Library in dynamic web application [message #173092] |
Wed, 05 July 2006 14:08 |
Originally posted by: tei.silbergrau.com
I am developing a web application that is based on other java projects
that hold some base classes. Additionally these base projects depend on a
Library that is installed as plugin in eclipse and provides JAR's as a
Library in the classpath of the base project.
How can I add this library to the classpath of the web application? Though
the base project exports the library and is included as a J2EE Module
Dependency the library is not loaded when I start the application.
Re: Library in dynamic web application [message #173296 is a reply to message #173194] |
Thu, 06 July 2006 10:01 |
Thanks for your anwser. This would be a workaround to solve my problem.
Will it be possible to include libraries in the future? Is there a feature
request in the bug database?
cheers
tOM
Re: Library in dynamic web application [message #173321 is a reply to message #173194] |
Thu, 06 July 2006 12:08 |
Originally posted by: gene.rockhoppertech.com
You cannot add a library and that stinks.
If you add a variable it will barf.
It only works if you add a jar directly. That stinks too.
3.2 callisto
Larry Isaacs wrote:
> In J2EE Module Dependencies, you can use the "Add External JARs..."
> button to include these kind of JARs in your web application. This
> would involve specifying the full path to the JARs in the plug-in. You
> could also use the "Add Variable..." button and define a variable that
> covers most of the path to the plug-in. Then reference the JAR from
> that variable.
> Cheers,
> Larry
>> on a Library that is installed as plugin in eclipse and provides JAR's
>> as a Library in the classpath of the base project.
>> Though the base project exports the library and is included as a J2EE
>> Module Dependency the library is not loaded when I start the application.
FUDForum. Page generated in 0.03557 seconds
