Home » Modeling » TMF (Xtext) » problem with xtext and antlr(Decision can match input such as “'?'” using multiple alternatives: 1, 2)
problem with xtext and antlr [message #1133242] Fri, 11 October 2013 18:14 Go to next message
Luca Puglia is currently offline Luca PugliaFriend
0 down vote favorite
I'm using xText for writing a new eclipse plugin for a new language. But when I try to generate the code Antlr give me this warning:
Decision can match input such as "'?'" using multiple alternatives: 1, 2
I'm sure, after commenting much code, that the problem is in the following code snip:
Expression:
     operatorExpr=OperatorExpr (condExpr=CondExpr)?
     |exprPrimary=ExprPrimary (condExpr=CondExpr)?
CondExpr:
ExprPrimary:
     Identifier
OperatorExpr:
     '+' expression=Expression
How can i solve the warning?
Re: problem with xtext and antlr [message #1135539 is a reply to message #1133242] Sun, 13 October 2013 07:56 Go to previous messageGo to next message
Jan Koehnlein is currently offline Jan KoehnleinFriend
Given e.g.
+ <someIdentifier> ?
the parser cannot decide whether the '?' belongs to the Expression
holding the OperatorExpression or the one holding the PrimaryExpression.
This is equivalent to the famous dangling-else problem (Google).
You could use a syntactic predicate to solve this, but it looks like
you're trying to build an expression grammar, which should be structured
differently in LL grammars. I'd suggest to read
http://blog.efftinge.de/2010/08/parsing-expressions-with-xtext.html
Am 11.10.13 21:09, schrieb Luca Puglia:
> Expression:
> CondExpr:
> ExprPrimary:
> Identifier
> OperatorExpr:
Get professional support from the Xtext committers at www.typefox.io
Re: problem with xtext and antlr [message #1139572 is a reply to message #1135539] Tue, 15 October 2013 21:38 Go to previous message
NESARAJ THOMPSON is currently offline NESARAJ THOMPSONFriend
Can you please let me know how did you deploy the xtext project ? Is it integrated with eclipse as a plug-in?
Previous Topic:platform:/resource when projects sit outside the workspace?
Next Topic:Terminal
Current Time: Mon Jan 25 21:09:10 GMT 2021
Powered by FUDForum. Page generated in 0.01960 seconds
