Re: [Xbase] getting the result type of an expression during inferring [message #1178440 is a reply to message #1132609] |
Sat, 09 November 2013 17:07 |
Hi, I'm experiencing a similar issue.
I have a grammar for defining objects with it properties and messages (those are features), then it gets into java through the jvm model inferrer.
When the property type is declared explicitly everything seems right. When it should be inferred by the initialization value it breaks.
Grammar:
Feature:
Property | Message;
Property:
name=ValidID (':' type=JvmTypeReference)? ('startsWith' value=XExpression)?;
The Inferrer includes:
def dispatch void infer(HoopeObject element, IJvmDeclaredTypeAcceptor acceptor, boolean isPrelinkingPhase) {
acceptor.accept(jvmGenericType).initializeLater [
documentation = element.documentation
for (feature : element.features) {
switch feature {
Property: {
val type = feature.type?: feature.value.inferredType
members += feature.toField(feature.name, type) [
initializer = feature.value
members += feature.toGetter(feature.name, type)
members += feature.toSetter(feature.name, type)
This works perfectly...
val pepita = object {
energia : double startsWith 2.0
but when I try to let the inferrer infer the type of Property initial value:
energia startsWith 2.0
Bang!
WrappedException: java.lang.UnsupportedOperationException: TODO:
import a functional handle on the type resolution that delegates
to the best available (current, but evolving) result (see logs
for details)
This gets to console:
!STACK 0
java.lang.UnsupportedOperationException: TODO: import a functional handle on the type resolution that delegates to the best available (current, but evolving) result
at org.eclipse.xtext.xbase.typesystem.internal.DefaultReentrantTypeResolver.reentrantResolve(DefaultReentrantTypeResolver.java:141)
at org.eclipse.xtext.xbase.typesystem.internal.DefaultBatchTypeResolver$1.reentrantResolve(DefaultBatchTypeResolver.java:122)
at org.eclipse.xtext.xbase.typesystem.internal.CompoundReentrantTypeResolver.getDelegate(CompoundReentrantTypeResolver.java:79)
at org.eclipse.xtext.xbase.typesystem.internal.CompoundReentrantTypeResolver.getDelegate(CompoundReentrantTypeResolver.java:114)
at org.eclipse.xtext.xbase.typesystem.internal.CompoundReentrantTypeResolver.getActualType(CompoundReentrantTypeResolver.java:106)
at org.eclipse.xtext.xbase.typesystem.internal.ForwardingResolvedTypes.getActualType(ForwardingResolvedTypes.java:39)
at org.eclipse.xtext.xbase.typesystem.InferredTypeIndicator.getTypeReference(InferredTypeIndicator.java:78)
at org.eclipse.xtext.xtype.impl.XComputedTypeReferenceImplCustom.getEquivalent(XComputedTypeReferenceImplCustom.java:46)
at org.eclipse.xtext.common.types.impl.JvmSpecializedTypeReferenceImplCustom.getType(JvmSpecializedTypeReferenceImplCustom.java:23)
at org.eclipse.xtext.xbase.scoping.batch.BucketedEObjectDescription.computeShadowingKey(BucketedEObjectDescription.java:79)
at org.eclipse.xtext.xbase.scoping.batch.BucketedEObjectDescription.getShadowingKey(BucketedEObjectDescription.java:62)
