Home » Eclipse Projects » JFace » CellModifier in TreeViewer in Dialog class
CellModifier in TreeViewer in Dialog class [message #16479] |
Wed, 24 June 2009 19:49 |
I have a TreeViewer in a class that implements a JFace Dialog. When I set
a CellModifier for this viewer, it does not work. The method canModify
doesn't ever get called. When I use same code in a class that DOES NOT
implement a Dialog, everything works fine. What gives???
Re: CellModifier in TreeViewer in Dialog class [message #16515 is a reply to message #16497] |
Wed, 24 June 2009 20:02 |
Yes, here is the brief snippet of how that code looks:
try{
viewerBills = new TableViewer(tableBills);
viewerBills.setUseHashlookup(true);
viewerBills.setColumnProperties(COLUMNNAMESBILLS);
// Create the cell editors
CellEditor[] editors = new CellEditor[COLUMNNAMESBILLS.length];
for(int i=0;i<editors.length;i++){
TextCellEditor textEditor = new TextCellEditor(tableBills);
// quantity (Text with digits only)
((Text) textEditor.getControl()).addVerifyListener(
new VerifyListener() {
public void verifyText(VerifyEvent e) {
// Here, we could use a RegExp such as the following
// if using JRE1.4 such as e.doit = e.text.matches("[\\-0-9]*");
e.doit = "0123456789".indexOf(e.text) >= 0 ;
editors[i] = textEditor;
viewerBills.setCellEditors(editors);
// Set the cell modifier for the viewer
viewerBills.setCellModifier(new CellBillModifier(this));
catch(Exception e){
System.out.println(e.getMessage());
Re: CellModifier in TreeViewer in Dialog class [message #16552 is a reply to message #16532] |
Wed, 24 June 2009 20:05 |
Here is the entire class:
public class ApproveDialog extends Dialog {
private File file = new File("util/Login_Accounts.txt");
private Text passwordField;
private Text balanceText;
private Label amount;
private Label currencyBills;
private Label currencyCoins;
private String[] displayApprovalError = new String[3];
public boolean approvalSuccessful;
public String approvalAmount;
private String feature = null;
GridData gridData;
TableViewer viewerBills;
TableViewer viewerCoins;
Table tableBills;
Table tableCoins;
TableViewerColumn column;
Color white = Display.getCurrent().getSystemColor(SWT.COLOR_WHITE);
final static String[] COLUMNNAMESBILLS = { "£100 (Scottish)", "£50",
"£20", "£10", "£5"};
final static String[] COLUMNNAMESCOINS = { "£2", "£1", "50p", "20p",
"10p", "5p", "2p", "1p" };
// Create a CoinList and assign it to an instance variable
private static CurrencyBillList CURRENCYBILLSLIST = new
CurrencyBillList();
private static CurrencyCoinList CURRENCYCOINLIST = new
CurrencyCoinList();
// Below we create a formatter with a pattern of #0.00. The # symbol
// means any number but leading zero will not be displayed. The 0
// symbol will display the remaining digit and will display as zero if no
digit is available.
NumberFormat formatter = new DecimalFormat("0.00");
private static String BALANCETYPE;
//enum for setting approval feature
private enum Approval{
discount,openingBalance,closingBalance,NOVALUE;
public static Approval TOAPPROVAL(String str)
try {
return valueOf(str);
catch (Exception ex) {
return NOVALUE;
public ApproveDialog(Shell parentShell, String feature){
super(parentShell);
this.feature = feature;
protected void configureShell(Shell shell) {
super.configureShell(shell);
switch (Approval.TOAPPROVAL(feature)){
case discount: shell.setText("DISCOUNT APPROVAL");
break;
case openingBalance: shell.setText("SET OPENING BALANCE");
break;
case closingBalance: shell.setText("SET CLOSING BALANCE");
break;
* Creates and returns the upper contents of this dialog's area.
