Home » Language IDEs » ServerTools (WTP) » WTP and Tomcat 3.3
WTP and Tomcat 3.3 [message #172016] Thu, 22 June 2006 10:27 Go to next message
Originally posted by: darknight74.email.it
Hi all.
I'd like to use Tomcat 3.3 and WTP to debug a webapp i developed (in
production we still use tomcat 3.3)
I noticed that WTP doesn't have a profile for Tomcat 3.3 so i tried to
use the profile for 3.2 but the recognition fails when i select the
tomcat 3.3 installation directory.
How can i setup WTP to use tomcat 3.3?
There's a server profile around for tomcat 3.3? (I treid to search it on
google but i found nothing).
Thanks in advance
Andrea Fabris
Re: WTP and Tomcat 3.3 [message #172055 is a reply to message #172016] Thu, 22 June 2006 13:32 Go to previous message
Larry Isaacs is currently offline Larry IsaacsFriend
This is something I started on a long time ago but ran some difficulties
supporting Tomcat 3.3's differences without making some non-trivial
changes in the existing Tomcat plug-in code. So far, demands of my day
job hasn't left enough time to come back to this. It should be possible
to make a number of improvements to the Tomcat support in the WTP 2.0
time frame. If can make it simple enough to add in Tomcat 3.3 support,
I'll do so. However, there are many possible improvements that could be
made. If ranked by how likely it will be used, Tomcat 3.3 probably
wouldn't rank very high. This is why it hasn't been treated as a high
priority.
If you are willing to dig into the Generic Server support, it should be
possible to create a Tomcat 3.3 Generic Server plug-in that you could
use. If not, a hackish alternative is to create a supported Tomcat
server and publish the project to that server to assemble an image of
the Web application. Then create a context in Tomcat 3.3 that will
serve that image.
Larry
Andrea Fabris wrote:
> Hi all.
> Thanks in advance
> Andrea Fabris
Previous Topic:.NET dataset deserialization
Next Topic:CreateServletTemplateModel cannot be resolved
Current Time: Tue Apr 16 04:57:03 GMT 2024
Powered by FUDForum. Page generated in 0.44457 seconds
