getStereotype() always return "invariant" [message #1125521] |
Fri, 04 October 2013 16:00 |
John Guerson Messages: 51 Registered: August 2011 |
Member |
From what I have tested (kepler and the OCL 4.2.0 build) the method PivotUtil.getStereotype(constraint) is always returning "invariant".
OCL Document:
context RoadTrafficAccident::fatalvictims:Integer
derive: self.victims->select(d|d.oclIsKindOf(DeceasedPerson))->size()
getStereotype():
public static String getStereotype(@NonNull Constraint object)
EStructuralFeature eContainingFeature = object.eContainingFeature();
System.out.println(eContainingFeature);
if (eContainingFeature == PivotPackage.Literals.TYPE__OWNED_INVARIANT) return UMLReflection.INVARIANT;
else if (eContainingFeature == PivotPackage.Literals.PROPERTY__DEFAULT_EXPRESSION) return UMLReflection.DERIVATION;
Constraint.toString():
context fatalvictims : ecore::EInt invariant: self.victims->select(d : EA_Model::Victim[?] | d.oclIsKindOf(EA_Model::DeceasedPerson))->size()
eContainingFeature:
org.eclipse.emf.ecore.impl.EReferenceImpl@244d9d89 (name: ownedInvariant) (ordered: false, unique: true, lowerBound: 0, upperBound: -1)
(changeable: true, volatile: false, transient: false, defaultValueLiteral: null, unsettable: false, derived: false) (containment: true, resolveProxies: false)
Someone already came across with that?
John
Re: getStereotype() always return "invariant" [message #1125533 is a reply to message #1125521] |
Fri, 04 October 2013 16:13 |
Ed Willink Messages: 7655 Registered: July 2009 |
I am sorry, but I do not have time to try to turn your hints into a
repro. If you want help you need to provide a small zipped project.
Ed Willink
On 04/10/2013 12:00, John Guerson wrote:
> OCL Document:
> getStereotype():
> public static String getStereotype(@NonNull Constraint object) {
> eContainingFeature:
> upperBound: -1) (changeable: true, volatile: false, transient: false,
> Regards,
> John
Re: getStereotype() always return "invariant" [message #1129443 is a reply to message #1125533] |
Tue, 08 October 2013 16:28 |
Hi John
We were both equally confused by "getStereotype()".
In UML 1.x there was a Constraint::stereotype feature to distinguish
kinds of constraints. OCL 2.x has yet to properly align with UML 2.x and
so the OCL specification uses it and implementations have corresponding
'support'.
So "getStereotype" is getting the constraint kind:
<<invariant>>/<<postcondition>>/... etc
Needless to say this usage is being phased out. I hope that it only
exists as a kind of compatibility and for some diagnostics such as text
in the Outline View.
Ed Willink
On 04/10/2013 17:13, Ed Willink wrote:
> Hi
> Regards
> Ed Willink
>> Hi,
>> OCL Document:
>> getStereotype():
>> eContainingFeature:
>> Regards,
>> John
FUDForum. Page generated in 0.02882 seconds