* @see
org.eclipse.jface.dialogs.Dialog#createDialogArea(org.eclips e.swt.widgets.Composite)
protected Control createDialogArea(Composite parent){
Composite comp = (Composite)super.createDialogArea(parent);
GridLayout layout = (GridLayout)comp.getLayout();
layout.numColumns=2;
GridData data = new GridData(SWT.BEGINNING,SWT.TOP,false,false);
//data.horizontalSpan=2;
//if approving an opening balance display the text field and tableviewer
for opening bal
if(feature.equals("openingBalance")){
amount = new Label(comp,SWT.NONE);
amount.setText("Amount: £");
amount.setLayoutData(data);
amount.setVisible(true);
data = new GridData(50,15);
balanceText = new Text(comp,SWT.SINGLE);
balanceText.setLayoutData(data);
balanceText.setVisible(true);
balanceText.setText("");
createTableBills(comp);
createTableViewerBills("opening",comp);
createTableCoins(comp);
createTableViewerCoins("opening",comp);
viewerBills.setContentProvider(new CurrencyBillContentProvider());
viewerBills.setLabelProvider(new CurrencyOpeningBillLabelProvider());
viewerCoins.setContentProvider(new CurrencyCoinContentProvider());
viewerCoins.setLabelProvider(new CurrencyOpeningCoinLabelProvider());
// The input for the table viewer is the instance of ExampleTaskList
CURRENCYCOINLIST = new CurrencyCoinList();
viewerCoins.setInput(CURRENCYCOINLIST);
CURRENCYBILLSLIST = new CurrencyBillList();
viewerBills.setInput(CURRENCYBILLSLIST);
//if approving a closing balance display the text field and tableviewer
closing bal
else if(feature.equals("closingBalance")){
createTableViewerBills("closing",comp);
createTableViewerCoins("closing",comp);
viewerBills.setLabelProvider(new CurrencyClosingBillLabelProvider());
viewerCoins.setLabelProvider(new CurrencyClosingCoinLabelProvider());
else{ //otherwise make balanceText invisible
//balanceText.setLayoutData(data);
balanceText.setVisible(false);
amount.setVisible(false);
//currencyCoins.setVisible(false);
//currencyBills.setVisible(false);
data= new GridData(130,15);
Label passwordLabel = new Label(comp,SWT.NONE);
passwordLabel.setText("Manager Password: ");
passwordLabel.setLayoutData(data);
data.horizontalAlignment = 2;
passwordField = new Text(comp,SWT.SINGLE|SWT.PASSWORD);
passwordField.setLayoutData(data);
return comp;
* Adds buttons to this dialog's button bar.
* @see
org.eclipse.jface.dialogs.Dialog#createButtonsForButtonBar(o rg.eclipse.swt.widgets.Composite)
protected void createButtonsForButtonBar(Composite parent){
super.createButtonsForButtonBar(parent);
//createButton(parent,RESET_ID,"Reset All", false);
* Notifies that this dialog's button with the given id has been pressed.
* @see org.eclipse.jface.dialogs.Dialog#buttonPressed(int)
protected void buttonPressed(int buttonId)
if(buttonId == 1){ //cancel was pressed, close the dialog
this.cancelPressed();
else
{ //check for valid manager password discount
try {
Scanner scanner = new Scanner(file);
try {
//first use a Scanner to get each line
while ( scanner.hasNextLine() ){
if(processApproval( scanner.nextLine() )){
//ready to apply discount
approvalSuccessful = true;
break;
if(displayApprovalError[0].equals("show")){
MessageDialog.openError(getParentShell(), "Error",
displayApprovalError[1]+" password incorrect.");
if(displayApprovalError[0].equals("show")&&displayApprovalError[2].equals( "format")){
displayApprovalError[1]+" balance incorrect, " +
"must be in the format xx.xx");
catch(Exception e){
System.out.println("exception: " + e.getMessage());
finally {
//ensure the underlying stream is always closed
scanner.close();
//closes this dialog
if(approvalSuccessful){
super.okPressed();
} catch (FileNotFoundException e) {
System.err.println("file not found");
// log error message that file was not found
//logger.log("login.txt not found");
* This method checks approvals.txt for valid manager password.
