Running into NPE errors with WTP RC4 [message #170531] |
Mon, 05 June 2006 08:20 |
Originally posted by: vbansal.tibco.com
I have created an extensibility element ecore model using WSDL.ecore from
org.eclipse.wst.wsdl plugin. Now I am trying to create a genmodel for my
extensibility element ecore model. Since the ExtensiblityElement is
defined inside wsdl.ecore, I need to reference wsdl.genmodel at the time
of my genmodel creation. The problem is when I click on the wsdl.genmodel
from the "New EMF model" dialog, Eclipse throws the following errors. I am
running Eclipse RC7 and EMF 2.2.
Will appreciate your help on this.
Vikram
at
org.eclipse.emf.converter.util.ConverterUtil.computeRequired Packages(ConverterUtil.java:392)
at
org.eclipse.emf.converter.ui.contribution.base.ModelConverte rPackagePage.validate(ModelConverterPackagePage.java:803)
at
org.eclipse.emf.importer.ui.contribution.base.ModelImporterP ackagePage.validate(ModelImporterPackagePage.java:92)
at
org.eclipse.emf.converter.ui.contribution.base.ModelConverte rPackagePage.referencedGenModelsCheckboxTreeViewerCheckState Changed(ModelConverterPackagePage.java:756)
at
org.eclipse.emf.converter.ui.contribution.base.ModelConverte rPackagePage$11.checkStateChanged(ModelConverterPackagePage. java:564)
at
org.eclipse.jface.viewers.CheckboxTreeViewer$1.run(CheckboxT reeViewer.java:133)
Re: Running into NPE errors with WTP RC4 [message #170566 is a reply to message #170531] |
Mon, 05 June 2006 11:19 |
Vikram,
Do you have an EPackage with a null nsURI?
Vikram Bansal wrote:
> from org.eclipse.wst.wsdl plugin. Now I am trying to create a genmodel
> for my extensibility element ecore model. Since the
> ExtensiblityElement is defined inside wsdl.ecore, I need to reference
> wsdl.genmodel at the time of my genmodel creation. The problem is when
> I click on the wsdl.genmodel from the "New EMF model" dialog, Eclipse
> throws the following errors. I am running Eclipse RC7 and EMF 2.2.
> Thanks
> Vikram
> at
> at
> at
> at
> at
> at
Re: Running into NPE errors with WTP RC4 [message #170589 is a reply to message #170566] |
Mon, 05 June 2006 15:17 |
No, I have all three (Name, NsPrefix and Ns URI) correctly entered. The
use case is as follows:
1. create an EMF model project
2. create an ecore model
3. create an EPackage and set Name, NsPrefix and Ns URI
4. create an EClass, give it some name
5. for this class add super class: wsdl.ecore --> ExtensibilityElement
6. save and now create a genmodel for the ecore you just created
7. in the "New Model" dialog you will reference wsdl.genmodel (your
org.eclipse.wst.wsdl must be in the workspace as a binary project prior to
this)
8. browse and pick wsdl.genmodel. The genmodel will be added to the
"referenced genmodels" tree view.
9. Now when click on the wsdl.genmodel, a dialog will show up saying there
were errors. The log shows you all those errors I sent with my last post.
regards
--vikram
Re: Running into NPE errors with WTP RC4 [message #170703 is a reply to message #170589] |
Tue, 06 June 2006 11:53 |
--------------010501040208070403020606
Vikram,
I see you've opened a bugzilla. It looks like the WSDL model is
referencing the XSD model in a bad way. If the WSDL model registered
its GenModel, you'd be able to use "Browse Registered Packages..." to
load the model without importing WSDL into your workspace:
When producing the .genmodel for such a new model that extends/uses
WSDL/XSD, the system would already know where to find the referenced
GenModel for those registered models...
> The use case is as follows:
> 2. create an ecore model 3. create an EPackage and set Name, NsPrefix
> and Ns URI
> prior to this)
> there were errors. The log shows you all those errors I sent with my
> last post.
> regards
> --vikram
