Re: RCP Application is NOT recognized with 2.0.1 [message #1143595 is a reply to message #1143392] |
Fri, 18 October 2013 09:43 |
Bhupendra Mahajan Messages: 33 Registered: September 2013 |
Member |
Hi Alex,
Tried with 7.2, still facing the same issue "Jubula is unable to recognize the RCP client"
When ran with autrun.exe got the same error
AUT:org.osgi.framework.BundleException: The bundle "org.eclipse.jubula.rc.rcp.e4_2.2.0.201310100933 [491]" could not be resolved. Reason: Missing Constraint
: Require-Bundle: org.eclipse.e4.ui.workbench; bundle-version="[0.10.2,2.0.0)"
AUT: at org.eclipse.osgi.framework.internal.core.AbstractBundle.getResolverError(AbstractBundle.java:1332)
AUT: at org.eclipse.osgi.framework.internal.core.AbstractBundle.getResolutionFailureException(AbstractBundle.java:1316)
AUT: at org.eclipse.osgi.framework.internal.core.BundleHost.startWorker(BundleHost.java:323)
AUT: at org.eclipse.osgi.framework.internal.core.AbstractBundle.start(AbstractBundle.java:300)
AUT: at org.eclipse.osgi.framework.internal.core.AbstractBundle.start(AbstractBundle.java:292)
AUT: at org.eclipse.jubula.rc.rcp.installer.BundleInstaller.startBundles(BundleInstaller.java:178)
AUT: at org.eclipse.jubula.rc.rcp.installer.BundleInstaller.start(BundleInstaller.java:64)
AUT: at org.eclipse.osgi.framework.internal.core.BundleContextImpl$1.run(BundleContextImpl.java:711)
AUT: at java.security.AccessController.doPrivileged(Native Method)
AUT: at org.eclipse.osgi.framework.internal.core.BundleContextImpl.startActivator(BundleContextImpl.java:702)
AUT: at org.eclipse.osgi.framework.internal.core.BundleContextImpl.start(BundleContextImpl.java:683)
AUT: at org.eclipse.osgi.framework.internal.core.BundleHost.startWorker(BundleHost.java:381)
AUT: at org.eclipse.osgi.framework.internal.core.AbstractBundle.resume(AbstractBundle.java:390)
AUT: at org.eclipse.osgi.framework.internal.core.Framework.resumeBundle(Framework.java:1176)
AUT: at org.eclipse.osgi.framework.internal.core.StartLevelManager.resumeBundles(StartLevelManager.java:559)
AUT: at org.eclipse.osgi.framework.internal.core.StartLevelManager.resumeBundles(StartLevelManager.java:544)
AUT: at org.eclipse.osgi.framework.internal.core.StartLevelManager.incFWSL(StartLevelManager.java:457)
AUT: at org.eclipse.osgi.framework.internal.core.StartLevelManager.doSetStartLevel(StartLevelManager.java:243)
AUT: at org.eclipse.osgi.framework.internal.core.StartLevelManager.dispatchEvent(StartLevelManager.java:438)
AUT: at org.eclipse.osgi.framework.internal.core.StartLevelManager.dispatchEvent(StartLevelManager.java:1)
AUT: at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230)
AUT: at org.eclipse.osgi.framework.eventmgr.EventManager$EventThread.run(EventManager.java:340)
AUT:2489 15:10:05.228 [Start Level Event Dispatcher] WARN ***.*****.services.client.http.HTTPServiceClient - This client application does not support
server feature '****.*****.messaging.orchestration.api.services.IRouteDeploymentService'; please update your client application.
Is there any other Jar needs to be copied over the plugins of the RCP client than "org.eclipse.jubula.rc.rcp_2.2.0.201310100933.jar"
Appreciate, if you could help further
Bhupendra
[Updated on: Fri, 18 October 2013 09:45] Report message to a moderator
FUDForum. Page generated in 0.03203 seconds
