Problems while saving/closing an editor [message #175098] |
Sat, 02 April 2005 12:40 |
Originally posted by: tuhlmann.gmx.de
in my model I have properties that can be changed through the Eclipse
Property view. If a propertiy is changed it fire an event so the edit
part can refresh. This works fine.
When I save the editor that also works without problems. The asterisk in
the editor label disappears.
When I then try and close the editor the asterisk suddenly reappears and
the editor ask if I want to save changes.
This beaviour seems to only occur when I change properties. When I move
a figure, resize it or edit connections everything works fine.
Do you have an idea where I can look for the problem. I'm sure it's my
mistake and I simply forgot to inform some mechanism...
thanks for your help,
Torsten.
Re: Problems while saving/closing an editor [message #175247 is a reply to message #175215] |
Mon, 04 April 2005 06:40 |
The code there looks as follow:
public void commandStackChanged(EventObject event)
super.commandStackChanged(event);
setDirty(getCommandStack().isDirty());
public void setDirty(boolean dirty)
if (isDirty != dirty)
isDirty = dirty;
firePropertyChange(IEditorPart.PROP_DIRTY);
public boolean isDirty()
return isDirty || getCommandStack().isDirty();
Is this ok? What else do I need to watch out for?
Torsten.
Pratik Shah wrote:
> What does your editor's isDirty() method do? In commandStackChanged(), I
> take it you're firing IEditorPart.PROP_DIRTY.
> "Torsten Uhlmann" <tuhlmann@gmx.de> wrote in message
> news:d2m40a$694$1@news.eclipse.org...
>>Hi,
>>Torsten.
Re: Problems while saving/closing an editor [message #175577 is a reply to message #175473] |
Tue, 05 April 2005 09:26 |
Sorry, that doesn't help. But I found out a bit more. It has to do with
which object is selected:
Say I only display one of my elements (compound figure with one label
and an image). I change the font of the label (the editor is marked as
dirty), then WHILE THE FIGURE IS STILL SELECTED I save the editor
(asterisk disappears). When I then click in the background (selecting
the content editpart) the asterisk reappears and the editor is again
marked as dirty.
When I repeat the same scenario with the exception that after changing
the font a select the content editpart and THEN SAVE the editor, I can
close the editor or do what I want, the asterisk will not reappear.
This behaviours only occurs with two of the complex figures, it does not
occur with a simple image (ImageFigure) or the StickyNote figure.
I have verified that the changes get persisted after the first save
operation, so the second must be triggered by some subsequent event. I
just don't know where it could come from.
I hope you got an idea, mine are gone :)
Torsten.
Pratik Shah wrote:
> Try doing what ShapesEditor and EDiagramEditor do:
> public void commandStackChanged(EventObject event) {
> public boolean isDirty() {
> return getCommandStack().isDirty();
> BTW, with the latest code, you don't need to override the isDirty() method
> (GraphicalEditor does that).
> news:d2qnmb$4gr$1@news.eclipse.org...
>> isDirty = dirty;
>>Torsten.
> I
>>>>Hi,
>>>>Torsten.
Re: Problems while saving/closing an editor [message #175639 is a reply to message #175577] |
Tue, 05 April 2005 17:38 |
Pratik Shah Messages: 1077 Registered: July 2009 |
After you've selected the first figure, and changed the font, and saved the
diagram, set a breakpoint in setDirty(). Then click on the background in
the editor. Selection change should not cause a command to be executed or
the diagram to become dirty.
news:d2tlqc$c3b$1@news.eclipse.org...
> marked as dirty.
> Torsten.
method
> >> isDirty = dirty;
> >>Torsten.
> > I
> >>>>Hi,
in
and
move
> >>>>Torsten.
FUDForum. Page generated in 0.03870 seconds
