Home » Newcomers » Newcomers » Installed the standard version of eclipse, Do I have to install jre else?(standard, jre,)
Re: Installed the standard version of eclipse, Do I have to install jre else? [message #1128300 is a reply to message #1128103] |
Mon, 07 October 2013 14:55 |
Zhg Mising name Messages: 81 Registered: March 2011 |
Member |
Ed Merks wrote on Mon, 07 October 2013 06:40You need a JRE to run Eclipse itself. Can you run your installation
yet; if not, see the stick post for this forum.
On 07/10/2013 12:31 PM, Zhg Mising name wrote:
> I have installed the standard version of eclipse, Do I have to install
> jre else for developing java?
> or say, does standard version involve jre?
> or can standard version do all what jre can do ?
In the past I used it with jre, but now I nearly forget them all. all is stating from beginning.
at my new machine, I haven't yet installed jre, but it seems no problem to vist java pages and files.
why?
Re: Installed the standard version of eclipse, Do I have to install jre else? [message #1128316 is a reply to message #1128300] |
Mon, 07 October 2013 15:10 |
Ed Merks Messages: 33140 Registered: July 2009 |
If Eclipse starts, there's definitely a JRE installed and available.
Within the IDE itself you might want to use a specific one which you'd
configure in your Java -> Installed JREs preference.
>> install > jre else for developing java?
> why?
Ed Merks
Re: Installed the standard version of eclipse, Do I have to install jre else? [message #1128378 is a reply to message #1128339] |
Mon, 07 October 2013 16:21 |
Member |
Ed Merks wrote on Mon, 07 October 2013 11:34Comments below.
On 07/10/2013 5:26 PM, Zhg Mising name wrote:
> as the file does not install,
What file?
> just extend to a certain fold.
I'm not sure what you're trying to say.
> so I han't yet found any problem.
Sounds fine then.
> but when run it, it shows that the jre is lack.
How does it show that?
> or need jdk.
I find that I always want to configure a JDK with source so I can debug
into the JRE code easily.
> now the question is why the standard version does not include jdk?
Because the JDKs are licensed by their providers with their own specific
rules about how they are distributed. So you'll have to get one from an
appropriate source and use it.
the elipse does not need install like other software did, just depress to some folder.
it shows need jre or jdk.
does ide for java develper include jdk?
or can I install ide for java developer without standard version?
[Updated on: Mon, 07 October 2013 16:33] Report message to a moderator
Re: Installed the standard version of eclipse, Do I have to install jre else? [message #1129100 is a reply to message #1128378] |
Tue, 08 October 2013 09:33 |
I can't parse statements nor your questions... In any case, you need at
JRE to run Eclipse itself, you also need a JRE if you're going to use
Eclipse to develop Java applications (it could be a different one), and
no package comes with a JRE so you have to just get that yourself.
>> Comments below.
>> What file?
>> Sounds fine then.
>> > or need jdk.
>> debug into the JRE code easily.
>> specific rules about how they are distributed. So you'll have to get
>> one from an appropriate source and use it.
> to some folder.
> or do I have to install ide for java developer without standard version?
Ed Merks
Current Time: Wed Apr 24 14:16:03 GMT 2024
Powered by FUDForum. Page generated in 0.09150 seconds