Content-Type: multipart/related;
boundary="------------060602040606080708020701"
--------------060602040606080708020701
<html>
<head>
http-equiv="Content-Type">
</head>
Vikram,<br>
<br>
Re: Running into NPE errors with WTP RC4 [message #170756 is a reply to message #170703] |
Wed, 07 June 2006 10:47 |
--------------000304000605080205000700
If I follow the exact same way of loading WSDL model and then try to
click on a class that refers the XSD ecore; here's what I run into:
(screenshot attached). Is it the issue of WSDL ecore not referring the
XSD ecore properly as you are saying?
Anand
Ed Merks wrote:
> Vikram,
>> and Ns URI
>> prior to this)
>> last post.
>> regards
>> --vikram
Content-Type: image/png;
name="wsdl.PNG"
Content-Disposition: inline;
filename="wsdl.PNG"
iVBORw0KGgoAAAANSUhEUgAAA6AAAAHZCAYAAACYd1aRAAAAAXNSR0IArs4c 6QAAAARnQU1B
AACxjwv8YQUAAAAgY0hSTQAAeiYAAICEAAD6AAAAgOgAAHUwAADqYAAAOpgA ABdwnLpRPAAA
RmBJREFUeF7t3QmULVdBLuDrCDiBAzKIgogDBkmIAwpqGniwiAGCC8WlKAmi IkuICwiKTx7c
BEIkQaYAilFQkggREjRMRkxMYhIzkBAxIIkMwadMD3nrIcTIkP123XuPnhS7 au+qc87u6urv
rlXr3ttdp6rOV//ZXX/t091fcsEFF4Q9/hAgQIAAAQIECBAgQIAAgU0LXHvN ZcHCQAZkQAZk
QAZkQAZkQAZkQAZkYNMZ2LPpHdi+EMuADMiADMiADMiADMiADMiADDQZUEDN AJsBlwEZkAEZ
kAEZkAEZkAEZkIEqGVBABa1K0NzxcsdLBmRABmRABmRABmRABmRAAVVAFVAZ kAEZkAEZkAEZ
kAEZkAEZqJIBBVTQqgTN3S53u2RABmRABmRABmRABmRABhRQBVQBlQEZkAEZ kAEZkAEZkAEZ
kIEqGVBABa1K0NztcrdLBmRABmRABmRABmRABmRAAVVAFVAZkAEZkAEZkAEZ kAEZkAEZqJIB
BVTQqgTN3S53u2RABmRABmRABmRABmRABhRQBVQBlQEZkAEZkAEZkAEZkAEZ kIEqGVBABa1K
0NztcrdLBmRABmRABmRABmRABmRAAVVAFVAZkAEZkAEZkAEZkAEZkAEZqJKB jRbQ61/3J+Ff
n/Lk8Imf+5nw6Z98ZPj8kY8IX3j4w8KNR/xE+OSjfjJ85Im/HD7wey8O115x UZUn646LOy4y
IAMyIAMyIAMyIAMysL0ZCP7MSmBra2tQl9tIAf3fz/yNcNOP/Ei4+SEPCeGX fimEY48NYe/e
EJ773BCe9awQnva0EB7/+BAe9ahw82GHhZvuec/wgVhSLz/3nEEHb/DY3sGD P38ZkAEZkAEZ
kAEZkIGhGWja19DHWH+aOdsbO962FtD3n/rycON9fyiEBz84hF/8xRB+67dC eMELQjj11BBO
Pz2E007b/+8XvnB/EX3Sk0L4hV8I4YgjQvjhHw7/9653DZc86QmTCuSePXuS x9P1cS+O4S+O
dVqWbKtkneXzOHT9dT12aJb6jjP1uVWe19BjK1m/OZ5Vj2ld2yg53nWts45j Xtex2M7w8YsZ
MxmQARkYngEFdLjZVHO2rQX0X556TPjCQQeF8IhHhPCrvxrCs58dwktfGsIf /3EIZ5wRwmtf
G8JrXhPCK1+5v4Aef3wIT3/6/nV/9mf3l9D73S+E7/7ucPUP/UC46Py3raWI Li7uxl7kKaCX
rVwKci+YsaUjdW4X2xpaxvpK49jja7a5fDzLx5szWX5sbt2xz3no82qvP/Tx fc9jHdsau43t
fF5jjzmXia7Pb/K5jj0mj5vPRYhz6VzKgAyUZkABnU9Wtq2A/uvj4izmwQeH 8PCHh/ArvxLC
M58Zwsknh/Cyl4XwileE8JKXhHDSSftnPZ/xjP1vwX3KU/bPgDZv0X3MY0J4 5CNDeNCDQvih
OIP6Xd8V3nH3u4U3vfF1K5fQVS+4FNBpFtBVzkvuon/VzKTK7Jht5o6zPcgP Ld2rbn/o43dj
Ac19IV6nYW5fQ25qlGzLOvO5eHAunUsZkIHaGVBA55O5bSmgH/rNp4abm5nP 5vs9m7fTHnNM
CL/92/u/5/O44/bPcj7hCSH89E+HcPjh+9d76EP3z5T+1E+F8DM/s798Np+L 38DavBX3xu/7
vnDj3e4Wzr3bXcPb3vSGlUpo14V/atYoNUOVmmVrX8jlHrdYP3Usi8emXvi5 7ZZsr2sbXSUp
t8/F4/q2u3xcqfWWPfqef+ksTq7wtY+hfXypIrd8XF0ZaD+PoQUr5zTkXJRk su959pksv1a6
XHK56MpB6eOW1+sqUn3nefkx7dd+6nEluS09pr68jz3HXcfcfi20X1+510Lf +u3xpvbFiv3N
52LFuXQuZUAGFND5ZKB6Ab3+9FeFm2JRDPe///7Zz5//+X0zoJ+Ps5r/cdRR +0tnM6t5n/uE
8O3fHsKd7hTCHe8Ywl3uEsJ3fuf+j9/3vuHGH/uxcHP8oUXhB38whO///vDZ e90rfDx+/qN3
vnM45QcODRec99bRJTRV0lKFsG+9voJT8rjUxX3uYq5ku6mL6tSx5i6U2xfk peun1istMn3H
mfvC1GeXKhep4tVVYlIfH3ouUsefOuah7rnn0bW9Ls+hz6tr/XYOhuZnqHnX +S89vlTJWvV1
kzumodZDXlt9r7nSczH2+HKvVZ+fzwWGc+lcyoAMrDMDcyiguWv5dXqtY1ub Ot7qBfSjh94n
fOHe994/c9l8D+eRR4bPPexh4bgnPjHs/bVfC59rSuY3fEMIX/u14bO3ulX4 9y//8vCpr/iK
8Jmv/Mrw+a/6qhC+5mvCp2PJfMLRR4cXNW/D/Y7v2Pf228/F7wP92N3vHm74 1m8N77rd7cLT
j/75cNXlF44qoct3/EvK0dALtvb2UyWgq4DmilTq2EsvFPsu6ku30VeQSo+t dL0hL6ycW0kx
L9lGSbHqyldXWUwVnZIMLR/L8vqp59ouWHMroEOfT+lreuz5LsnS0NfckGPu GteGvPbGHt+Q
1611XbzKgAzIgAwsMpAroO1rne3MTt/1cO64uq7xco8ruY7sujYsvSm+rkJa tYBef+Lx4d+a
Wc1DDgnhR380hB//8XBTnAn9g/i9nee9973hr667Lrwyfo/n/4s/2fLGuHws Lh+Oy0fi8tG4
fCYuH4jLsY9+dPj9t789nHrhheF1zazpHe4QPhtnSj8SZ0mvi3//0+1vH174 dV8X/vCVp4wu
oKmT3HXBVXrh1xXG1EVsrvimApALT+44N11Ax5jmLvBLX4xDLvj7bIcal5iX lqNcSe47f13H