at org.eclipse.xtext.xbase.scoping.batch.AbstractSessionBasedScope.getShadowingKey(AbstractSessionBasedScope.java:169)
at org.eclipse.xtext.xbase.scoping.batch.AbstractSessionBasedScope.isShadowed(AbstractSessionBasedScope.java:179)
at org.eclipse.xtext.scoping.impl.AbstractScope$ParentIterable.apply(AbstractScope.java:67)
at org.eclipse.xtext.scoping.impl.AbstractScope$ParentIterable.apply(AbstractScope.java:1)
at com.google.common.collect.Iterators$7.computeNext(Iterators.java:645)
at com.google.common.collect.AbstractIterator.tryToComputeNext(AbstractIterator.java:141)
at com.google.common.collect.AbstractIterator.hasNext(AbstractIterator.java:136)
at com.google.common.collect.Iterators$5.hasNext(Iterators.java:539)
at org.eclipse.xtext.xbase.typesystem.internal.AbstractTypeComputationState.getLinkingCandidates(AbstractTypeComputationState.java:346)
at org.eclipse.xtext.xbase.typesystem.computation.XbaseTypeComputer._computeTypes(XbaseTypeComputer.java:848)
at org.uqbar.HoopeTypeComputer.computeTypes(HoopeTypeComputer.java:70)
at org.eclipse.xtext.xbase.typesystem.internal.AbstractTypeComputationState.doComputeTypes(AbstractTypeComputationState.java:119)
at org.eclipse.xtext.xbase.typesystem.internal.AbstractTypeComputationState.computeTypes(AbstractTypeComputationState.java:108)
at org.eclipse.xtext.xbase.typesystem.computation.XbaseTypeComputer._computeTypes(XbaseTypeComputer.java:292)
at org.uqbar.HoopeTypeComputer.computeTypes(HoopeTypeComputer.java:88)
at org.eclipse.xtext.xbase.typesystem.internal.AbstractRootTypeComputationState.computeTypes(AbstractRootTypeComputationState.java:36)
at org.eclipse.xtext.xbase.typesystem.internal.LogicalContainerAwareReentrantTypeResolver._computeTypes(LogicalContainerAwareReentrantTypeResolver.java:512)
at org.eclipse.xtext.xbase.typesystem.internal.LogicalContainerAwareReentrantTypeResolver.computeTypes(LogicalContainerAwareReentrantTypeResolver.java:422)
at org.eclipse.xtext.xbase.typesystem.internal.LogicalContainerAwareReentrantTypeResolver.computeMemberTypes(LogicalContainerAwareReentrantTypeResolver.java:583)
at org.eclipse.xtext.xbase.typesystem.internal.LogicalContainerAwareReentrantTypeResolver._computeTypes(LogicalContainerAwareReentrantTypeResolver.java:572)
at org.eclipse.xtext.xbase.typesystem.internal.LogicalContainerAwareReentrantTypeResolver.computeTypes(LogicalContainerAwareReentrantTypeResolver.java:416)
at org.eclipse.xtext.xbase.typesystem.internal.LogicalContainerAwareReentrantTypeResolver.computeTypes(LogicalContainerAwareReentrantTypeResolver.java:411)
at org.eclipse.xtext.xbase.typesystem.internal.DefaultReentrantTypeResolver.resolve(DefaultReentrantTypeResolver.java:160)
at org.eclipse.xtext.xbase.typesystem.internal.DefaultReentrantTypeResolver.reentrantResolve(DefaultReentrantTypeResolver.java:147)
at org.eclipse.xtext.xbase.compiler.ErrorSafeExtensions.serializeSafely(ErrorSafeExtensions.java:210)
