Application running twice, once again [message #172352] |
Sat, 24 June 2006 19:29 |
Originally posted by: pecanov.mt.net.mk
I've been absent from the forums for quite a while, since I switched to
MyEclipse.
The reason for this was an annoying problem of WTP. The web application
was starting twice, and the probable cause was the structure of it.
After some debating, it was concluded that a context.xml in META-INF was
causing the problems.
However, 6 months later the context.xml is gone, 1.5 WTP is here ... and
the problem is still present.
Is this a problem for someone else at the moment (there were quite a few
people experiencing this with WTP 1.0).
Has a bug been filed?
Should it be?
Thank you
Re: Application running twice, once again [message #172391 is a reply to message #172383] |
Mon, 26 June 2006 06:33 |
Seem like the correct symptoms, except the deployment to "webapps" in
Tomcat.
Thanks, it's most probably what I was looking for.
On Sun, 2006-06-25 at 12:47 -0400, Larry Isaacs wrote:
> Perhaps this one accounts for what you are seeing:
> https://bugs.eclipse.org/bugs/show_bug.cgi?id=125364
> Cheers,
> Larry
> > MyEclipse.
> > Should it be?
> > Thank you
FUDForum. Page generated in 0.03242 seconds