kcp0iVXueZUOvKuUmLGvx1Shz+WsdF85l679pI5prE2JfWp8Gbq/oeuXvlat 52JTBmRABmQg
lYG+Apr7Or1dmVrluFYte0Ou50qvRVc9psV+qhbQGw763vCJe9wjhPj9mvve Sht/CNGr4w8f
OieWz8WfCz70ofCKOBt6w1IB/Zf47080v9okLk+JP/32j84/f9/qX4jLn77n PeFvnvrUcGOc
9fyXb/7m8J5YPt/5jd8YLokzqI874qHhkgvPHVxC110y2heEJRdufQU0VTTW UR7XsY2Si9++
IlVi0z7O0hdD7rz23SAYej7GPI/2i79v0Bq7/VwWu7I1tqDlBt6xz2NM2R5z A2RonnMFtC9j
Yx87xlABdXG3XRdj9it7MiADYzPQVUBLru+adRZL+6Zv++PL6+a23XVNuvz1 fnn7Jdvuu1md
eh591wGp51xyrdfeT9fzWWwrZdi3n2oF9N1vPiu8L85UNm+T/c/4ltnmV6eE WEbf89jHhgs+
+MHwmf+qoCFcFP9/aiyV7z8w89nMhP59XP7nUUeH0y+6aGnNED4b//fBOCP6 0fgW3RtiCb32
678+/N1tbxuujjOgj7vjHcIrX/HijRXQPvRcQEo+n7og7QrS8rpdIUgFuus4 ci/Skgvzvhf0
0BdX2zp1AV0yoKVe+Knn0vXCKznuXDnqGgRTBbRv3dxgmspE+7n2DShdhS23 367z3j6esZkt
OQel+Uh9YenLSOqL1pjz3fUFbXlbfV9Q+rLS5dNl0v5435iQ+kI7ZLwpeY1a x8WpDMiADMhA
KgOrFND21+++r91dX39T20h9XSz5Wt53LVPydTy339TzS13DlH4NL7nubz/v vmudagX0vU87
Jrwnvj32w/Ftsp/6tm8Ln2/eihv/Dk1xjD+M6MoPfzh8eqlaXvHxj4fT4k/G ve7AzOfz469h
ef2VV96ifDb/+WT8HtJmhvRDX/3V4fo463l1/B7Ri+LSlNAXx23/8uOPCu+8 8uLBJdTgZ/CT
ARmQARmQARmQARmQgWlkYBMFtOSmc9fN6lTR7LrRX1oqu0ruYl+p413HtnPb GFNA+1431Qro
ux/xsHBtfHvsDc0saPyptp+KP0joM3H59zhT+X9igXxX/DUr13ziE7eYCX3P Jz8Z3n7CCeGs
E08Ml7z//eHmVv385/hrWd4VH/tP8YcUXRdL5z/EEnpF/EFF58flr+O/z4gF 9IGH/Wg4961v
VECvmcbgYRB3HmRABmRABmRABmRABoZmYBMFNHUMQ2ZA+95Z1jfLuo4Z0Pax lxx3br+5d1/l
9tFVVNvHWq2AXnXIwfu+N/Mf40+4/VD8+2Nx+URcPhKL4w2xRL4vLlcddlh4 V5z5vHGpaDZv
zf33L5r3DOF98Ve1XNEU12aGNBbNf4il8+pb3zpcGpe3x5+e++b495vix+99 928Przr15Qqo
AioDMiADMiADMiADMiADOzQDY38IUa5UtUtZrmTlZgtTM6MljxlaKFPfWrPK tyD1FeYdOwN6
6bfcOVwev0fzmjjjeX1cPhTfIvvPcbmheevsl31ZeM+Bt9pe+cAHhnd/7GPh c4nS2cyA/mdc
PnD44eHSuP47mtL6JV8S3hmL5jtj6bw8/v23cTb0bXE5K/77L+PHvucO3xxe +qKTDDY7dLAZ
enfM+u6oyoAMyIAMyIAMyMD8MjD217Dk3rZa+n2QQwpi6ucrlMyI9r0Ft/02 3JJS235uy4/p
csm9LTnllTPcthnQ82PpbL438/JYOK+Jy3vj8r74PZvXxZnKd8cC2sxk7pvN jMslD31I+PB/
NlXzln+amdGr73e/feXzyrhcHpcr4mOviIWzWS6Oy/nx94aeE5cz47/Pjct3 3O624eTnP1cB
VUBlQAZkQAZkQAZkQAZkYIdmIFdAu2469P0wHDcqtudGRbW34J535zuFv7rN bcJFsXBeEZdr
4nJt/P+1cZbyXbFEXnOgfF4U/z77pJPCx//jP/a1z5tvvnnf0vxpKullp5wS /jauc1lcmiJ6
aZwBvTQWzkua8hm389Yv/dLwhricFv99dpwFvWssvs9/3nEGmx062BgYtmdg 4M5dBmRABmRA
BmRgShlQQOeTx2oF9Px73yu8pfn+zFgKL45L83bZq+JyTfP22VgYm5nP8+Ly vGOOCeddf33i
Dbj7P3T9Zz4TTj/uuPDXzUxpXC6Oy4WxbDbl8y/jdv48Ln8alz+J/391XO58 268LJ514vAKq
gMqADMiADMiADMiADMjADs3A2AI6pRLtWPaX6GoF9KIjjwhnxdnOt8TC+fY4 Y3lRnLG8LC5X
Hnj77V/FIvmbj3tceP2ll3aWz8UnrorfI/ryY48Nb4uPaWZMz4uzoE35PCcu fxb//er496vi
dp8f/77DN31j+N2TTjDY7NDBxgt1Pne7nEvnUgZkQAZkQAZkYGwGFND5ZKda Ab3iN58aXhsL
59mxfL41lsO3x+XCWBavigXy3Lgc8+hHhzMuuOCLyuc773//8I+PfGT4bPxM 8xNxF38uu+GG
8KInPzmcEx/7l3H5i7i8Pm7vtLj8QVxeFcvnr8flLnf5lvCyl5ysgCqgMiAD MiADMiADMiAD
MrBDM6CAKqCDX7x/H38X52mxfL42LmfFYvimWBKbt9H+eVyedvTR4cyLL/7i 8rm1ta9Yvqn5
ns/4Oz8/eOONt/gVLVd+5CPhlKc9LZzZlM+4nB6XU+N2Xxq3f2pcfiT++9D7 HBz+9LQ/Gny8
Y+/OeNx8XhzOpXMpAzIgAzIgAzIgA9PIgAI6jfOwjtdDtRnQ5mDfEH8n52vi zOcZzQ8KimWx
mb383Wc8I5xx5ZXh8636efWRR4az4+ffEpe3Hlj3vCOOCNd96lPhpqV1r73p pnD28ceH18R1
/iguL4ul8yVx+y+Iy+3iv498xBHhgr9+iwK6Q+92rSPktjGfAcu5dC5lQAZk QAZkYHdmoLn8
b4qLZR4GW3Gicchrec+QlZfXff0Je8M5sYA2b49tZiv/LC5nHnxwuOAd7wif XiqVVzzgAfsK
ajPzuViasnpWU0gf9KBw3b/92y3q6hsPPTS8PH7upXE5OZbOU+L2fzr+ffvb f1N4xtOfMujJ
jX1uHrc7B0Pn3XmXARmQARmQARmQgc1noCkslnkZDHndjC6gzU7OvNtd9/2A oD+IZfGP4/In
zdtn73nPfd/j2fy57Cd+IpwRP/bGA8vZsUj+eVya/zeltPncWx/60P8qoGff 4x7hRfFjL47L
8w8U0L1x/a+J//7h+/5gOOM1f6iAmv2UARmQARmQARmQARmQARmQgR2agZUK 6Ll/+Ip9vybl
Zc0SS2JTRH8/Ln9z+OHh4kc9at/baF/bzIw2M6SxSDbLmXF5XVya8tm81bZ5 zCVHHRXedL/7
hZOa0hmX58XlOXGdZgb0vvHfzeznrz/5ieEdl10gaDs0aEPuilh383ceGTOW ARmQARmQARmQ
ARnYjgysVECbAz718UeF02MBfUksi83MZfP22VPi8oq4NAW0KZmL5bQD/25m Sl8dl1Pj8ntx
+d0DxbMpoM+Ny7MPzH7+VPz7VvHXvfyPB22FN5z5GuVT+ZQBGZABGZABGZAB GZABGZCBHZyB
lQtoU0JPevAD930v6AtjCX1BLI3N22ib7+FsymgzI/rKA383hXMxS9oUz2bW tFm3mfU8MS7H