* @param next line of the file
* @return approvalResult <b>true</b> if password was correct, false
otherwise
private boolean processApproval(String aLine){
boolean approvalResult = false;
//use a second Scanner to parse the content of each line
Scanner scanner = new Scanner(aLine);
if ( scanner.hasNext() ){
scanner.next();
String function = scanner.next();
String password = scanner.next();
//if we are doing approval for openingBalance of closingBalance
if(feature.equals("openingBalance")||feature.equals("closingBalance ")){
boolean invalidFormat = false;
//check that correct balance format has been entered
try{
formatter.format(Float.valueOf(balanceText.getText()));
catch(IllegalArgumentException e){
System.out.println("invalid format was entered");
invalidFormat = true;
if(balanceText.isVisible() && !balanceText.getText().equals("") &&
!invalidFormat){
System.out.println("correct fomat and not empty");
//approval was successful for manager
approvalResult = true;
approvalAmount =
displayApprovalError[0]=""; //don't display an approval error
displayApprovalError[2]="";
//check that manager password is correct
if(function.equals("manager") &&
password.equals(passwordField.getText())){
displayApprovalError[1]="";
else{
displayApprovalError[0] = "show";
displayApprovalError[1] = "Manager";
else{
displayApprovalError[0] = "show"; //display an approval error
displayApprovalError[2] = "format";
//if we are doing approval for discount
else if(feature.equals("discount")){
else{
else { //this line in approval.txt is not relevant
scanner.close();
return approvalResult;
private void createTableBills(Composite parent) {
int style = SWT.SINGLE | SWT.BORDER | SWT.H_SCROLL | SWT.V_SCROLL |
SWT.FULL_SELECTION | SWT.HIDE_SELECTION;
gridData = new GridData(100, 15);
gridData.verticalIndent=20;
currencyBills = new Label(parent,SWT.None);
currencyBills.setText("Currency Notes/Bills: ");
currencyBills.setLayoutData(gridData);
currencyBills.setVisible(true);
gridData = new GridData(SWT.BEGINNING,SWT.TOP,false,false);
tableBills = new Table(parent,style);
//table.setLayout(gridLayout);
tableBills.setLayoutData(gridData);
tableBills.setBackground(white);
tableBills.setHeaderVisible(true);
tableBills.setLinesVisible(true);
// 1st currency
TableColumn column = new TableColumn(tableBills, SWT.CENTER, 0);
column.setText("£100 (Scottish)");
column.setWidth(120);
// 2nd currency
column = new TableColumn(tableBills, SWT.LEFT, 1);
column.setText("£50");
column.setWidth(50);
// 3rd currency
column = new TableColumn(tableBills, SWT.LEFT, 2);
column.setText("£20");
// 4th currency
column = new TableColumn(tableBills, SWT.LEFT, 3);
column.setText("£10");
// 5th currency
column = new TableColumn(tableBills, SWT.LEFT, 4);
column.setText("£5");
private void createTableViewerBills(String balType, Composite parent) {
ApproveDialog.BALANCETYPE = balType;
try{
catch(Exception e){
private void createTableCoins(Composite parent) {
gridData.verticalIndent=10;
currencyCoins = new Label(parent,SWT.None);
currencyCoins.setText("Currency Coins: ");
currencyCoins.setLayoutData(gridData);
currencyCoins.setVisible(true);
tableCoins = new Table(parent,style);
tableCoins.setLayoutData(gridData);
tableCoins.setBackground(white);
tableCoins.setHeaderVisible(true);
tableCoins.setLinesVisible(true);
// 1st currency
TableColumn column = new TableColumn(tableCoins, SWT.CENTER, 0);
column.setText("£2");
// 2nd currency
column = new TableColumn(tableCoins, SWT.LEFT, 1);
column.setText("£1");
// 3rd currency
column = new TableColumn(tableCoins, SWT.LEFT, 2);
column.setText("50p");
// 4th currency
column = new TableColumn(tableCoins, SWT.LEFT, 3);
column.setText("20p");
// 5th currency
column = new TableColumn(tableCoins, SWT.LEFT, 4);
column.setText("10p");
// 6th currency
column = new TableColumn(tableCoins, SWT.LEFT, 5);
column.setText("5p");
// 7th currency
column = new TableColumn(tableCoins, SWT.LEFT, 6);
column.setText("2p");
// 8th currency
column = new TableColumn(tableCoins, SWT.LEFT, 7);
column.setText("1p");
private void createTableViewerCoins(String balType, Composite parent) {
try{
viewerCoins = new TableViewer(tableCoins);
viewerCoins.setUseHashlookup(true);
viewerCoins.setColumnProperties(COLUMNNAMESCOINS);
CellEditor[] editors = new CellEditor[COLUMNNAMESCOINS.length];
TextCellEditor textEditor = new TextCellEditor(tableCoins);
// Column 3 : quantity (Text with digits only)
viewerCoins.setCellEditors(editors);
viewerCoins.setCellModifier(new CellCoinModifier(viewerCoins));
catch(Exception e){
* This inner class implements an ICellModifier
* An ICellModifier is called when the user modifes a cell in the
* tableViewer.
