Home » Modeling » Graphiti » hide PaletteCompartmentEntry object
hide PaletteCompartmentEntry object [message #1121235] Mon, 30 September 2013 12:05 Go to next message
Mithu Deb is currently offline Mithu DebFriend
How do i hide PaletteCompartmentEntry object
(org.eclipse.graphiti.palette.impl.PaletteCompartmentEntry)
so that it is not visible to the user
Re: hide PaletteCompartmentEntry object [message #1125373 is a reply to message #1121235] Fri, 04 October 2013 12:50 Go to previous messageGo to next message
Michael Wenz is currently offline Michael WenzFriend
Mithu,
Graphiti currently only allows to hide the complete palette, not individual
groups. This sounds as if you would need to create your own palette using
GEF means in DefaultPaletteBehavior. Subclassing and exchanging paletteRoot
should give you the hook.
Michael
Re: hide PaletteCompartmentEntry object [message #1698383 is a reply to message #1125373] Mon, 15 June 2015 08:38 Go to previous messageGo to next message
Flavio Donze is currently offline Flavio DonzeFriend
Hi Michael,
How would you hide the complete palette?
greets
Flavio
Prozessmanagement und Qualit├Ątsmanagement Software QMS/IMS
https://www.scodi.ch
Re: hide PaletteCompartmentEntry object [message #1698869 is a reply to message #1698383] Thu, 18 June 2015 13:18 Go to previous messageGo to next message
Flavio,
you can override isShowFlyoutPalette() in your tool behavior provider and
return false there to hide the palette.
Michael
Re: hide PaletteCompartmentEntry object [message #1698886 is a reply to message #1698869] Thu, 18 June 2015 14:09 Go to previous message
Hi Michael
Perfect exactly what I was looking for!
Flavio
Previous Topic:Select DiagramEditpart after opening the Diagram to show the propertysheet for the same.
Next Topic:how to import/export model instances
Current Time: Sun Jan 26 17:56:32 GMT 2020
Powered by FUDForum. Page generated in 0.02499 seconds
