Home » Modeling » EMF » Have @Ecore and @GenModel disappeared from Xcore?
Re: Have @Ecore and @GenModel disappeared from Xcore? [message #1129202 is a reply to message #1129180] |
Tue, 08 October 2013 11:49 |
Ed Merks Messages: 33140 Registered: July 2009 |
Istvan,
Comments below.
On 08/10/2013 1:17 PM, Istvan Rath wrote:
> Hi all,
> the Xcore tutorial still contains references to @Ecore and @GenModel
> annotations, see e.g.
> http://wiki.eclipse.org/Xcore#Converting_a_GenModel_to_an_Xcore_Model
> After an upgrade to Kepler SR1,
Upgrading from which version? During the Kepler release XcoreLang.xcore
was moved from org.eclipse.emf.ecore.xcore to
org.eclipse.emf.ecore.xcore.lib...
> I am getting the following errors on these annotations: "Couldn't
> resolve reference to XAnnotationDirective 'Ecore'. ". Additionally,
> when I open such files, a pop-up dialog appears, signaling the following:
> An internal error occurred during: "Xtext validation".
> No GenPackage found for
> mailto:org.eclipse.emf.ecore.impl.EPackageImpl@2dba51e6 (eProxyURI:
> platform:/resource/mypackage/model/mymodel.xcore#/EPackage)
> Is this a bug (should I file a bugzilla), or am I missing something?
It's hard to say, but it might be necessary to clean all projects to
rebuild the whole index. And personally I've had problems in general
with runtime workspaces that stop working when I update the bundle
versions in my workspace on which the runtime workspace depends. In
those cases I create a new workspace and import (with copying) all the
projects is the workspace that stopped working...
> thanks
> Istvan
Ed Merks
Re: Have @Ecore and @GenModel disappeared from Xcore? [message #1129359 is a reply to message #1129230] |
Tue, 08 October 2013 14:54 |
Ed Willink Messages: 7655 Registered: July 2009 |
There are all sorts of hard bugs for unusual increments; changing GIT
branches so that you have backwards time changes is particularly
troublesome and sometimes files aren't even refreshed. So this kind of
bug can be platform or GIT or JDT or project-specific builder. Always
safest to do at least a Clean All after a non-trivial change.
Ed Willink
On 08/10/2013 13:26, Ed Merks wrote:
> Istvan,
> I suppose it's an Xtext bug, but I'm not sure. Clearly if some bundle
> contributes resource description infrastructure that is used by Xtext
> to build an index and that bundle changes versions, the index it built
> might no longer be accurate with respect to the expectations of the
> new version. Perhaps Xtext should be checking for the versions on
> startup to know if reindexing is necessary...
> On 08/10/2013 2:12 PM, Istvan Rath wrote:
>> Hi Ed,
>> Quote:
>>> the projects is the workspace that stopped working...
>> it indeed seems to be a workspace-specific problem. I moved my
>> projects to a new workspace and the problem went away. Thanks!
>> The question is then, which component has the bug? Ie. where is the
>> cache that should be cleaned and rebuilt properly, but isn't?
Re: Have @Ecore and @GenModel disappeared from Xcore? [message #1129962 is a reply to message #1129359] |
Wed, 09 October 2013 05:23 |
Ed,
Well, there's a difference between what you do in your development
workspace and how that impacts your runtime workspace. I've had
situations (just yesterday in fact) where the runtime workspace just
won't launch, so no opportunity to do refreshing or cleaning. That's
quite annoying and for less expert users, they might not consider to
create a new workspace and import all their old projects into the new
one, which is easy only if all the projects are physically nested in the
workspace, not if they're linked...
On 08/10/2013 4:54 PM, Ed Willink wrote:
> Hi
> Regards
> Ed Willink
>> Istvan,
>> bundle contributes resource description infrastructure that is used
>> by Xtext to build an index and that bundle changes versions, the
>> index it built might no longer be accurate with respect to the
>> expectations of the new version. Perhaps Xtext should be checking
>> for the versions on startup to know if reindexing is necessary...
>>> Hi Ed,
>>> Quote:
>>>> to rebuild the whole index. And personally I've had problems in
>>>> general with runtime workspaces that stop working when I update the
>>>> bundle versions in my workspace on which the runtime workspace
>>>> depends. In those cases I create a new workspace and import (with
>>>> copying) all the projects is the workspace that stopped working...
Ed Merks
Re: Have @Ecore and @GenModel disappeared from Xcore? [message #1129985 is a reply to message #1129962] |
Wed, 09 October 2013 05:53 |
Istvan Rath Messages: 59 Registered: July 2009 |
Member |
In my situation, even cleaning the workspace (which was not a runtime workspace, but my regular development workspace) didn't help. I also tried switching compiler compliance levels back and forth to trigger a complete rebuild - no result. So the only solution was to move stuff to a new workspace.
I entirely agree with Ed (Merks) that this is a major annoyance, especially when working with Git where the best practice is (used to be) to maintain a single local repository clone and link projects to your various workspaces from there. For novice users (as I have seen with my students), such issues are especially daunting since the way they manifest (i.e. cryptic error messages, validation errors etc) do not hint at how the issue should be resolved.
I asked about triggering the Xtext indexer in the TMF forum. Let's see if the guys there can help.
Current Time: Tue Apr 23 09:20:11 GMT 2024
Powered by FUDForum. Page generated in 0.04452 seconds
