 2013 12:09 Go to previous message
Member
Not sure why I had to do this, having specified MSSQL as my platform... at least it works fine now. Had to dig a bit more though but thanks for the correct pointers Smile
public class DatabaseCustomizer implements SessionCustomizer {
	public void customize(Session session) {
		DatasourcePlatform platform = session.getPlatform();
		platform.setStartDelimiter("[");
		platform.setEndDelimiter("]");
And persistence.xml
<persistence-unit>
   <persistence>
      <properties>
         <property name="eclipselink.session.customizer" value="si.result.internal.ure.service.data.customizer.DatabaseCustomizer"/>
      </properties>
   </persistence-unit>
</persistence>
Previous Topic:Asking for advise (Failover question)
Next Topic:Retrieve object and dependencies with only one SQL request
Current Time: Thu Feb 06 14:17:51 GMT 2025
Powered by FUDForum. Page generated in 0.03515 seconds
