Re: Having issues with Kepler SR1 and Gemini Web [message #1137287 is a reply to message #1133420] |
Mon, 14 October 2013 11:37 |
Violeta Georgieva Messages: 278 Registered: October 2010 |
That's very strange. I do not have any problems.
My custom target platform is:
http://download.eclipse.org/releases/kepler/ - "Equinox Core Function" feature
http://download.eclipse.org/gemini/updates/web/2.2.2
osgi> Oct 14, 2013 2:32:17 PM org.apache.catalina.core.AprLifecycleListener init
INFO: The APR based Apache Tomcat Native library which allows optimal performance in production environments was not found on the java.library.path: ...
Oct 14, 2013 2:32:19 PM org.apache.coyote.AbstractProtocol init
INFO: Initializing ProtocolHandler ["http-bio-8080"]
INFO: Initializing ProtocolHandler ["ajp-bio-8009"]
Oct 14, 2013 2:32:19 PM org.apache.catalina.core.StandardService startInternal
INFO: Starting service Catalina
Oct 14, 2013 2:32:19 PM org.apache.catalina.core.StandardEngine startInternal
INFO: Starting Servlet Engine: Apache Tomcat/7.0.35
Oct 14, 2013 2:32:19 PM org.apache.coyote.AbstractProtocol start
INFO: Starting ProtocolHandler ["http-bio-8080"]
INFO: Starting ProtocolHandler ["ajp-bio-8009"]
ss
"Framework is launched."
id State Bundle
0 ACTIVE org.eclipse.osgi_3.9.1.v20130814-1242
1 ACTIVE org.eclipse.equinox.simpleconfigurator_1.0.400.v20130327-2119
2 ACTIVE com.springsource.javax.activation_1.1.1
3 ACTIVE javax.annotation_1.1.0.v201108011116
4 ACTIVE javax.ejb_3.1.1.v201204261316
5 ACTIVE javax.el_2.2.0.v201108011116
6 ACTIVE javax.mail_1.4.0.v201005080615
7 ACTIVE javax.persistence_2.0.4.v201112161009
8 ACTIVE javax.servlet_3.0.0.v201103241009
9 ACTIVE javax.servlet.jsp_2.2.0.v201112011158
10 ACTIVE javax.transaction_1.1.0.v201205091237
11 ACTIVE javax.xml.rpc_1.1.0.v201005080400
12 ACTIVE javax.xml.soap_1.3.0.v201105210645
13 ACTIVE org.apache.catalina_7.0.35.v201302131125
Fragments=14, 15, 16, 21, 24
14 RESOLVED org.apache.catalina.ha_7.0.35.v201302131607
Master=13
15 RESOLVED org.apache.catalina.tribes_7.0.35.v201302140645
Master=13
16 RESOLVED org.apache.coyote_7.0.35.v201302140645
Master=13
17 ACTIVE org.apache.el_7.0.35.v201302120746
18 ACTIVE org.apache.felix.gogo.command_0.10.0.v201209301215
19 ACTIVE org.apache.felix.gogo.runtime_0.10.0.v201209301036
20 ACTIVE org.apache.felix.gogo.shell_0.10.0.v201212101605
21 RESOLVED org.apache.jasper_7.0.35.v201302161127
Master=13
22 ACTIVE org.apache.juli.extras_7.0.35.v201302120746
23 ACTIVE org.apache.tomcat.api_7.0.35.v201302120746
24 RESOLVED org.apache.tomcat.util_7.0.35.v201302140645
Master=13
25 ACTIVE org.eclipse.core.jobs_3.5.300.v20130429-1813
26 ACTIVE org.eclipse.equinox.app_1.3.100.v20130327-1442
27 ACTIVE org.eclipse.equinox.common_3.6.200.v20130402-1505
28 ACTIVE org.eclipse.equinox.console_1.0.100.v20130429-0953
29 ACTIVE org.eclipse.equinox.ds_1.4.101.v20130813-1853
30 ACTIVE org.eclipse.equinox.registry_3.5.301.v20130717-1549
31 ACTIVE org.eclipse.equinox.util_1.0.500.v20130404-1337
32 ACTIVE org.eclipse.gemini.web.core_2.2.2.RELEASE
33 ACTIVE org.eclipse.gemini.web.extender_2.2.2.RELEASE
34 ACTIVE org.eclipse.gemini.web.tomcat_2.2.2.RELEASE
35 ACTIVE org.eclipse.jdt.core.compiler.batch_3.8.0.I20120518-2145
36 ACTIVE org.eclipse.osgi.services_3.3.100.v20130513-1956
37 ACTIVE org.eclipse.virgo.util.common_3.6.0.RELEASE
38 ACTIVE org.eclipse.virgo.util.io_3.6.0.RELEASE
39 ACTIVE org.eclipse.virgo.util.math_3.6.0.RELEASE
40 ACTIVE org.eclipse.virgo.util.osgi_3.6.0.RELEASE
41 ACTIVE org.eclipse.virgo.util.osgi.manifest_3.6.0.RELEASE
42 ACTIVE org.eclipse.virgo.util.parser.manifest_3.6.0.RELEASE
43 ACTIVE org.slf4j.api_1.7.2.v20121108-1250
Fragments=44
44 RESOLVED org.slf4j.nop_1.7.2.v201212060727
Master=43
osgi>
Can you post here what your exact problems are?
Violeta
Re: Having issues with Kepler SR1 and Gemini Web [message #1137565 is a reply to message #1133420] |
Mon, 14 October 2013 15:32 |
Nirav Sheth Messages: 2 Registered: October 2013 |
HI Violeta,
Here is what happens when I include the same bundles as you. The only extra bundle is javax.xml I can't get mine to work without it as that is a dependency for org.eclipse.equinox.registry. If you see below org.eclipse.osgi and org.eclipse.gemini.web.tomcat are stuck in STARTING state and it never starts even after 2 hours. If I "close" the framework down then it seems like org.eclipse.gemini.web.tomcat starts which logs the some things to the console.