HyifvxO385j47y+N2zzk4HuHF73gRCHbwSHbjjsr9umOngzIgAzIgAzIgAxM MwNf9OsyfGBH
C1T7IUTLL+h/eOffhecc/pBwSiyOTQltvn+zWZoyuiikzezoYlmUzmbGs3m7 bVM8nxWX45p/
Nz/t9kD5POh7vyeccPz/ClddfqECqoDKgAzIgAzIgAzIgAzIwAwy4NewTPPG wJgbNlV/DUv7
AP/+qkvCsx/7c+EZza9OiUtTLk9oLU3ZbJbmbbZN2dx7YMaz+Xez7lPj4w6J f9/61rcK9znk
3uE5xz0zXPl3vu9zTBg8Zj4vbOfSuZQBGZABGZABGZhTBhTQ+eR5Wwvo4kXx wpOfF446+PvC
02OZfF4zGxqXplw2s5yL0tkUz2Z5zoGPHxPXOSwut4k/UfdOd7pjePjDDg8v e8nJ4eorLnKX
awZ3ueY0YHou8xkwnUvnUgZkQAZkQAa2JwMK6Pa4byLvkyigzRN725vPCr9x 7K+Hw3/g0PCw
W986/EIsl0+Ky7GxcD49Lk+Ky2Pj/x8cl7vFf9/mNrcJ33LnO4UHPeCw8Nu/ dWx481/8meKp
eMqADMiADMiADMiADMjADDOggCqgG3lhN2/JPefs14YTT9gbjo5vzX3gA348 fP+hh4SDDrpn
aL63814Hfe++/zcfP/qox4TnPedZ4Y1vOCNc846LN3I8m2j8tjmfF49z6VzK gAzIgAzIgAzI
QJ0MKKB1nGvkeTIzoDWerH3MJ7jOpXMpAzIgAzIgAzIgA7snAwpo+bneE98t OuXXhgI6w7co
TDlwjq188GDFSgZkQAZkQAZkQAb2Z2CTBbQpbMvLOszHlMDFMSzvP/Wx3PGN 2Xdum+v8vAKq
gE76Dsk6w25bvojLgAzIgAzIgAzIwM7MwKYK6KbK2pjtKqDd2dzjhbszX7jO m/MmAzIgAzIg
AzIgAzKwEzOwiQLaVxIXn1tep2uWNPXx0o+1Zzub/7f3nTuG3PqLfXQd0/I+ F/8eM/Namisz
oGZAzYDKgAzIgAzIgAzIgAzIwKQzsB0FtF38UmWxXbpSxbVd8FL/7yueXUV5 eV+pYy05/nbR
HDNzW1o8F+spoAabSQ82QwNtfXd1ZUAGZEAGZEAGZGB+GdiOAtounF3fK5r6 eLvItddJFb2u
wtg1A9pXdkv337XeJl9DCqgCqoDKgAzIgAzIgAzIgAzIwKQzMIUCmiplqQJX OuPZNXuaekts
3zZLjiE3i5o6lk3NhiqgBptJDzabvPti2/O7O+qcOqcyIAMyIAMyMM8MbKKA dr0VtqRA5t5q
21UKF/nMzYCm3u5bUjRXLa8lbzNe9TWmgCqgCqgMyIAMyIAMyIAMyIAMTDoD myqgi8LW/gE9
XQUx9cN5cm/NXS6dfT/cp2SWsvTtvl0FNvc9n22HVctm6vEKqMFm0oPNJkJv m/O8M+q8Oq8y
IAMyIAMyMN8MbLKAyk3d3CigCqgCKgMyIAMyIAMyIAMyIAOTzoACWrckbrKU K6AGm0kPNpsM
v23PZyBzLp1LGZABGZABGZh3BhTQ+ZxfBVQBVUBlQAZkQAZkQAZkQAZkYNIZ UEAV0EkH1B2w
+QTUuXQuZUAGZEAGZEAGZEAGFND5ZMAMqLtdbibIgAzIgAzIgAzIgAzIwKQz oIAqoJMOqLtk
8wmoc+lcyoAMyIAMyIAMyIAMNAW0mTmzzMNga2trUJ/cYxAwCMiADMiADMiA DMiADMiADNTK
QFNYLPMyGJIdBdRbNAbdsRgSLuv6QiYDMiADMiADMiADMiADMrCcAQVUAVVA ZUAGZEAGZEAG
ZEAGZEAGZKBKBhRQQasSNHe+3PmSARmQARmQARmQARmQARlQQBVQBVQGZEAG ZEAGZEAGZEAG
qmWg+SFE/sxHwA8hMnhUGzzcwXIHSwZkQAZkQAZkQAZkYGgG/BqW+WTG7wFV PpVPGZABGZAB
GZABGZABGZh0BhRQBXTSAR16R8X68wm0c+lcyoAMyIAMyIAMyMD8MqCAzuec mgF1t8vNBBmQ
ARmQARmQARmQARmYdAYUUAV00gF112s+AXUunUsZkAEZkAEZkAEZkAEFdD4Z MAPqbpebCTIg
AzIgAzIgAzIgAzIw6QwooMML6J49eyZ5ThVQg80kg+lO5/BBhhkzGZABGZAB GZCBuWZgbgW0
KYfLS8l5Ky2Ui/VK1y/Z9zrXUUAVUAVUBmRABmRABmRABmRABiadgSkX0FzR S32+/bHcNpoC
WLLOclEcuv46S2bfthRQg82kB5taLwT7ccdYBmRABmRABmRABqabgSkW0MUM Zldu+j6fK6Wp
2dEhH2sX1qGzrZt8LSigCqgCKgMyIAMyIAMyIAMyIAOTzsCUCugqxXNR7PoK aNfsaG5Gs/3W
26m+FVcBNdhMerDZ5N0X257uXU7nxrmRARmQARmQARlYzsBUCmhpCczlN1dA U98j2vWY9uxm
qojmjjt3vOv8vAKqgCqgMiADMiADMiADMiADMjDpDEylgC7e2tpX6HIzpF3f z5mbscx932jX
DOjyrOsUiqgCarCZ9GCzzrsttuVOqgzIgAzIgAzIgAzszAxMqYCWFroh3wO6 XAxL34KbWy/3
fabb9VpQQBVQBVQGZEAGZEAGZEAGZEAGJp2BKRbQvu/nXC53pW+dbT8mVWDb H+t7q+7yjGjJ
rGytQqqAGmwmPdjUeiHYz868G+q8OW8yIAMyIAMysDsyMOUCKoPDMqiAKqAK qAzIgAzIgAzI
gAzIgAxMOgMK6LCSN+VSrIAabCY92Ez5xePY5jMQOpfOpQzIgAzIgAxMOwMK 6LTPz5DXjwKq
gCqgMiADMiADMiADMiADMjDpDCigCuikAzqkgVt3PmF2Lp1LGZABGZABGZAB GZhnBhTQ+ZxX
M6DudrmZIAMyIAMyIAMyIAMyIAOTzoACqoBOOqDufM0noM6lcykDMiADMiAD MiADMtAU0Gbm
zDIPg62trUF9co9BwCAgAzIgAzIgAzIgAzIgAzJQKwNNYbHMy2BIdhRQb9EY dMdiSLis6wuZ
DMiADMiADMiADMiADMjAcgYUUAVUAZUBGZABGZABGZABGZABGZCBKhlQQAWt StDc+XLnSwZk
QAZkQAZkQAZkQAZkQAFVQBVQGZABGZABGZABGZABGZABGaiSAQVU0KoEzd0u d7tkQAZkQAZk
QAZkQAZkQAYUUAVUAZUBGZABGZABGZABGZABGZCBKhlQQAWtStDc7XK3SwZk QAZkQAZkQAZk
QAZkQAFVQBVQGZABGZABGZABGZABGZABGaiSAQVU0KoEzd0ud7tkQAZkQAZk QAZkQAZkQAYU
UAVUAZUBGZABGZABGZABGZABGZCBKhlQQAWtStDc7XK3SwZkQAZkQAZkQAZk QAZkQAFVQBVQ
GZABGZABGZABGZABGZABGaiSAQVU0KoEzd0ud7tkQAZkQAZkQAZkQAZkQAZG FdC9e/cGCwMZ
kAEZkAEZkAEZkAEZkAEZ2N0ZCPHPkBsLowvo1tZWsDCQARmQARmQARmQARmQ ARmQgd2ZgaZ4
Vi2g+/a2pj9DWrN1Td3LgAzIwO7NwJq+7NgMAQIECBAgsKKAAur7OQdNf7uA 370X8M69c7+T
M7Di10oPJ0CAAAECBNYkoIAqoAqoDMiADMw+A2v6mmkzBAgQIECAwIoCCmi8 8NyzZ0/y4qvr
