BUG : postgresql @NamedStoredProcedureQuery call [message #1120996] |
Mon, 30 September 2013 06:50  |
I created a simple function in postgresql
CREATE OR REPLACE FUNCTION simpletest()
RETURNS bigint AS
$BODY$
BEGIN
return 10;
END;
$BODY$
LANGUAGE plpgsql
when I try to run it with eclipse link I get this exception
ERROR: syntax error at or near ")"
Position: 20
Error Code: 0
Call: EXECUTE simpletest()
Query: DataReadQuery(name="simpletest" )
I assume this is eclipselink bug and this is how I define and run the function.
@NamedStoredProcedureQuery(name="simpletest", procedureName="simpletest")
public class Student
public void exec()
Query createNamedQuery = entityManager.createNamedQuery("simpletest");
System.out.println(createNamedQuery.getResultList());
is this a bug ?
Re: BUG : postgresql @NamedStoredProcedureQuery call [message #1124425 is a reply to message #1121392] |
Thu, 03 October 2013 14:23   |
thank you Chris,
if you mean org.eclipse.persistence.platform.database.PostgreSQLPlatform
yes I have used it as target database and it is "EXECUTE" in getProcedureCallHeader() method not SELECT anyway Do you know why direction is deprecated ?
I have a function with two input arguments and two output arguments which is defined as follow
@NamedStoredProcedureQuery(name = DocumentAccess.CONTAINS_DOC_BY_ANOTHER_OWNER, procedureName = "contains_doc_by_another_owner", parameters = {
@StoredProcedureParameter(queryParameter = "commaSeparatedIds", type = String.class, direction=Direction.IN),
@StoredProcedureParameter(queryParameter = "uid", type = Long.class, direction=Direction.IN),
@StoredProcedureParameter(queryParameter = "has_another_owner", type = Boolean.class, direction= Direction.OUT),
@StoredProcedureParameter(queryParameter = "doc_id", type = Long.class, direction= Direction.OUT)}, resultSetMappings = { DocumentAccess.CONTAINS_DOC_BY_ANOTHER_OWNER }),
but the query is select contains_doc_by_another_owner(?,?) . it should be
select has_another_owner, doc_id from contains_doc_by_another_owner(?,?)
Re: BUG : postgresql @NamedStoredProcedureQuery call [message #1125564 is a reply to message #1124425] |
Fri, 04 October 2013 16:54   |
Looks like 'direction' was deprecated and replaced with 'mode' to be inline with javax.persistence.StoredProcedureParameter from the JPA 2.1 specification.
I'm not sure why it is calling execute instead of select. Please provide the full stack from the error as that might give an indication as to why the wrong code path is being used.
Re: BUG : postgresql @NamedStoredProcedureQuery call [message #1126061 is a reply to message #1125564] |
Sat, 05 October 2013 05:26  |
I had it fixed by extending Postgresql platform
public class PostgresqlPlatform extends PostgreSQLPlatform
public String getProcedureCallHeader()
return "SELECT * FROM ";
public boolean shouldPrintStoredProcedureArgumentNameInCall()
return false;
FUDForum. Page generated in 0.25512 seconds
