Re: why build/classes and not WEB-INF/classes? [message #174653 is a reply to message #174499] |
Mon, 17 July 2006 13:29 |
Larry Isaacs Messages: 1354 Registered: July 2009 |
The only version I'm aware of that did something with a
<workspace>/<projectName>/<secretFolder> was WTP 0.7. It built an image
of the webapp under a ".deployables" directory. WTP 0.7 also tried to
support multiple modules per project. Neither of these features
survived to WTP 1.0, as both proved unworkable. Can you be more
specific about the "<secretFolder>" you are referring to?
I can confirm that in WTP 1.0.x and 1.5, the build/classes contents are
copied to the target "WEB-INF/classes" as part of publishing.
Graeme Harker wrote:
> Larry Isaacs wrote:
>> I'm not sure how difficult it would be to keep the built class files
>> out of your CVS if they were being generated under the web content
>> folder of your web project. By putting them in a normal Java build
>> folder, they will stay out of your CVS automatically. WTP copies the
>> build folder contents to WEB-INF/classes when the web application is
>> assembled for publishing to a server or is exported.
>> If you want, you can "override" this behavior by creating a new Java
>> source folder and check the "Allow output folders for source folders"
>> checkbox. For the new source folder, specify its output folder to be
>> "<webcontent>\WEB-INF\classes". Since this new source folder isn't
>> listed in the ".component" file, WTP won't try to copy its contents to
>> WEB-INF/classes for you. I have done something somewhat similar to
>> this to put a Java applet in the content portion of a web application,
>> so I think it should work.
>> Cheers,
>> Larry
>>> Is there a good reason that the default Java build target in WTP for
>>> a Dynamic Web Project is build/classes? It would seem to make much
>>> more sense if default was WEB-INF/classes as this is where the
>>> container expects to find the servlet implementations?
> Thanks for your reply. That explains a lot. Tell me, does what WTP does
> at "Run at Server"-time (i.e. when it copies the target files to
> <workspace>/<projectName>/<secretFolder>) constitute "publishing to a
> server" i.e. does it also copy the contents of build/classes to
> WEB-INF/classes?
Re: why build/classes and not WEB-INF/classes? [message #174898 is a reply to message #174653] |
Wed, 19 July 2006 12:43 |
Graeme Harker Messages: 12 Registered: July 2009 |
<workspace>/.metadta/.plugins/org.eclipse.wst.server.core/tmp
I used the adjective "secret" since (unless I'm reading the wrong
documentation) it's not mentioned in the documentation for WTP.
WTP is a very nice piece of technology and I'm a fan already but the
learning curve for new users would be shorter if the black-box bits were
more transparent so people could figure out what was going on.
>>> "<webcontent>WEB-INFclasses". Since this new source folder isn't
>>> Cheers,
>>> Larry
>> WEB-INF/classes?When I said "secret folder" I meant ...
FUDForum. Page generated in 0.02418 seconds
