Home » Language IDEs » ServerTools (WTP) » WTP 1.5 Web Services Explorer does not work
Re: WTP 1.5 Web Services Explorer does not work [message #174370 is a reply to message #174295] |
Thu, 13 July 2006 13:49 |
Chris Brealey Messages: 104 Registered: July 2009 |
Marcel,
are you running with a Sun 1.4 JRE? I was able to reproduce what might be the
same problem. After clicking "Go" to load XMethods' query.wsdl, the WSE spends a
few seconds with the progress bar ticking away, then goes quiet. From a look at
the latest Catalina log in .metadata\.plugins\org.eclipse.tomcat, the problem is
due to a collision deep within the WSE between Crimson and Xerces.
Try restarting Eclipse like this, replacing "C:\..." by whatever your root path
to your eclipse directory is...
eclipse -vmargs
-Djava.endorsed.dirs=C:\...\eclipse\plugins\org.apache.xerce s_2.8.0.v200606131651
Meanwhile, please feel encouraged to open a bug [1]. There may not be much we can
do to solve this, and Crimson is gone in Java 5 anyways, but I'd still like to
track the issue and possibly take a crack at it.
Cheers - CB.
[1]
https://bugs.eclipse.org/bugs/enter_bug.cgi?product=Web%20To ols&component=wst.ws&rep_platform=all&op_sys=all
Marcel wrote:
> Hi Peter,
> yes, opening the wsdl in a browser was very fast the time I had the
> problem with Web Services Explorer.
> It looks like the problem is related to some sort of complex wsdl's
> because I have the same problem with my own webservice which is located on
> my local machine.
> Marcel
> Peter Moogk wrote:
> > Hi Marcel,
> > I have found that the xmethods site can be very slow at times. Can you
> > reach this WSDL file through a browser? Thanks.
> > Peter Moogk
> > Marcel wrote:
> >> In WTP 1.5 the Web Services Explorer is not working any longer.
> >> I tried to open wsdl "http://www.xmethods.net/wsdl/query.wsdl" and pressed
> >> the "Go" button. Nothing happens. Trying to press "Go" again shows "Please
> >> wait. Operation is still in progress." It looks like reading the wsdl will
> >> last forever. The URL is valid and reachable and with WTP 1.0 it is
> >> working.
Re: WTP 1.5 Web Services Explorer does not work [message #174378 is a reply to message #174370] |
Thu, 13 July 2006 13:52 |
--------------62D321D50C57F1161FDEDAF5
Content-Type: text/plain; charset=us-ascii
Marcel,
I forgot to mention this, obvious though it might be, but the workaround I just described effectively replaces
Crimson by Xerces as the preferred XML parser, and after a few seconds of processing the WSE appears to
successfully load the WSDL. FYI, I'm doing all this on java full version "1.4.2_05-b04".
Cheers - CB.
Chris Brealey wrote:
> Marcel,
> eclipse -vmargs
> Cheers - CB.
> [1]
> Marcel wrote:
> > Hi Peter,
> > my local machine.
> > Marcel
> > Peter Moogk wrote:
> > > Hi Marcel,
> > > Peter Moogk
> > >> working.
Content-Type: text/html; charset=us-ascii
<!doctype html public "-//w3c//dtd html 4.0 transitional//en">
<html>
Marcel,
<br>I forgot to mention this, obvious though it might be, but the workaround
I just described effectively replaces Crimson by Xerces as the preferred
XML parser, and after a few seconds of processing the WSE appears to successfully
<p>Cheers - CB.
<p>Chris Brealey wrote:
<blockquote TYPE=CITE>Marcel,
<br>are you running with a Sun 1.4 JRE? I was able to reproduce what might
be the
<br>same problem. After clicking "Go" to load XMethods' query.wsdl, the
WSE spends a
<br>few seconds with the progress bar ticking away, then goes quiet. From
a look at
<br>the latest Catalina log in .metadata\.plugins\org.eclipse.tomcat, the
problem is
<br>due to a collision deep within the WSE between Crimson and Xerces.
<p>Try restarting Eclipse like this, replacing "C:\..." by whatever your
root path
<br>to your eclipse directory is...
<p> eclipse -vmargs
<br> -Djava.endorsed.dirs=C:\...\eclipse\plugins\org.apache.xerce s_2.8.0.v200606131651
<p>Meanwhile, please feel encouraged to open a bug [1]. There may not be
much we can
<br>do to solve this, and Crimson is gone in Java 5 anyways, but I'd still
like to
<br>track the issue and possibly take a crack at it.
<p>Cheers - CB.
<p>[1]
<br><a href=" https://bugs.eclipse.org/bugs/enter_bug.cgi?product=Web%20To ols&component=wst.ws&rep_platform=all&op_sys=all"> https://bugs.eclipse.org/bugs/enter_bug.cgi?product=Web%20To ols& ;component=wst.ws&rep_platform=all&op_sys=al l </a>
<p>Marcel wrote:
<p>> Hi Peter,
<br>>
<br>> yes, opening the wsdl in a browser was very fast the time I had the
<br>> problem with Web Services Explorer.
<br>> It looks like the problem is related to some sort of complex wsdl's
<br>> because I have the same problem with my own webservice which is located
on
<br>> my local machine.
<br>>
<br>> Marcel
<br>>
<br>> Peter Moogk wrote:
<br>>
<br>> > Hi Marcel,
<br>> > I have found that the xmethods site can be very
<br>> > reach this WSDL file through a browser? Thanks.
<br>>
<br>> > Peter Moogk
<br>>
<br>> > Marcel wrote:
<br>>
<br>> >> In WTP 1.5 the Web Services Explorer is not working any longer.
<br>>
<br>> >> I tried to open wsdl "<a href="http://www.xmethods.net/wsdl/query.wsdl">http://www.xmethods.net/wsdl/query.wsdl</a>"
and pressed
<br>> >> the "Go" button. Nothing happens. Trying to press "Go" again shows
"Please
<br>> >> wait. Operation is still in progress." It looks like reading the
wsdl will
<br>> >> last forever. The URL is valid and reachable and with WTP 1.0
it is
<br>> >> working.</blockquote>
</html>
--------------62D321D50C57F1161FDEDAF5--
Current Time: Fri Apr 19 23:00:30 GMT 2024
Powered by FUDForum. Page generated in 0.03727 seconds
