Home » Eclipse Projects » SWTBot » Eclipse doesn't show launcher configuration "SWTBot Test"
Eclipse doesn't show launcher configuration "SWTBot Test" [message #16458] Wed, 21 January 2009 11:07 Go to next message
Previously I started the RCP JUnit Tests not as SWTBot Test because of the
compatibility issue. I had problems backporting the SWTBot plugin to
Eclipse 3.2.2, which now is not needed since we migrated to 3.3.1.
Now I tried to use that special launcher. I thought that I have to do this
in order to install the SWTBot plugin which provides this extra launch
configuration:
1. Export plugin "org.eclipse.swtbot.eclipse.ui" so that a jar file is
created like "org.eclipse.swtbot.eclipse.ui_2.0.0.200901211658.jar".
2. Copy that file into the dropins folder of Eclipse 3.4.x or into the
plugins folder.
3. Start Eclipse (with or without -clean option).
4. Go to "Run>Run Configurations" and see "SWTBot Test" there.
But I don't see that launch configuration there. I tried it several times.
It seems that Eclipse doesn't install or activate that plugin at all.
What is wrong?
Re: Eclipse doesn't show launcher configuration "SWTBot Test" [message #16496 is a reply to message #16458] Wed, 21 January 2009 12:07 Go to previous messageGo to next message
> configuration:
> plugins folder.
> What is wrong?
I don't know what is wrong... I tried the same and I couldn't see the
"SWTBot Test" either.
It migth comes from eclipse.
I tried to install by directly inserting the SWTBOT plugin in eclipse's
plugin directory. This is not recommended ... but it worked for me.
But in the end, I'm not using this method.
I set the Eclipse Update manager to point to the swtbot update site.
Then eclipse downloaded it and installed it properly. That's good because
it will now be able to detect updates on swtbot and download it.
Eclipse Update manager : menu HELP > Sofware update
Bye
Marc
Re: Eclipse doesn't show launcher configuration "SWTBot Test" [message #16583 is a reply to message #16496] Thu, 22 January 2009 05:01 Go to previous messageGo to next message
Which Update Site URL did you use? I haven't found any for the new version
of SWTBot which has been migrated to the Eclipse project.
Re: Eclipse doesn't show launcher configuration "SWTBot Test" [message #16598 is a reply to message #16583] Thu, 22 January 2009 05:27 Go to previous messageGo to next message
Finally got my commit access to orbit resolved.
I'll be pushing out an 'official' build this weekend. You can download a
recent build here:
http://swtbot.sourceforge.net/artifacts/2.0-eclipse/update-s ite/
-- Ketan
> version of SWTBot which has been migrated to the Eclipse project.
Re: Eclipse doesn't show launcher configuration "SWTBot Test" [message #16648 is a reply to message #16598] Thu, 22 January 2009 06:21 Go to previous messageGo to next message
> recent build here:
> -- Ketan
Thank you. It works when I install it this way. But it installs much more
than I wanted. As it seems I cannot just install the SWTBot Test launcher
plugin. This was possible previously, even in a former 2.0 stream version
I think. I guess I have to export all these plugins now:
org.eclipse.swtbot.eclipse.ui, org.eclipse.swtbot.eclipse.core,
org.eclipse.swtbot.swt.finder, org.eclipse.swtbot.eclipse.finder and
org.eclipse.swtbot.eclipse.spy.
Will you close sourceforge repository then soon? Because I feel its
confusing to have two of them, one at Eclipse and one at Sourceforge, with
potential different versions. The SWTBot update site will be on Eclipse
pages too I guess and closed on Sourceforge?
Re: Eclipse doesn't show launcher configuration "SWTBot Test" [message #16678 is a reply to message #16648] Thu, 22 January 2009 08:27 Go to previous message
> with potential different versions. The SWTBot update site will be on
> Eclipse pages too I guess and closed on Sourceforge?
Yes, I'll be closing everything at Sourceforge and redirect everything
to the eclipse website.
-- Ketan
Previous Topic:Move position of an element on a graphical editor
Next Topic:can't find button
Current Time: Sat Jun 14 05:07:53 EDT 2025
Powered by FUDForum. Page generated in 0.06994 seconds
