REPOST - BendPoint Connection - What all to do? [message #175123] |
Sat, 02 April 2005 22:12 |
Originally posted by: binti.ksu.edu
Hi All,
Can anyone tell me the steps to create a bendpoint connection from polyline
connection. And what commands and policies to code to create and delete
these bend points. I have a working polyline connection. Can it be converted
to bend point connection?
Binti.
Re: REPOST - BendPoint Connection - What all to do? [message #175231 is a reply to message #175201] |
Mon, 04 April 2005 04:02 |
Problem statement was as simplistic and clear as possible. It can easily be
interpreted as "How to create a bend point connection?"
Its not me that is thoroghly confused, its the example that is confusing and
lack of documentation makes it even more confusing. I have looked at the
WireEditPart in the logic example and also looked at Schema Editor and how
two are different in their architecture. Even the Red Book doesn't explain
how to do it.
I have implemented WireEditPart in my code but that requires changing the
current architecture of my application.
You have been very helpful in the past and I would really appreciate if you
could point me to a simpler example like Shapes example.
Thank You,
Binti
"Pratik Shah" <ppshah@us.ibm.com> wrote in message
news:d2qb1p$nkt$1@news.eclipse.org...
> Reposting the same thing doesn't help. If you don't get an answer it's
> most
> likely because you've not stated the problem clearly or are thoroughly
> confused, or have not done your due diligence before posting.
> Have you looked at any of our examples that have connections with
> bendpoints? Look at WireEditPart in the logic example.
> "Binti Sepaha" <binti@ksu.edu> wrote in message
> news:d2n5i4$7uh$1@news.eclipse.org...
>> Hi All,
> polyline
> converted
>> Regards,
>> Binti.
Re: REPOST - BendPoint Connection - What all to do? [message #175319 is a reply to message #175123] |
Mon, 04 April 2005 14:24 |
PolylineConnection already supports bendpoints, so to create one just do:
new PolylineConnection();
Commands are specific to your model so it's impossible to say what code you
need to write there. Subclass BendpointEditPolicy, and look the compile
errors for the commands that you need to provide.
> Hi All,
> polyline
> converted
> Binti.
FUDForum. Page generated in 0.04371 seconds