4zt5FmC7jn0dls022tsZst3FurnH5D6fMkwd26asxxzfuo9lCsfQ95xWycm6 rdrb2/Sx5c7N
pve/ab/c9rte5yt+rfRwAgQIECBAYE0CkyigJT8FK/V8Fxcii4v/sSVAAe0u 4bmLvdLPp4xz
F8rL2+66aB6zjdxjhn4+t36pUel6tffXVbibj0/hWPqOb3mMKPXd9HqbLoC5 c1L6WlpeLzXG
rjrubspZAV3T1YHNECBAgACBDQlMpoD2Pb+moOYKaF9ZyV3oKKCbLxK5i+Ia 52hdM6CbLhBj
LXKPW+fnVz2f6zwWBfSW35uaOzdDC2jp+Jjb76bPeftmQ/t4NvQ11GYJECBA gACBgQKzLqCp
wrF81z43g9o1A5B63GI2KHVx1zczO+R4lvdRcmypUt41a5E7jr6Lu9Rj28ea ujhdPj9d2+iz
bs/A5bbRvgDus+jab+ocjLVrPy6Vk1zZ7dp3n01fUSg5l8vbLjmHpT6p89N1 Yym3zfbro72d
ZevScaLvJlfJ67HvXPXlqu/YS8awdq5yNqnslJT89uP6Xm+55zQm17mCO/Br o9UJECBAgACB
DQnMvoAOvdjqurjuKnPtYpZ6fNeFUVe5KP146oIvdTHdd0y59VPFcxXTnGPX RWzOJFfUSi6g
uyxSBqVlpG3fZVfy8VwxaJfBVDb7SkLOuO/cjXls1/HlMpIq0H3nvy+vy8Wv 5HhqHVvqmEuN
c6/pEo+S8lhyHnIZLNnGqrleHMOGvobaLAECBAgQIDBQYFIFdPmu9+LfzfNZ vAW3/ffyxU1u
dmGVspY6rr4y0HXB1HdRtzxLUXqhucpzKilV7efdtb/S9VLPv+85lJS8tnUq B6nyWWo35rmV
nr/S0tnlMGY/uQJa8nzbpTpnmTrO1H6GnKe+wpl7bQ55bGqMyeVyyPZLMjCk ULbPTe58lhTA
0tfturM1dozqytHAr41WJ0CAAAECBDYkMKkC2vUch34PaO6ue8mFTeoiu+tC rO+Cd/G5IRd6
pcUid+GfulAu3XbqeEvLYul6uQvr3IV+yTnquhgtsRtrNeZxXUWkNHN9FrlC 1PV66ft4+9zl
9tF3g6XvHJWUmlzeul57Q/JXWo7bhXXIseXK6NBclbyGS7dZMpbkzlXKsGRc XMd5Wnyh29DX
UZslQIAAAQIEBggooImf5Fl6cZ27YOwrUCUFKFeU17GN0ou7da83pDCVPM9c ASq5+B1z3nMF
o/R5lmapr6gOPUftYx9SRkqtSorLmOeUe22UFPpSr1z5zBW9vmyWnPfccZae t9R2Suy7boLk
XnMl215nAe06D4vjH/B10aoECBAgQIDABgV2VQFdXHA3Fyrti6PFx/ouCFOP S80SLV/otR+T
upjr226qJPQdf/uCv/28chfDXS6p59me7UltO+U6pDx07bfrYjrnnfPp807Z dM365PLUV/5K
SkmffddFfekxpQy7cpTKei5DXa/DIYU4d4ypfPS9/ktel6kyncryKsfWN57k 3LrOb9f40jcW
tG+c5Lbdlbmu11vu4yVZ7fNI3TTY4NdRmyZAgAABAgQGCEymgOZ+F2jqOXXN TPj4LX8tA4+0
R+qiecpW6zredW2nr5BNxXETz3Vdz227j227978ux9LtDPi6aFUCBAgQIEBg gwKTKKBjn1/p
hYf1FNJUBnbaBfgqx9s3E72O18cqx7aO/XdtY6rH1Z7t3aTBTrTZhMfYrzMe R4AAAQIECKxX
QAGN3wO6iYsd2+QqAzIgA9PJwHq/dNoaAQIECBAgMFZAAVVAFXAZkAEZmH0G xn6R9DgCBAgQ
IEBgvQI7uoCWUHT9CpeSx1qHAAECBAgQIECAAAECBNYnMPsCuj4qWyJAgAAB AgQIECBAgACB
VQRmX0DNgK4SD48lQIAAAQIECBAgQIDA+gRmX0DXR9W/peanbS7+LH7iaK19 L+9n+Ti2Y//2
OV2BVDYWH8vlJvf51LOu8TooPf6pnJUxjlM59tQ4M4XnM4Vj6DtH7YxO/Xin mDfHRIAAAQLz
Eph9AR06A5q6aC65kJ7KhXDfcSx/bvnXcuQK7PK6JRbreIm0L9I2cdHWV8jW 8Rw2tY2xFpss
oDXOV1fJbT4+1qSkOKzzPG7HcW7i3ExlvFs+95uwXce5V0DXoWgbBAgQIDAn gdkX0KEna7cU
0K7SOZVSVuNicirPdUxGhz6mq6SVFonc+dhEySl5jqXHX7Kt9jq55zyVbeaO Y5PPYxPbzj2f
Gudp6DGU3MjYZFbXeby2RYAAAQIENi0w+wI6ZgY0dVd9+UIrNXuYml1cnLzc +ov9LZffviKc
uthv72PIbFf7uZVe4PWVjq7n3H5ey+v1GZf4p/bZVbxKClnf9trnKlXoS55b 37lczk87k32O
7WPpeh6pwaXvmHN5TuW35Lz1Pbeu10HJwJh7LiXHNsY555R7fZUcV2qMSo0j XWNL7hiHZCa3
rfZrreu8pFxKxsHlsbf9fEtfX6n9pF7T7ddkiXlqLC7Jr3UIECBAgMBcBWZf QIeeuNTFTEmJ
aT8udaGSutDuuqBpf7yr7JV+vOuCNXVx2HchWLK/1AVXyeNKjnHodkrOXepC s3Q/qe3nslC6
7eXttEtJycVx1376XhOlx1aaz3W/DvrOZyq3Xee2xDPn13Weh2Sib92u55Mq xalzuu4cjs1N
ifWQc9fnsin7rrFpyFg39GuR9QkQIECAwFwFZl9AFzOgub9TF8pdF06pO/i5 i70hF+yp/bb3
mdtf34VR6vi7ikLJBX/uQn2xjT63Up/SgpR6/rmL3K6LzPbHc8936LkZu/6y 2RDbsUWia38l
JWrMeesrLiUD8ph9lmQgl9WhJSi3z+Vzm7MekoOxPin7sdvqep2Wjncpu75j SX2ubzzMjRnt
mwG581OSW+sQIECAAIG5C8y+gA49gX2ls+TCctVy0t5HVznpKox966c+lzve dRbQdVy4jr3Q
Ldl3rggsb2P5wnPoMa1r/a4M5LKxSgEdeuy5Y+nL324voEOtN73+KrnJ5SBX 9Pqy3h7XcmNa
32s39/UiV5gV0JygzxMgQIAAgRAU0FYK+i4wplRAu4rm0ALaVXjbZavrxVJS akvc2heY67qY
7ivQqXOdc025rOtYh24nd1GfuxAvKeWlF/e5fY15brmbQbkBfMw+h96E6MpX 6b77Xmel28hl
dl3b2XQB7bvhMGRcy2Wx9ByXupWOXSWvt1ymfZ4AAQIECMxBQAEdWEAXFy+L u+i5C/T2+rnS
0FcI2/tc3lbqc8sf67u4a1+QpZ5balt9F3q548kd+7JbymSx/aGe7RdtqdHy eW7vuy8TOYeU
Ye65tW26MtZ1XLki0XXMuXO2fNzt57Xu10HJ4Ft6bkv8Us99+Rhy57krp+1t lOSz9HXXfs2n
SlzuXLdfe6XZ6Xu+peelZLxrj119mS/dXurY+8po6XiQsku9TkqybR0CBAgQ ILCTBRTQnXz2
ZnDsc74A63puU37OUz62oXGf03MZ+tx3yvqbOEeb2OZO8XScBAgQIEBgJwgo oDvhLM34GOd8
saiAbm9w55yt7ZVdbe9dM5GrbfW/H+28r0vSdggQIECAwGYEFNDNuNoqAQIE CBAgQIAAAQIE
CLQEFFCRIECAAAECBAgQIECAAIEqAgpoFWY7IUCAAAECBAgQIECAAAEFVAYI ECBAgAABAgQI