class CellBillModifier implements ICellModifier {
private ApproveDialog dialog;
//ApproveDialog dialog;
* Constructor
* @param OrderTableViewer an instance of a OrderTableViewer
public CellBillModifier(ApproveDialog dialog) {
super();
// this.dialog=dialog;
System.out.println("been here 1");
* @see
org.eclipse.jface.viewers.ICellModifier#canModify(java.lang. Object,
java.lang.String)
public boolean canModify(Object element, String property) {
System.out.println("been here 2");
return true;
* @see
org.eclipse.jface.viewers.ICellModifier#getValue(java.lang.O bject,
java.lang.String)
public Object getValue(Object element, String property) {
System.out.println("been here 3");
// Find the index of the column
int columnIndex = ApproveDialog.GETCOLUMNNAMESBILLS().indexOf(property);
Object result = null;
CurrencyBill currencyBill = (CurrencyBill) element;
if(ApproveDialog.BALANCETYPE.equals("opening")){ //we are modifying a
cell in the openingBalance tableviewer
switch (columnIndex) {
case 0 : // CURRENCY A COLUMN
System.out.println("been here 4");
result = currencyBill.getOpeningCurrencyA();
break;
case 1 : // CURRENCY B COLUMN
result = currencyBill.getOpeningCurrencyB();
break;
case 2 : // CURRENCY C COLUMN
result = currencyBill.getOpeningCurrencyC();
break;
case 3 : // CURRENCY D COLUMN
result = currencyBill.getOpeningCurrencyD();
break;
case 4 : // CURRENCY E COLUMN
result = currencyBill.getOpeningCurrencyE();
break;
default :
result = "";
if(ApproveDialog.BALANCETYPE.equals("closing")){ //we are modifying a
cell in the closingBalance tableviewer
System.out.println("been here 5");
result = currencyBill.getClosingCurrencyA();
break;
result = currencyBill.getClosingCurrencyB();
break;
result = currencyBill.getClosingCurrencyC();
break;
result = currencyBill.getClosingCurrencyD();
break;
result = currencyBill.getClosingCurrencyE();
break;
default :
result = "";
return result;
* @see org.eclipse.jface.viewers.ICellModifier#modify(java.lang.Obj ect,
java.lang.String, java.lang.Object)
public void modify(Object element, String property, Object value) {
System.out.println("been here 6");
TableItem tableItem = (TableItem) element;
CurrencyBill currencyBill = (CurrencyBill) tableItem.getData();
String valueString;
if(BALANCETYPE.equals("opening")){
System.out.println("been here 7");
valueString = ((String) value).trim();
if (valueString.length() == 0)
valueString = "0";
currencyBill.setOpeningCurrA(Integer.parseInt(valueString));
break;
valueString = "0";
currencyBill.setOpeningCurrB(Integer.parseInt(valueString));
break;
valueString = "0";
currencyBill.setOpeningCurrC(Integer.parseInt(valueString));
break;
valueString = "0";
currencyBill.setOpeningCurrD(Integer.parseInt(valueString));
break;
valueString = "0";
currencyBill.setOpeningCurrE(Integer.parseInt(valueString));
break;
default :
ApproveDialog.getCurrencyBillList().quantityChanged(currency Bill);
* tableViewer.