I am not sure what I am I doing wrong, could it be the start level of the bundles causing this issue.
osgi> Oct 14, 2013 11:27:31 AM org.apache.catalina.core.AprLifecycleListener init
INFO: The APR based Apache Tomcat Native library which allows optimal performance in production environments was not found on the java.library.path: .:/Library/Java/Extensions:/System/Library/Java/Extensions:/usr/lib/java
ss
"Framework is shutdown."
id State Bundle
0 STARTING org.eclipse.osgi_3.9.1.v20130814-1242
3 ACTIVE javax.annotation_1.1.0.v201209060031
5 ACTIVE javax.el_2.2.0.v201303151357
8 ACTIVE javax.servlet_3.0.0.v201112011016
11 ACTIVE javax.xml_1.3.4.v201005080400
12 ACTIVE javax.xml.rpc_1.1.0.v201209140446
13 ACTIVE javax.xml.soap_1.3.0.v201105210645
14 ACTIVE org.apache.catalina_7.0.35.v201302131125
Fragments=15, 16, 17, 22, 25
15 RESOLVED org.apache.catalina.ha_7.0.35.v201302131607
Master=14
16 RESOLVED org.apache.catalina.tribes_7.0.35.v201302140645
Master=14
17 RESOLVED org.apache.coyote_7.0.35.v201302140645
Master=14
18 ACTIVE org.apache.el_7.0.35.v201302120746
19 ACTIVE org.apache.felix.gogo.command_0.10.0.v201209301215
20 ACTIVE org.apache.felix.gogo.runtime_0.10.0.v201209301036
21 ACTIVE org.apache.felix.gogo.shell_0.10.0.v201212101605
22 RESOLVED org.apache.jasper_7.0.35.v201302161127
Master=14
23 ACTIVE org.apache.juli.extras_7.0.35.v201302120746
24 ACTIVE org.apache.tomcat.api_7.0.35.v201302120746
25 RESOLVED org.apache.tomcat.util_7.0.35.v201302140645
Master=14
26 ACTIVE org.eclipse.core.jobs_3.5.300.v20130429-1813
27 ACTIVE org.eclipse.equinox.app_1.3.100.v20130327-1442
28 ACTIVE org.eclipse.equinox.common_3.6.200.v20130402-1505
29 ACTIVE org.eclipse.equinox.console_1.0.100.v20130429-0953
30 ACTIVE org.eclipse.equinox.ds_1.4.101.v20130813-1853
31 ACTIVE org.eclipse.equinox.registry_3.5.301.v20130717-1549
32 ACTIVE org.eclipse.equinox.util_1.0.500.v20130404-1337
33 ACTIVE org.eclipse.gemini.web.core_2.2.2.RELEASE
34 ACTIVE org.eclipse.gemini.web.extender_2.2.2.RELEASE
35 STARTING org.eclipse.gemini.web.tomcat_2.2.2.RELEASE
36 RESOLVED org.eclipse.jdt.core.compiler.batch_3.8.0.I20120518-2145
37 RESOLVED org.eclipse.osgi.services_3.3.100.v20130513-1956
38 RESOLVED org.eclipse.virgo.util.common_3.6.0.RELEASE
39 RESOLVED org.eclipse.virgo.util.io_3.6.0.RELEASE
40 RESOLVED org.eclipse.virgo.util.math_3.6.0.RELEASE
41 RESOLVED org.eclipse.virgo.util.osgi_3.6.0.RELEASE
42 RESOLVED org.eclipse.virgo.util.osgi.manifest_3.6.0.RELEASE
43 RESOLVED org.eclipse.virgo.util.parser.manifest_3.6.0.RELEASE
44 RESOLVED org.slf4j.api_1.7.2.v20121108-1250
Fragments=45
45 RESOLVED org.slf4j.nop_1.7.2.v201212060727
Master=44
osgi> close
Really want to stop Equinox? (y/n; default=y) y
osgi> 2013-10-14 11:28:37.494 java[18151:707] [Java CocoaComponent compatibility mode]: Enabled
2013-10-14 11:28:37.495 java[18151:707] [Java CocoaComponent compatibility mode]: Setting timeout for SWT to 0.100000
Oct 14, 2013 11:28:37 AM org.apache.coyote.AbstractProtocol init
Oct 14, 2013 11:28:37 AM org.apache.catalina.core.StandardService startInternal
Oct 14, 2013 11:28:37 AM org.apache.catalina.core.StandardEngine startInternal
Oct 14, 2013 11:28:37 AM org.apache.coyote.AbstractProtocol start
Oct 14, 2013 11:28:37 AM org.apache.coyote.AbstractProtocol pause
INFO: Pausing ProtocolHandler ["http-bio-8080"]
INFO: Pausing ProtocolHandler ["ajp-bio-8009"]
Oct 14, 2013 11:28:37 AM org.apache.catalina.core.StandardService stopInternal
INFO: Stopping service Catalina
Oct 14, 2013 11:28:37 AM org.apache.coyote.AbstractProtocol stop
INFO: Stopping ProtocolHandler ["http-bio-8080"]
INFO: Stopping ProtocolHandler ["ajp-bio-8009"]
Oct 14, 2013 11:28:37 AM org.apache.coyote.AbstractProtocol destroy
INFO: Destroying ProtocolHandler ["http-bio-8080"]
INFO: Destroying ProtocolHandler ["ajp-bio-8009"]
FUDForum. Page generated in 0.03142 seconds