ECBAoIqAAlqF2U4IECBAgAABAgQIECBAQAGVAQIECBAgQIAAAQIECBCoIqCA VmG2EwIECBAg
QIAAAQIECBBQQGWAAAECBAgQIECAAAECBKoIKKBVmO2EAAECBAgQIECAAAEC BBRQGSBAgAAB
AgQIECBAgACBKgIKaBVmOyFAgAABAgQIECBAgAABBVQGCBAgQIAAAQIECBAg QKCKgAJahdlO
CBAgQIAAAQIECBAgQEABlQECBAgQIECAAAECBAgQqCKggFZhthMCBAgQIECA AAECBAgQUEBl
gAABAgQIECBAgAABAgSqCCigVZjthAABAgQIECBAgAABAgQUUBkgQIAAAQIE CBAgQIAAgSoC
CmgVZjshQIAAAQIECBAgQIAAAQVUBggQIECAAAECBAgQIECgioACWoXZTggQ IECAAAECBAgQ
IEBAAZUBAgQIECBAgAABAgQIEKgioIBWYbYTAgQIECBAgAABAgQIEFBAZYAA AQIECBAgQIAA
AQIEqggooFWY7YQAAQIECBAgQIAAAQIEFFAZIECAAAECBAgQIECAAIEqAgpo FWY7IUCAAAEC
BAgQIECAAAEFVAYIECBAgAABAgQIECBAoIqAAlqF2U4IECBAgAABAgQIECBA QAGVAQIECBAg
QIAAAQIECBCoIqCAVmG2EwIECBAgQIAAAQIECBBQQGWAAAECBAgQIECAAAEC BKoIKKBVmO2E
AAECBAgQIECAAAECBBRQGSBAgAABAgQIECBAgACBKgIKaBVmOyFAgAABAgQI ECBAgAABBVQG
CBAgQIAAAQIECBAgQKCKgAJahdlOCBAgQIAAAQIECBAgQEABlQECBAgQIECA AAECBAgQqCKg
gFZhthMCBAgQIECAAAECBAgQUEBlgAABAgQIECBAgAABAgSqCCigVZjthAAB AgQIECBAgAAB
AgQUUBkgQIAAAQIECBAgQIAAgSoCCmgVZjshQIAAAQIECBAgQIAAAQVUBggQ IECAAAECBAgQ
IECgioACWoXZTggQIECAAAECBAgQIEBAAZUBAgQIECBAgAABAgQIEKgioIBW YbYTAgQIECBA
gAABAgQIEFBAZYAAAQIECBAgQIAAAQIEqggooFWY7YQAAQIECBAgQIAAAQIE FFAZIECAAAEC
BAgQIECAAIEqAgpoFWY7IUCAAAECBAgQIECAAAEFVAYIECBAgAABAgQIECBA oIqAAlqF2U4I
ECBAgAABAgQIECBAQAGVAQIECBAgQIAAAQIECBCoIqCAVmG2EwIECBAgQIAA AQIECBBQQGWA
AAECBAgQIECAAAECBKoIKKBVmO2EAAECBAgQIECAAAECBBRQGSBAgAABAgQI ECBAgACBKgIK
aBVmOyFAgAABAgQIECBAgAABBVQGCBAgQIAAAQIECBAgQKCKgAJahdlOCBAg QIAAAQIECBAg
QEABlQECBAgQIECAAAECBAgQqCKggFZhthMCBAgQIECAAAECBAgQUEBlgAAB AgQIECBAgAAB
AgSqCCigVZjthAABAgQIECBAgAABAgQUUBkgQIAAAQIECBAgQIAAgSoCCmgV ZjshQIAAAQIE
CBAgQIAAAQVUBggQIECAAAECBAgQIECgioACWoXZTggQIECAAAECBAgQIEBA AZUBAgQIECBA
gAABAgQIEKgioIBWYbYTAgQIECBAgAABAgQIEFBAZYAAAQIECBAgQIAAAQIE qggooFWY7YQA
AQIECBAgQIAAAQIEFFAZIECAAAECBAgQIECAAIEqAgpoFWY7IUCAAAECBAgQ IECAAAEFVAYI
ECBAgAABAgQIECBAoIqAAlqF2U4IECBAgAABAgQIECBAQAGVAQIECBAgQIAA AQIECBCoIqCA
VmG2EwIECBAgQIAAAQIECBBQQGWAAAECBAgQIECAAAECBKoIKKBVmO2EAAEC BAgQIECAAAEC
BBRQGSBAgAABAgQIECBAgACBKgIKaBVmOyFAgAABAgQIECBAgAABBVQGCBAg QIAAAQIECBAg
QKCKgAJahdlOCBAgQIAAAQIECBAgQEABlQECBAgQIECAAAECBAgQqCKggFZh thMCBAgQIECA
AAECBAgQUEBlgAABAgQIECBAgAABAgSqCCigVZjthAABAgQIECBAgAABAgQU UBkgQIAAAQIE
CBAgQIAAgSoCCmgVZjshQIAAAQIECBAgQIAAAQVUBggQIECAAAECBAgQIECg ioACWoXZTggQ
IECAAAECBAgQIEBAAZUBAgQIECBAgAABAgQIEKgioIBWYbYTAgQIECBAgAAB AgQIEFBAZYAA
AQIECBAgQIAAAQIEqggooFWY7YQAAQIECBAgQIAAAQIEFFAZIECAAAECBAgQ IECAAIEqAgpo
FWY7IUCAAAECBAgQIECAAAEFVAYIECBAgAABAgQIECBAoIqAAlqF2U4IECBA gAABAgQIECBA
QAGVAQIECBAgQIAAAQIECBCoIqCAVmG2EwIECBAgQIAAAQIECBBQQGWAAAEC BAgQIECAAAEC
BKoIKKBVmO2EAAECBAgQIECAAAECBBRQGSBAgAABAgQIECBAgACBKgIKaBVm OyFAgAABAgQI
ECBAgAABBVQGCBAgQIAAAQIECBAgQKCKgAJahdlOCBAgQIAAAQIECBAgQEAB lQECBAgQIECA
AAECBAgQqCKggFZhthMCBAgQIECAAAECBAgQUEBlgAABAgQIECBAgAABAgSq CCigVZjthAAB
AgQIECBAgAABAgQUUBkgQIAAAQIECBAgQIAAgSoCCmgVZjshQIAAAQIECBAg QIAAAQVUBggQ
IECAAAECBAgQIECgioACWoXZTggQIECAAAECBAgQIEBAAZUBAgQIECBAgAAB AgQIEKgioIBW
YbYTAgQIECBAgAABAgQIEFBAZYAAAQIECBAgQIAAAQIEqggooFWY7YQAAQIE CBAgQIAAAQIE
FFAZIECAAAECBAgQIECAAIEqAgpoFWY7IUCAAAECBAgQIECAAAEFVAYIECBA gAABAgQIECBA
oIqAAlqF2U4IECBAgAABAgQIECBAQAGVAQIECBAgQIAAAQIECBCoIqCAVmG2 EwIECBAgQIAA
AQIECBBQQGWAAAECBAgQIECAAAECBKoIKKBVmO2EAAECBAgQIECAAAECBBRQ GSBAgAABAgQI
ECBAgACBKgIKaBVmOyFAgAABAgQIECBAgAABBVQGCBAgQIAAAQIECBAgQKCK gAJahdlOCBAg
QIAAAQIECBAgQEABlQECBAgQIECAAAECBAgQqCKggFZhthMCBAgQIECAAAEC BAgQUEBlgAAB
AgQIECBAgAABAgSqCCigVZjthAABAgQIECBAgAABAgQUUBkgQIAAAQIECBAg QIAAgSoCCmgV
ZjshQIAAAQIECBAgQIAAAQVUBggQIECAAAECBAgQIECgioACWoXZTggQIECA AAECBAgQIEBA
AZUBAgQIECBAgAABAgQIEKgioIBWYbYTAgQIECBAgAABAgQIEFBAZYAAAQIE CBAgQIAAAQIE
qggooFWY7YQAAQIECBAgQIAAAQIEFFAZIECAAAECBAgQIECAAIEqAgpoFWY7 IUCAAAECBAgQ
IECAAAEFVAYIECBAgAABAgQIECBAoIqAAlqF2U4IECBAgAABAgQIECBAQAGV AQIECBAgQIAA