class CellCoinModifier implements ICellModifier {
private String balanceType;
private Viewer viewerCoins;
* Constructor
public CellCoinModifier(TableViewer viewerCoins) {
super();
this.balanceType=ApproveDialog.BALANCETYPE;
this.viewerCoins = viewerCoins;
* @see
java.lang.String)
return true;
* @see
java.lang.String)
int columnIndex = ApproveDialog.GETCOLUMNNAMESCOINS().indexOf(property);
CurrencyCoin currencyCoin = (CurrencyCoin) element;
if(balanceType.equals("opening"))
result = currencyCoin.getOpeningCurrencyA();
else result = currencyCoin.getClosingCurrencyA();
break;
result = currencyCoin.getOpeningCurrencyB();
else result = currencyCoin.getClosingCurrencyB();
break;
result = currencyCoin.getOpeningCurrencyC();
else result = currencyCoin.getClosingCurrencyC();
break;
result = currencyCoin.getOpeningCurrencyD();
else result = currencyCoin.getClosingCurrencyD();
break;
result = currencyCoin.getOpeningCurrencyE();
else result = currencyCoin.getClosingCurrencyE();
break;
case 5 : // CURRENCY F COLUMN
result = currencyCoin.getOpeningCurrencyF();
else result = currencyCoin.getClosingCurrencyF();
break;
case 6 : // CURRENCY G COLUMN
result = currencyCoin.getOpeningCurrencyG();
else result = currencyCoin.getClosingCurrencyG();
break;
case 7 : // CURRENCY H COLUMN
result = currencyCoin.getOpeningCurrencyH();
else result = currencyCoin.getClosingCurrencyH();
break;
default :
result = "";
return result;
CurrencyCoin currencyCoin = (CurrencyCoin) tableItem.getData();
String valueString;
valueString = "0";
currencyCoin.setOpeningCurrA(Integer.parseInt(valueString));
else currencyCoin.setClosingCurrA(Integer.parseInt(valueString));
break;
valueString = "0";
currencyCoin.setOpeningCurrB(Integer.parseInt(valueString));
else currencyCoin.setClosingCurrB(Integer.parseInt(valueString));
break;
valueString = "0";
currencyCoin.setOpeningCurrC(Integer.parseInt(valueString));
else currencyCoin.setClosingCurrC(Integer.parseInt(valueString));
break;
valueString = "0";
currencyCoin.setOpeningCurrD(Integer.parseInt(valueString));
else currencyCoin.setClosingCurrD(Integer.parseInt(valueString));
break;
valueString = "0";
currencyCoin.setOpeningCurrE(Integer.parseInt(valueString));
else currencyCoin.setClosingCurrE(Integer.parseInt(valueString));
break;
valueString = "0";
currencyCoin.setOpeningCurrF(Integer.parseInt(valueString));
else currencyCoin.setClosingCurrF(Integer.parseInt(valueString));
break;
valueString = "0";
currencyCoin.setOpeningCurrG(Integer.parseInt(valueString));
else currencyCoin.setClosingCurrG(Integer.parseInt(valueString));
break;
valueString = "0";
currencyCoin.setOpeningCurrH(Integer.parseInt(valueString));
else currencyCoin.setClosingCurrH(Integer.parseInt(valueString));
break;
default :
ApproveDialog.getCurrencyCoinList().quantityChanged(currency Coin);
* Return the column names in a collection
* @return List containing column names
public static java.util.List<String> GETCOLUMNNAMESBILLS() {
return Arrays.asList(COLUMNNAMESBILLS);
public static java.util.List<String> GETCOLUMNNAMESCOINS() {
return Arrays.asList(COLUMNNAMESCOINS);
* Return the CurrencyCoinList
public static CurrencyCoinList getCurrencyCoinList() {
return CURRENCYCOINLIST;
public static CurrencyBillList getCurrencyBillList() {
return CURRENCYBILLSLIST;
class CurrencyBillContentProvider implements
IStructuredContentProvider,ICurrencyBillListViewer{
public Object[] getElements(Object inputElement) {
if(CURRENCYBILLSLIST.getCurrency()!=null) {
return CURRENCYBILLSLIST.getCurrency().toArray();
else
return new Object[]{};
public void dispose() {
// TODO Auto-generated method stub
public void inputChanged(Viewer viewer, Object oldInput, Object
newInput) {
if (newInput != null)
((CurrencyBillList) newInput).addChangeListener(this);
if (oldInput != null)
((CurrencyBillList) oldInput).removeChangeListener(this);
public void updateQuantity(CurrencyBill bill) {
viewerBills.update(bill,null);
class CurrencyCoinContentProvider implements
IStructuredContentProvider,ICurrencyCoinListViewer{
if(CURRENCYCOINLIST.getCurrency()!=null) {
return CURRENCYCOINLIST.getCurrency().toArray();
else
newInput) {
((CurrencyCoinList) newInput).addChangeListener(this);
((CurrencyCoinList) oldInput).removeChangeListener(this);
public void updateQuantity(CurrencyCoin coin) {
viewerCoins.update(coin,null);
Re: CellModifier in TreeViewer in Dialog class [message #16574 is a reply to message #16552] |
Wed, 24 June 2009 20:57 |
Thomas Schindl Messages: 6651 Registered: July 2009 |
Hi Igor,
I need something I can run locally without modification. This snippet is
missing a lot of stuff! Could you start with a snippet from our
collection [1] and modify it in a way that I can see the problem?
