Tomcat Server oroblem with Eclipse [message #173002] |
Wed, 05 July 2006 11:45 |
Originally posted by: fleming.rhrk.uni-kl.de
Hello everyone,
I want to know how to bind an existing Tomcat Server Configuration in
Eclipse with Eclipse webtools.At the moment Eclipse creates his own
server.xml file without using the one I have already configured. How can I
use my own configuration of Tomcat with Eclipse webtools.
Thank you for help.
Re: Tomcat Server oroblem with Eclipse [message #173033 is a reply to message #173002] |
Wed, 05 July 2006 12:06 |
Originally posted by: gene.rockhoppertech.com
Marc Fleming wrote:
> Hello everyone,
> I use my own configuration of Tomcat with Eclipse webtools.
> Thank you for help.
The easiest solution: You could copy your elements into the eclipse
generated server.xml
what are your custom elements though? Perhaps a context.xml would be a
better solution.
Re: Tomcat Server oroblem with Eclipse [message #173110 is a reply to message #173002] |
Wed, 05 July 2006 14:47 |
Larry Isaacs Messages: 1354 Registered: July 2009 |
When you create a Tomcat server, it will "import" the server.xml file,
and others, that exist at that time, leaving out and Context elements it
may contain. It leaves out the contexts because it defaults to running
with a separate catalina.base to avoid altering your Tomcat
installation. You can change this by double clicking on the Tomcat
server in the Servers view and unchecking the "Run modules directly from
the workspace" setting. This will cause the server to be run with the
catalina.base set to your Tomcat installation. However, at this point
Eclipse WTP now "owns" your installation. The imported server.xml file
found under the Servers project in your workspace, along with the
others, will overwrite the ones in your installation every time you
start the server.
With "Run modules..." checked or unchecked, it is the server.xml under
the Servers project that controls the Tomcat configuration. You should
be able to make any needed modifications to define your configuration.
Larry
Marc Fleming wrote:
> Hello everyone,
> Thank you for help.
Re: Tomcat Server problem with Eclipse [message #173150 is a reply to message #173110] |
Wed, 05 July 2006 16:15 |
Hello I succeeded to start the right server now. Thank you for this help.
But I also want to be able to use JUDDI (an implementation of UDDI) out of
Eclipse. JUDDI must be able to locate my database. This works when I start
Tomcat from the command line because Tomcat then knows where to find the
web.xml and juddi.properties file of juddi WEB-Application. But when I
start the Server from Eclipse JUDDI doesn`t have database access. I
supose this is because Eclipse doesn't know where to search for JUDDI
application and its configuration files web.xml and juddi.properties. How
can I integrate these ones together whith JUDDI in Eclise. Eclipse only
knows the web.xml of my new project which has to use JUDDI.
Thank you for help
Re: Tomcat Server problem with Eclipse [message #173264 is a reply to message #173033] |
Thu, 06 July 2006 07:38 |
Hello again. I have located the problem.I now have remarked that when
start Tomcat from command line JUDDI also doesn`t get a connection to the
datababase. This is because Eclipse overwrites my original server.xml and
deletes the following Context tag from the original server.xml.The Context
tag is the following:
<Context path="/juddi" docBase="juddi" debug="5" reloadable="true"
crossContext="true">
<ResourceLink name="jdbc/postgres" global="jdbc/postgres"
type="javax.sql.DataSource"/>
<Logger className="org.apache.catalina.logger.FileLogger"
prefix="localhost_juddiDB_log" suffix=".txt" timestamp="true"/>
</Context>
I then tried to add this Context tag to the server.xml file of Eclipse and
tried to restart the server out of Eclipse. I got the following server
Error message from Eclipse:
Could not find a client that is able to launch the selection.
What does this mean? What should I do? I also tried your suggestion to
add an external web module. But this didn't work. Perhaps I have entered
the wrong docBase and path parameter. What should I enter there. For both
parameters I entered the home directory of JUDDI. I tried before I
modified the server.xml.
Thank you for help.
Marc
Re: Tomcat Server problem with Eclipse [message #173328 is a reply to message #173264] |
Thu, 06 July 2006 12:17 |
> the datababase. This is because Eclipse overwrites my original
> server.xml and deletes the following Context tag from the original
> server.xml.The Context tag is the following:
> </Context>
> and tried to restart the server out of Eclipse. I got the following
> server Error message from Eclipse:
> both parameters I entered the home directory of JUDDI. I tried before I
> Thank you for help.
> Cheers,
> Marc
You'd think that creating a META-INF/context.xml would work - as it
should - and as the tomcat docs suggest - but it doesn't with wtp.
As a kludge create a tomcatdir/conf/context.xml with the context element
you provided above.
FUDForum. Page generated in 0.03827 seconds
