Home » Modeling » TMF (Xtext) » Terminal (Terminal Overlapping )
Terminal [message #1138802] Tue, 15 October 2013 10:38 Go to next message
Vishal seth is currently offline Vishal sethFriend
Member
While creating a rule, I am facing issue related to overlapping of terminals. In grammar below I am trying to input Reference one1.111GGG.two.three but it fails as the terminal conflicts with whole number terminal being a '.' in between.
It can however be resolved by either creating the Greeting name as a terminal rule or by changing NUM & TOKEN_STARTING_WITH_NUMBER to a non terminal rule. But converting from non terminal rule to a data type rule would have performance impact.
What should be the ideal ways to handle such use cases?
Model:
'Reference' hello=GreetingName
GreetingName:
ID '.' TOKEN_STARTING_WITH_NUMBER '.' ID '.' ID;
terminal ID:
'^'? ('a'..'z' | 'A'..'Z' | '_') ('a'..'z' | 'A'..'Z' | '_' | '0'..'9' | '-' | '+')*;
terminal NUM:
('0'..'9')* ('.' ('0'..'9')+)?
terminal TOKEN_STARTING_WITH_NUMBER:
('0'..'9')* ID;
terminal INT returns ecore::EInt:
"not to be used";
Attaching xtext file for various scenarios along with junit test case.
Vishal
Re: Terminal [message #1139065 is a reply to message #1138802] Tue, 15 October 2013 14:06 Go to previous messageGo to next message
Christian Dietrich is currently offline Christian DietrichFriend
why dont you use a datatype rule aka
INT? ID;
Need professional support for Xtext, Xpand, EMF?
Go to: https://www.itemis.com/en/it-services/methods-and-tools/xtext
Twitter : @chrdietrich
Re: Terminal [message #1139928 is a reply to message #1139065] Wed, 16 October 2013 03:29 Go to previous messageGo to next message
Member
That's what I have done in MyDsl_datatyperule_working.xtext. My concerns for this is having a performance impact & secondly there are some other number related terminal rules, which again I have to convert into a datatype rule.
Just wanted to know what should have been the better way of handling such cases, i.e. one mentioned in MyDsl_terminal_working.xtext/ MyDsl_datatyperule_working.xtext or any other better way.
Vishal
Re: Terminal [message #1140040 is a reply to message #1139928] Wed, 16 October 2013 05:12 Go to previous message
It is the property way to do (besides avoiding the use case)
Need training, onsite consulting or any other kind of help for Xtext?
Go visit http://xtext.itemis.com or send a mail to xtext at itemis dot de
Previous Topic:problem with xtext and antlr
Next Topic:Formatting configuration
Current Time: Sun Jan 17 01:31:06 GMT 2021
Powered by FUDForum. Page generated in 0.01698 seconds