Please keep it as minimal as possible!
Tom
[1]http://wiki.eclipse.org/JFaceSnippets
> GridData gridData;
> Table tableBills;
> Table tableCoins;
> CurrencyBillList(); // Create a CoinList and assign it to an
> instance variable
> CurrencyCoinList();
> if no digit is available.
> try {
> } catch (Exception ex) {
> return NOVALUE;
> super(parentShell);
> break;
> break;
> break;
> * @see
> tableviewer for opening bal
> ExampleTaskList
> tableviewer closing bal
> ExampleTaskList
> return comp;
> * @see
> pressed.
> else { //check for valid manager password discount
> try {
> try {
> break; }
> "Error", displayApprovalError[1]+" password incorrect.");
> "Error", displayApprovalError[1]+" balance incorrect, " +
> catch(Exception e){
> finally {
> scanner.close();
> super.okPressed();
> /** * This method checks approvals.txt for valid manager password.
> otherwise
> scanner.next();
> try{
> !balanceText.getText().equals("") && !invalidFormat){
> approvalAmount =
> approval error
> approval error
> else{
> else{
> approval error
> approval error
> else{
> scanner.close();
> SWT.V_SCROLL | SWT.FULL_SELECTION | SWT.HIDE_SELECTION;
> // 1st currency
> 0);
> // 2nd currency
> // 3rd currency
> // 4th currency
> // 5th currency
> try{
> following // if using JRE1.4 such as e.doit
> catch(Exception e){
> // 1st currency
> 0);
> // 2nd currency
> // 3rd currency
> // 4th currency
> // 5th currency
> // 6th currency
> // 7th currency
> // 8th currency
> try{
> catch(Exception e){
> * tableViewer.
> * Constructor * @param OrderTableViewer an instance of
> a OrderTableViewer */
> super();
> * @see
> java.lang.String)
> return true;
> * @see
> java.lang.String)
> int columnIndex =
> modifying a cell in the openingBalance tableviewer
> break;
> break;
> case 2 : // CURRENCY C COLUMN result
> break;
> break;
> break;
> default :
> result = "";
> modifying a cell in the closingBalance tableviewer
> break;
> break;
> break;
> break;
> break;
> default :
> result = "";
> return result;
> * @see
> value) {
> // Find the index of the column int
> String valueString;
> valueString = "0";
> break;
> valueString = "0";
> break;
> valueString = "0";
> break;
> valueString = "0";
> break;
> valueString = "0";
> break;
> default :
> * tableViewer.
> super();
> * @see
> java.lang.String)
> return true;
> * @see
> java.lang.String)
> int columnIndex =
> break;
> break;
> break;
> break;
> break;
> break;
> break;
> break;
> default :
> result = "";
> return result;
> * @see
> value) {
> String valueString;
> valueString = "0";
> else
> break;
> valueString = "0";
> else
> break;
> valueString = "0";
> else
> break;
> valueString = "0";
> else
> break;
> valueString = "0";
> else
> break;
> valueString = "0";
> else
> break;
> valueString = "0";
> else
> break;
> valueString = "0";
> else
> break;
> default :
> * * @return List containing column names
> @Override
> else
> @Override
> @Override
> newInput) {
> @Override
> @Override
> else
> @Override
> @Override
> newInput) {
> @Override
Re: CellModifier in TreeViewer in Dialog class [message #16700 is a reply to message #16574] |
Fri, 26 June 2009 01:26 |
I modified a JFace example as you asked -
Snippet012DialogWithImageButtons. I don't know how to "keep it as minimal
as possible." I'm want to illustrate the way I create a table and
tableviewer and use a cellmodifier. Therefore, the code I'm going to
present here isn't short. If you have suggestions on how to make it
shorter please let me know.
Anyway, here is the entire class of the example:
* Copyright (c) 2006, 2008 Tom Schindl and others.