at org.eclipse.xtext.xbase.compiler.JvmModelGenerator.generateParameter(JvmModelGenerator.java:1066)
at org.eclipse.xtext.xbase.compiler.JvmModelGenerator.generateParameters(JvmModelGenerator.java:1038)
at org.eclipse.xtext.xbase.compiler.JvmModelGenerator._generateMember(JvmModelGenerator.java:857)
at org.eclipse.xtext.xbase.compiler.JvmModelGenerator.generateMember(JvmModelGenerator.java:1880)
at org.eclipse.xtext.xbase.compiler.JvmModelGenerator$2.apply(JvmModelGenerator.java:288)
at org.eclipse.xtext.xbase.compiler.JvmModelGenerator$2.apply(JvmModelGenerator.java:1)
at org.eclipse.xtext.xbase.lib.ObjectExtensions.operator_doubleArrow(ObjectExtensions.java:139)
at org.eclipse.xtext.xbase.compiler.LoopExtensions$1.apply(LoopExtensions.java:39)
at org.eclipse.xtext.xbase.lib.IterableExtensions.forEach(IterableExtensions.java:399)
at org.eclipse.xtext.xbase.compiler.LoopExtensions.forEach(LoopExtensions.java:42)
at org.eclipse.xtext.xbase.compiler.JvmModelGenerator._generateBody(JvmModelGenerator.java:292)
at org.eclipse.xtext.xbase.compiler.JvmModelGenerator.generateBody(JvmModelGenerator.java:1852)
at org.eclipse.xtext.xbase.compiler.JvmModelGenerator.generateType(JvmModelGenerator.java:211)
at org.eclipse.xtext.xbase.compiler.JvmModelGenerator._internalDoGenerate(JvmModelGenerator.java:202)
at org.eclipse.xtext.xbase.compiler.JvmModelGenerator.internalDoGenerate(JvmModelGenerator.java:1835)
at org.eclipse.xtext.xbase.compiler.JvmModelGenerator.doGenerate(JvmModelGenerator.java:183)
at org.eclipse.xtext.builder.BuilderParticipant.handleChangedContents(BuilderParticipant.java:299)
at org.eclipse.xtext.builder.BuilderParticipant.build(BuilderParticipant.java:229)
at org.eclipse.xtext.builder.impl.RegistryBuilderParticipant.build(RegistryBuilderParticipant.java:60)
at org.eclipse.xtext.builder.impl.XtextBuilder.doBuild(XtextBuilder.java:186)
at org.eclipse.xtext.builder.impl.XtextBuilder.incrementalBuild(XtextBuilder.java:162)
at org.eclipse.xtext.builder.impl.XtextBuilder.build(XtextBuilder.java:95)
at org.eclipse.core.internal.events.BuildManager$2.run(BuildManager.java:726)
at org.eclipse.core.internal.events.BuildManager.basicBuild(BuildManager.java:199)
at org.eclipse.core.internal.events.BuildManager.basicBuild(BuildManager.java:239)
at org.eclipse.core.internal.events.BuildManager$1.run(BuildManager.java:292)
at org.eclipse.core.internal.events.BuildManager.basicBuild(BuildManager.java:295)
at org.eclipse.core.internal.events.BuildManager.basicBuildLoop(BuildManager.java:351)
at org.eclipse.core.internal.events.BuildManager.build(BuildManager.java:374)
at org.eclipse.core.internal.events.AutoBuildJob.doBuild(AutoBuildJob.java:143)
at org.eclipse.core.internal.events.AutoBuildJob.run(AutoBuildJob.java:241)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:53)
It's running on Eclipse 4.3 and Xtext 2.4.2.
Any clue? Sinc domain model examples using jvminferrer have mandatory type declaration, perhaps this feature is not available.
Thanks in advance and best regards!
