Re: Cant find source file [message #1717377 is a reply to message #1717112] |
Sat, 12 December 2015 11:51 |
David Vavra Messages: 1426 Registered: October 2012 |
Don't know about auto continuing but for inadvertently stepping into a library routine you can use the finish command to run until the current routine finishes, that is, returns. The eclipse debugger view shows this as a bent up-arrow.
In this case the program stopped within a library routine with a segment fault. You don't want to continue running.
Instead you should walk back through the stack trace if you want to see how the program got there.
I find this far more informative. An "only-show-my-code" switch is just laziness IMO. When stepping through the code you should simply step over things not yours. When the program halts unexpectedly, I personally want to exactly where. Even it I don't want to know, it's quite easy to find where things went wrong in my own code.
Every option comes with a cost: code bloat, extra testing requirements, and yet another way things can go wrong. Eclipse is a fine example of what you get when you try to accommodate everybody: a gazillion options that sometimes result in bizarre interactions. Just read the posts here to see how many steps, and how much understanding, is needed because of all the options.
FUDForum. Page generated in 0.02453 seconds