AQIECBCoIqCAVmG2EwIECBAgQIAAAQIECBBQQGWAAAECBAgQIECAAAECBKoI KKBVmO2EAAEC
BAgQIECAAAECBBRQGSBAgAABAgQIECBAgACBKgIKaBVmOyFAgAABAgQIECBA gAABBVQGCBAg
QIAAAQIECBAgQKCKgAJahdlOCBAgQIAAAQIECBAgQEABlQECBAgQIECAAAEC BAgQqCKggFZh
thMCBAgQIECAAAECBAgQUEBlgAABAgQIECBAgAABAgSqCCigVZjthAABAgQI ECBAgAABAgQU
UBkgQIAAAQIECBAgQIAAgSoCCmgVZjshQIAAAQIECBAgQIAAAQVUBggQIECA AAECBAgQIECg
ioACWoXZTggQIECAAAECBAgQIEBAAZUBAgQIECBAgAABAgQIEKgioIBWYbYT AgQIECBAgAAB
AgQIEFBAZYAAAQIECBAgQIAAAQIEqggooFWY7YQAAQIECBAgQIAAAQIEFFAZ IECAAAECBAgQ
IECAAIEqAgpoFWY7IUCAAAECBAgQIECAAAEFVAYIECBAgAABAgQIECBAoIqA AlqF2U4IECBA
gAABAgQIECBAQAGVAQIECBAgQIAAAQIECBCoIqCAVmG2EwIECBAgQIAAAQIE CBBQQGWAAAEC
BAgQIECAAAECBKoIKKBVmO2EAAECBAgQIECAAAECBBRQGSBAgAABAgQIECBA gACBKgIKaBVm
OyFAgAABAgQIECBAgAABBVQGCBAgQIAAAQIECBAgQKCKgAJahdlOCBAgQIAA AQIECBAgQEAB
lQECBAgQIECAAAECBAgQqCKggFZhthMCBAgQIECAAAECBAgQUEBlgAABAgQI ECBAgAABAgSq
CCigVZjthAABAgQIECBAgAABAgQUUBkgQIAAAQIECBAgQIAAgSoCCmgVZjsh QIAAAQIECBAg
QIAAAQVUBggQIECAAAECBAgQIECgioACWoXZTggQIECAAAECBAgQIEBAAZUB AgQIECBAgAAB
AgQIEKgioIBWYbYTAgQIECBAgAABAgQIEFBAZYAAAQIECBAgQIAAAQIEqggo oFWY7YQAAQIE
CBAgQIAAAQIEFFAZIECAAAECBAgQIECAAIEqAgpoFWY7IUCAAAECBAgQIECA AAEFVAYIECBA
gAABAgQIECBAoIqAAlqF2U4IECBAgAABAgQIECBAQAGVAQIECBAgQIAAAQIE CBCoIqCAVmG2
EwIECBAgQIAAAQIECBBQQGWAAAECBAgQIECAAAECBKoIKKBVmO2EAAECBAgQ IECAAAECBBRQ
GSBAgAABAgQIECBAgACBKgIKaBVmOyFAgAABAgQIECBAgAABBVQGCBAgQIAA AQIECBAgQKCK
gAJahdlOCBAgQIAAAQIECBAgQEABlQECBAgQIECAAAECBAgQqCKggFZhthMC BAgQIECAAAEC
BAgQUEBlgAABAgQIECBAgAABAgSqCFQtoM3OLAxkQAZkQAZkQAZkQAZkQAZk YPdmoGm6Q87/
niErL9atUqfthAABAgQIECBAgAABAgQmLzCkU44qoEN2YN3dezfEuXfuZUAG ZEAGZEAGZEAG
ZEAGljOggHor8aApcwOIAUQGZEAGZEAGZEAGZEAGZGBsBhRQBVQBlQEZkAEZ kAEZkAEZkAEZ
kIEqGRhVQPfu3RssDGRABmRABmRABmRABmRABmRgd2egyg8hakK2tbVlYSAD MiADMiADMiAD
MiADMiADuzQDVX8NS1NA/SFAgAABAgQIECBAgACBnSkw9vs4m8c1fVAB3Znn 3VETIECAAAEC
BAgQIECgusCiQA7d8eIdsQroUDnrEyBAgAABAgQIECBAYJcKjCmQzWMU0F0a GE+bAAECBAgQ
IECAAAECYwUU0LFyHkeAAAECBAgQIECAAAECgwQU0EFcViZAgAABAgQIECBA gACBsQIK6Fg5
jyNAgAABAgQIECBAgACBQQJ9BbT5Ps+un5Lre0AHMVuZAAECBAgQIECAAAEC BLoKaFMwF0uq
hCqgskOAAAECBAgQIECAAAECgwRSBXS5fHaVUAV0ELOVCRAgQIAAAQIECBAg QKBdQFPlM1VC
FVDZIUCAAAECBAgQIECAAIFBAqkZ0L4NLN6Oq4AOYrYyAQIECBAgQIAAAQIE CPgpuDJAgAAB
AgQIECBAgAABAlUEFNAqzHZCgAABAgQIECBAgAABAgqoDBAgQIAAAQIECBAg QIBAFYGmgPb9
4KG+z21tbe37PaHNn67fF5r6+J4hK7e/6bSKip0QIECAAAECBAgQIECAwNoF mhK5yqKArv2U
2CABAgQIECBAgAABAgTmKbBcIBczmWP/Lp3YNAM6zyx5VgQIECBAgAABAgQI EMgKrFJCzYBm
ea1AgAABAgQIECBAgAABAmNnOrseZwZUpggQIECAAAECBAgQIECgV8AMqIAQ IECAAAECBAgQ
IECAwMYFVimf7ZlQM6AbP112QIAAAQIECBAgQIAAgZ0tsEoJ9T2gO/vcO3oC BAgQIECAAAEC
BAhUE1ilfJoBrXaa7IgAAQIECBAgQIAAAQLzEFilhJoBnUcGPAsCBAgQIECA AAECBAhsXGCV
8mkGdOOnxw4IECBAgAABAgQIECAwL4FVSqgZ0HllwbMhQIAAAQIECBAgQIDA xgRWKZ9mQDd2
WmyYAAECBAgQIECAAAEC8xRYpYSaAZ1nJjwrAgQIECBAgAABAgQIrF1glfJp BnTtp8MGCRAg
QIAAAQIECBAgMG+BVUqoGdB5Z8OzI0CAAAECBAgQIECAwNoEVimfZkDXdhps iAABAgQIECBA
gAABArtDYJUSagZ0d2TEsyRAgAABAgQIECBAgMDKAquUTzOgK/PbAAECBAgQ IECAAAECBHaX
wCol1Azo7sqKZ0uAAAECBAgQIECAAIHRAquUTzOgo9k9kAABAgQIECBAgAAB ArtTYJUSagZ0
d2bGsyZAgAABAgQIECBAgMBggVXKpxnQwdweQIAAAQIECBAgQIAAgd0tsEoJ NQO6u7Pj2RMg
QIAAAQIECBAgQKBYYJXyaQa0mNmKBAgQIECAAAECBAgQINAukUP/bwZUhggQ IECAAAECBAgQ
IECgSMAMaBGTlQgQIECAAAECBAgQIEBgHQKrlFAzoOs4A7ZBgAABAgQIECBA gACBXSCwSvls
eBTQXRAST5EAAQIECBAgQIAAAQLrElilhCqg6zoLtkOAAAECBAgQIECAAIGZ C6xSPs2Azjwc
nh4BAgQIECBAgAABAgTWLbBKCTUDuu6zYXsECBAgQIAAAQIECBCYqcAq5dMM 6ExD4WkRIECA
AAECBAgQIEBgUwKrlFAzoJs6K7ZLgAABAgQIECBAgACBmQmsUj7NgM4sDJ4O AQIECBAgQIAA
AQIENi2wSgk1A7rps2P7BAgQIECAAAECBAgQmInAKuXTDOhMQuBpECBAgAAB AgQIECBAoJbA
KiXUDGits2Q/BAgQIECAAAECBAgQ2OECq5RPM6A7/OQ7fAIECBAgQIAAAQIE CNQWWKWEmgGt
fbbsjwABAgQIECBAgAABAjtUYJXyaQZ0h550h02AAAECBAgQIECAAIHtElil hJoB3a6zZr8E
CBAgQIAAAQIECBDYYQKrlE8zoDvsZDtcAgQIECBAgAABAgQIbLfAKiXUDOh2 nz37J0CAAAEC