* All rights reserved. This program and the accompanying materials
* are made available under the terms of the Eclipse Public License v1.0
* which accompanies this distribution, and is available at
* http://www.eclipse.org/legal/epl-v10.html
* Contributors:
* Tom Schindl - initial API and implementation
package dialogs;
import java.util.Arrays;
import org.eclipse.jface.dialogs.Dialog;
import org.eclipse.jface.dialogs.IDialogConstants;
import org.eclipse.jface.resource.ImageDescriptor;
import org.eclipse.jface.resource.ImageRegistry;
import org.eclipse.jface.viewers.CellEditor;
import org.eclipse.jface.viewers.ICellModifier;
import org.eclipse.jface.viewers.TableViewer;
import org.eclipse.jface.viewers.TextCellEditor;
import org.eclipse.swt.SWT;
import org.eclipse.swt.events.VerifyEvent;
import org.eclipse.swt.events.VerifyListener;
import org.eclipse.swt.layout.FillLayout;
import org.eclipse.swt.layout.GridData;
import org.eclipse.swt.widgets.Button;
import org.eclipse.swt.widgets.Composite;
import org.eclipse.swt.widgets.Label;
import org.eclipse.swt.widgets.Shell;
import org.eclipse.swt.widgets.Table;
import org.eclipse.swt.widgets.TableColumn;
import org.eclipse.swt.widgets.TableItem;
import org.eclipse.swt.widgets.Text;
* A snippet to demonstrate a dialog with image buttons.
public class Snippet012DialogWithImageButtons {
private ImageRegistry registry;
Table tableBills;
public Snippet012DialogWithImageButtons(final Shell shell) {
Dialog dia = new Dialog(shell) {
private ImageDescriptor getImageDescriptor(String path) {
if( registry == null ) {
registry = new ImageRegistry(shell.getDisplay());
ImageDescriptor desc = registry.getDescriptor(path);
if( desc == null ) {
desc =
ImageDescriptor.createFromFile(Snippet012DialogWithImageButt ons.class,
path);
registry.put(path, desc);
return desc;
protected Button createButton(Composite parent, int id, String label,
boolean defaultButton) {
createTableBills(parent);
createTableViewerBills("opening",parent);
Button b = super.createButton(parent, id, label, defaultButton);
if( id == IDialogConstants.OK_ID ) {
b.setImage(getImageDescriptor("filesave.png").createImage());
//$NON-NLS-1$
// reset the button layout
setButtonLayoutData(b);
} else {
b.setImage(getImageDescriptor("cancel.png").createImage());
//$NON-NLS-1$
return b;
return b;
dia.open();
Display display = new Display ();
Shell shell = new Shell(display);
shell.setLayout(new FillLayout());
shell.open ();
new Snippet012DialogWithImageButtons(shell);
while (!shell.isDisposed ()) {
if (!display.readAndDispatch ()) display.sleep ();
display.dispose ();
GridData gridData = new GridData(100, 15);
Label currencyBills = new Label(parent,SWT.None);
// 1st currency
// 2nd currency
// 3rd currency
// 4th currency
// 5th currency
Snippet012DialogWithImageButtons.BALANCETYPE = balType;
try{
TableViewer viewerBills = new TableViewer(tableBills);
catch(Exception e){
* tableViewer.
private Snippet012DialogWithImageButtons dialog;
* Constructor
public CellBillModifier(Snippet012DialogWithImageButtons dialog) {
super();
* @see
java.lang.String)
return true;
* @see
java.lang.String)
int columnIndex =
Snippet012DialogWithImageButtons.GETCOLUMNNAMESBILLS().index Of(property);
//CurrencyBill currencyBill = (CurrencyBill) element;
if(Snippet012DialogWithImageButtons .BALANCETYPE.equals("opening")){
//we are modifying a cell in the openingBalance tableviewer
// result = currencyBill.getOpeningCurrencyA();
break;
// result = currencyBill.getOpeningCurrencyB();
break;
// result = currencyBill.getOpeningCurrencyC();
break;
//result = currencyBill.getOpeningCurrencyD();
break;
//result = currencyBill.getOpeningCurrencyE();
break;
default :
result = "";
if(Snippet012DialogWithImageButtons .BALANCETYPE.equals("closing")){
//we are modifying a cell in the closingBalance tableviewer
//result = currencyBill.getClosingCurrencyA();
break;
//result = currencyBill.getClosingCurrencyB();
break;
//result = currencyBill.getClosingCurrencyC();
break;
//result = currencyBill.getClosingCurrencyD();
break;
//result = currencyBill.getClosingCurrencyE();
break;
default :
result = "";
return result;
int columnIndex =
//CurrencyBill currencyBill = (CurrencyBill) tableItem.getData();
String valueString;
valueString = "0";
//currencyBill.setOpeningCurrA(Integer.parseInt(valueString) );
break;
valueString = "0";
//currencyBill.setOpeningCurrB(Integer.parseInt(valueString) );
break;
valueString = "0";
//currencyBill.setOpeningCurrC(Integer.parseInt(valueString) );
break;
valueString = "0";
//currencyBill.setOpeningCurrD(Integer.parseInt(valueString) );
break;
valueString = "0";
//currencyBill.setOpeningCurrE(Integer.parseInt(valueString) );
break;
default :
//ApproveDialog.getCurrencyBillList().quantityChanged(curren cyBill);
Re: CellModifier in TreeViewer in Dialog class [message #16715 is a reply to message #16700] |
Fri, 26 June 2009 07:44 |
.... and now your viewers have no input so I can't reproduce the problem.
