Home » Language IDEs » C / C++ IDE (CDT) » Share projects on multiple platforms
Share projects on multiple platforms [message #1134347] Sat, 12 October 2013 08:23 Go to next message
Hi all,
I am trying to create multiple C++ projects, which have to be shared among different computers (which are in turn running different operating systems).
I have created my projects using a PC with Windows 7. However, I noticed that Eclipse binds some configurations to the projects: for instance, it is said that once the code is compiled, a .exe file has to be created. Obviously this is NOT working on other platforms (Mac OS X, Linux, unix in general), since a .exe file cannot be executed.
Is there a simple way of sharing a project across different platforms, or convert an existing project in Windows in a project for other platforms? I am requiring, if possible, a simple technique, since I have to share these projects with newbies, and I cannot ask them to do complicated things in order to achieve the expected result.
Thank you all in advance,
Best,
Eleanore.
Re: Share projects on multiple platforms [message #1134709 is a reply to message #1134347] Sat, 12 October 2013 14:11 Go to previous messageGo to next message
Hello Eleanore,
"Simple"? I think that is not possible.
But read this article to find out more:
"Cross-Platform C/C++ Development with Eclipse CDT":
http://www.drdobbs.com/cpp/cross-platform-cc-development-with-eclip/232300575
Klaus
Re: Share projects on multiple platforms [message #1135627 is a reply to message #1134709] Sun, 13 October 2013 05:24 Go to previous messageGo to next message
Solution is quite simple - create subfolders in your project such as:
./Platform/Linux
./Platform/Windows
etc. and put there (create new) projects, one per each platform. I think that's only reasonable solution.
Re: Share projects on multiple platforms [message #1140342 is a reply to message #1135627] Wed, 16 October 2013 05:39 Go to previous message
You should create a build configuration for every platform. In each build configuration you can define the tool chain, build steps, paths etc.
This way you can share the project and people will use a build configuration depending on their local OS.
see http://help.eclipse.org/kepler/index.jsp?topic=%2Forg.eclipse.cdt.doc.user%2Freference%2Fcdt_u_prop_all.htm
[Updated on: Wed, 16 October 2013 05:40] by Moderator
Previous Topic:Convinient way of switching between Cross GCC and native build?
Next Topic:"required from..." errors
Current Time: Wed Jun 18 02:33:07 EDT 2025
Powered by FUDForum. Page generated in 0.03445 seconds