Miguel
Re: [Xbase] getting the result type of an expression during inferring [message #1178558 is a reply to message #1178552] |
Sat, 09 November 2013 18:55 |
I've tried this:
Property: {
val type = feature.type?: inferredType
members += feature.toObservedSetter(feature.name, type)
And get the following Exception:
org.eclipse.emf.common.util.WrappedException: java.lang.IllegalStateException: equivalent could not be computed
at org.eclipse.xtext.util.OnChangeEvictingCache.execWithoutCacheClear(OnChangeEvictingCache.java:129)
at org.eclipse.xtext.xbase.typesystem.internal.CachingBatchTypeResolver.resolveTypes(CachingBatchTypeResolver.java:58)
at org.eclipse.xtext.xbase.resource.BatchLinkingService.resolveBatched(BatchLinkingService.java:45)
at org.eclipse.xtext.xbase.resource.BatchLinkableResource.resolveLazyCrossReferences(BatchLinkableResource.java:142)
at org.eclipse.xtext.EcoreUtil2.resolveLazyCrossReferences(EcoreUtil2.java:511)
at org.eclipse.xtext.validation.ResourceValidatorImpl.resolveProxies(ResourceValidatorImpl.java:155)
at org.eclipse.xtext.validation.ResourceValidatorImpl.validate(ResourceValidatorImpl.java:68)
at org.eclipse.xtext.ui.validation.DefaultResourceUIValidatorExtension.addMarkers(DefaultResourceUIValidatorExtension.java:60)
at org.eclipse.xtext.ui.validation.DefaultResourceUIValidatorExtension.updateValidationMarkers(DefaultResourceUIValidatorExtension.java:45)
at org.eclipse.xtext.builder.builderState.MarkerUpdaterImpl.processDelta(MarkerUpdaterImpl.java:74)
at org.eclipse.xtext.builder.builderState.MarkerUpdaterImpl.updateMarkers(MarkerUpdaterImpl.java:59)
at org.eclipse.xtext.builder.builderState.AbstractBuilderState.updateMarkers(AbstractBuilderState.java:80)
at org.eclipse.xtext.builder.clustering.ClusteringBuilderState.doUpdate(ClusteringBuilderState.java:266)
at org.eclipse.xtext.builder.builderState.AbstractBuilderState.update(AbstractBuilderState.java:111)
at org.eclipse.xtext.builder.impl.XtextBuilder.doBuild(XtextBuilder.java:184)
at org.eclipse.xtext.builder.impl.XtextBuilder.fullBuild(XtextBuilder.java:210)
at org.eclipse.xtext.builder.impl.XtextBuilder.build(XtextBuilder.java:89)
at org.eclipse.core.internal.events.BuildManager$2.run(BuildManager.java:733)
at org.eclipse.core.internal.events.BuildManager.basicBuild(BuildManager.java:206)
at org.eclipse.core.internal.events.BuildManager.basicBuild(BuildManager.java:246)
at org.eclipse.core.internal.events.BuildManager$1.run(BuildManager.java:299)
at org.eclipse.core.internal.events.BuildManager.basicBuild(BuildManager.java:302)
at org.eclipse.core.internal.events.BuildManager.basicBuildLoop(BuildManager.java:358)
at org.eclipse.core.internal.events.BuildManager.build(BuildManager.java:381)
Caused by: java.lang.IllegalStateException: equivalent could not be computed
at org.eclipse.xtext.xbase.typesystem.InferredTypeIndicator.getTypeReference(InferredTypeIndicator.java:84)
at org.eclipse.xtext.xbase.typesystem.computation.XbaseTypeComputer._computeTypes(XbaseTypeComputer.java:859)
at org.eclipse.xtext.xbase.typesystem.computation.XbaseTypeComputer._computeTypes(XbaseTypeComputer.java:293)
at org.eclipse.xtext.xbase.typesystem.internal.DefaultReentrantTypeResolver.resolve(DefaultReentrantTypeResolver.java:210)
at org.eclipse.xtext.xbase.typesystem.internal.DefaultReentrantTypeResolver.reentrantResolve(DefaultReentrantTypeResolver.java:197)
at org.eclipse.xtext.xbase.typesystem.internal.CompoundReentrantTypeResolver.reentrantResolve(CompoundReentrantTypeResolver.java:65)
at org.eclipse.xtext.xbase.typesystem.internal.CachingBatchTypeResolver$LazyResolvedTypes.delegate(CachingBatchTypeResolver.java:114)
at org.eclipse.xtext.xbase.typesystem.internal.CachingBatchTypeResolver$2.process(CachingBatchTypeResolver.java:61)
at org.eclipse.xtext.xbase.typesystem.internal.CachingBatchTypeResolver$2.process(CachingBatchTypeResolver.java:1)
at org.eclipse.xtext.util.concurrent.IUnitOfWork$Void.exec(IUnitOfWork.java:36)
at org.eclipse.xtext.util.OnChangeEvictingCache.execWithoutCacheClear(OnChangeEvictingCache.java:127)
... 28 more
FUDForum. Page generated in 0.04324 seconds