Could you init them statically with a list of elements?
Tom
> minimal as possible." I'm want to illustrate the way I create a table
> and tableviewer and use a cellmodifier. Therefore, the code I'm going
> to present here isn't short. If you have suggestions on how to make it
> shorter please let me know. Anyway, here is the entire class of the
> example:
> * Contributors:
> package dialogs;
> import org.eclipse.swt.widgets.Display;
> Table tableBills;
> desc =
> path);
> return desc;
> String label, boolean defaultButton) {
> defaultButton);
> b.setImage(getImageDescriptor("filesave.png").createImage()); //$NON-NLS-1$
> } else {
> b.setImage(getImageDescriptor("cancel.png").createImage()); //$NON-NLS-1$
> return b;
> return b;
> dia.open();
> public static void main(String[] args) {
> shell.open ();
> display.dispose ();
> // 1st currency
> 0);
> // 2nd currency
> // 3rd currency
> // 4th currency
> // 5th currency
> try{
> the following // if using JRE1.4 such
> 0 ;
> catch(Exception e){
> * tableViewer.
> super();
> * @see
> java.lang.String)
> return true;
> * @see
> java.lang.String)
> int columnIndex =
> .BALANCETYPE.equals("opening")){ //we are modifying a cell in the
> break;
> break;
> case 2 : // CURRENCY C COLUMN //
> break;
> break;
> break;
> default :
> result = "";
> .BALANCETYPE.equals("closing")){ //we are modifying a cell in the
> break;
> break;
> break;
> break;
> break;
> default :
> result = "";
> return result;
> * @see
> value) {
> columnIndex =
> String valueString;
> valueString = "0";
> break;
> valueString = "0";
> break;
> valueString = "0";
> break;
> valueString = "0";
> break;
> valueString = "0";
> break;
> default :
Re: CellModifier in TreeViewer in Dialog class [message #17508 is a reply to message #16715] |
Fri, 26 June 2009 14:56 |
Do I have to have a ContentProvider and LabelProvider? I think I was
getting confused. What I want to do is have an empty table that the user
can fill in. Upon pressing a submit button in the dialog, this table data
should be saved in a model.
So what I was trying to do is have an empty table that has an input of an
empty model. I just want to allow editing and saving the table's data.
Is that possible?
Re: CellModifier in TreeViewer in Dialog class [message #17550 is a reply to message #17537] |
Fri, 26 June 2009 16:30 |
Ok, that makes sense. Now I don't understand why the tableviewer has 2
columns instead of 1. Take a look at the modified code:
* Contributors:
package dialogs;
import java.util.ArrayList;
import org.eclipse.jface.viewers.ArrayContentProvider;
Table tableBills;
desc =
path);
return desc;
//$NON-NLS-1$
} else {
//$NON-NLS-1$
return b;
return b;
dia.open();
shell.open ();
display.dispose ();
// 1st currency
// 2nd currency
// 3rd currency
// 4th currency
// 5th currency
try{
ArrayList arrlist = new ArrayList();
arrlist.add("test1");
viewerBills.setContentProvider(new ArrayContentProvider());//{
viewerBills.setInput(arrlist);
catch(Exception e){
* tableViewer.
* Constructor
super();
* @see
java.lang.String)
return true;
* @see
java.lang.String)
int columnIndex =
break;
break;
break;
break;
break;
default :
result = "";
break;
break;
break;
break;
break;
default :
result = "";
return result;
int columnIndex =
String valueString;
valueString = "0";
break;
valueString = "0";
break;
valueString = "0";
break;
valueString = "0";
break;
valueString = "0";
break;
default :
Current Time: Thu Apr 25 04:31:34 GMT 2024
Powered by FUDForum. Page generated in 0.03610 seconds