BAgQIECAwA4RWKV8mgHdISfZYRIgQIAAAQIECBAgQGAqAquUUDOgUzmLjoMA AQIECBAgQIAA
AQITF1ilfJoBnfjJdXgECBAgQIAAAQIECBCYmsAqJdQM6NTOpuMhQIAAAQIE CBAgQIDARAVW
KZ9mQCd6Uh0WAQIECBAgQIAAAQIEpiqwSgk1AzrVs+q4CBAgQIAAAQIECBAg MDGBVcqnGdCJ
nUyHQ4AAAQIECBAgQIAAgakLrFJCzYBO/ew6PgIECBAgQIAAAQIECExEYJXy aQZ0IifRYRAg
QIAAAQIECBAgQGCnCKxSQs2A7pSz7DgJECBAgAABAgQIECCwzQKrlE8zoNt8 8uyeAAECBAgQ
IECAAAECO0mgKaBjl62trX2PXRTR0u3sKV1xeb29e/eGZof+ECBAgAABAgQI ECBAgMDOFFgU
yKFHv+iDCuhQOesTIECAAAECBAgQIEBglwqMKZDNYxTQXRoYT5sAAQIECBAg QIAAAQJjBRTQ
sXIeR4AAAQIECBAgQIAAAQKDBBTQQVxWJkCAAAECBAgQIECAAIGxAgroWDmP I0CAAAECBAgQ
IECAAIFBAu0C2nxvZ9eS+qG0Ywqsn4I76BRZmQABAgQIECBAgAABAvMQSBXI VAFdPNtFCfVD
iOZx/j0LAgQIECBAgAABAgQIVBPomsFcLqHt8umn4FY7PXZEgAABAgQIECBA gACB+Qj0vYW2
KaGp8qmAzuf8eyYECBAgQIAAAQIECBCoJpD7Hs7mQJa/99NbcKudGjsiQIAA AQIECBAgQIDA
vARyBTRVPs2AzisDng0BAgQIECBAgAABAgSqCCigVZjthAABAgQIECBAgAAB AgQUUBkgQIAA
AQIECBAgQIAAgSoCi7fT9v3+z67PbW1t7fv+0OZP11t1Ux/3e0CrnFo7IUCA AAECBAgQIECA
wLQEmhK5ylK9gA5puu11mye6aMv+3n/XgAMHOfA6MA4YB4wDxgHjgHHAOGAc KB0HVu1jqzx+
8diqM6CLF8fQHt9M47anbEuRrWdQNigblI0DxgHjgHHAOGAcMA4YB4wD/z0O rNLHVi2h21JA
hx70ooAKjS8evnj44mEcMA4YB4wDxgHjgHHAOGAcGDcOjHkLbPvXqAztcu31 d1QBNdgYbAw2
4wYbbtyMn8ZP44BxwDhgHDAOGAcU0Ph9jMuNuJnpTDVqM6BeLL5o+qLpi6Zx wDhgHDAOGAeM
A8YB48Bq40BXAe3qYYtutvwtkbOZAV38uN7UlKzvATXYGGxWG2z48XPRZhw1 DhgHjAPGAeOA
caCvgPaV0NkV0OXfFdNXQL1ovGh88fTF0zhgHDAOGAeMA8YB44BxwDgwbhzI FdDcO1JXnf0c
8xbglX4PaGqH7V9UagZ0XJi8CLn5YuyLsXHAOGAcMA4YB4wDxgHjQOk40P5W yOVe1i6aZkCj
qheXF1fpi8t6Xi/GC+OFccA4YBwwDhgHjAPGgf0/f6drwm/5WyLb68yugDYQ vgfUoGBQcHHg
4sA4YBwwDhgHjAPGAeOAcaDOOJCaAd3XTg9M9rU/v7W1lfyBsUPflpvaft82 1v4W3PYT8z2g
Bh2DTp1BhzNnF3nGW+OAccA4YBwwDuyucaBvBrSrfC4mC2dZQPtAFk/Yi2R3 vUicb+fbxZGL
I+OAccA4YBwwDhgHjAPrHwfas459M5OzfAtu37Sr3wNq0DHorH/Q8cXc68rr yuvKOGAcMA4Y
B4wDu2sc6Jrwy72NdtcWUIOkQdIgubsGSefb+TbuG/eNA8YB44BxwDiwmXEg Vzpn8z2g7V+7
Uvr/5i24wreZ8HHl6ou7L+7GAeOAccA4YBwwDhgH5j8OLP/w19IetlhvR34P aHPQqyxeFPN/
Ufji54uf17nXuXHAOGAcMA4YB4wDxoHNjAOrdLEdV0CHTPFad//v6LEwkAEZ kAEZkAEZkAEZ
kAEZmFMGqvwalsWP9PU3AQIECBAgQIAAAQIECOxugSGFetTvAR2yA+u6wyMD MiADMiADMiAD
MiADMiADMtBkQAH11lhvDZYBGZABGZABGZABGZABGZCBKhlQQAWtStDc8XLH SwZkQAZkQAZk
QAZkQAZkQAFVQBVQGZABGZABGZABGZABGZABGaiSAQVU0KoEzd0ud7tkQAZk QAZkQAZkQAZk
QAYUUAVUAZUBGZABGZABGZABGZABGZCBKhlQQAWtStDc7XK3SwZkQAZkQAZk QAZkQAZkQAFV
QBVQGZABGZABGZABGZABGZABGaiSAQVU0KoEzd0ud7tkQAZkQAZkQAZkQAZk QAYUUAVUAZUB
GZABGZABGZABGZABGZCBKhlQQAWtStDc7XK3SwZkQAZkQAZkQAZkQAZkQAFV QBVQGZABGZAB
GZABGZABGZABGaiSAQVU0KoEzd0ud7tkQAZkQAZkQAZkQAZkQAb27N27N0xp CTP4MyVPxzKt
fDsfzocMyIAMyIAMyIAMyMBuzsCkZkCbEzGHP83zcHfH3R0ZkAEZkAEZkAEZ kAEZkAEZuGUG
FNANNF4F1EBjoJEBGZABGZABGZABGZABGfjiDCigCqjZWt8HLAMyIAMyIAMy IAMyIAMyUCUD
sy6ge/bsSdbLro+vq4uaAXW3y90uGZABGZABGZABGZABGZCBghnQppy1l1pw 7e8BbR/H0IKo
gHrR18qu/ciaDMiADMiADMiADMiADOQz8EUzoE1p2y64VAFdLp1DZy4V0HwA tutc269zIwMy
IAMyIAMyIAMyIAO7LwODCujyjOQiLF0faz6/XGZT67UDV1pAF8VyuWAub39R WrtmUIc8rtnW
YjvtMpz6eLOOt+DuvheSwdM5lwEZkAEZkAEZkAEZkIF8Bv4/teFpY5bqN4EA AAAASUVORK5C
YII=
--------------000304000605080205000700--
Re: Running into NPE errors with WTP RC4 [message #170764 is a reply to message #170756] |
Wed, 07 June 2006 18:00 |
--------------080908030302080104080903
Anad,
Yes, that looks like the same type of problem.
Anand Hatwalne wrote:
> Anand
> Ed Merks wrote:
>> Vikram,
>>> NsPrefix and Ns URI
>>> prior to this)
>>> last post.
>>> regards
>>> --vikram
boundary="------------080803070200090400040901"
--------------080803070200090400040901
<html>
<head>
</head>
Anad,<br>
<br>
Yes, that looks like the same type of problem.<br>
<br>
<br>
<blockquote cite="mide66ask$ldg$1@utils.eclipse.org" type="cite">Hi,
<br>
<br>
<br>
<br>
Anand
<br>
<br>
Ed Merks wrote:
<br>
<blockquote type="cite">Vikram,
<br>
<br>
FUDForum. Page generated in 0.03221 seconds
