Home » Eclipse Projects » GEF » Frame on editor problem
Frame on editor problem [message #170330] Thu, 03 March 2005 11:48 Go to next message
Originally posted by: binti.ksu.edu
Hi all,
I am trying to make changes to the schema diagram editor example to get a
better understanding of gef. I need to add af frame to the editor on which
my figures would appear. I am able to do this by adding a recatngular figure
to the schemafigure. Schemafigure extends FreeformLayer. So the frame
appears on it.
The class schemafigure is as follows:
public class SchemaFigure extends FreeformLayer
public SchemaFigure()
setOpaque(true);
setBorder(new LineBorder(ColorConstants.white, 1));
protected void paintFigure(Graphics g)
Rectangle r = getBounds().getCopy();
r.translate(20, 20);
g.setLineWidth(2);
g.drawRectangle(r.x, r.y, r.width - 40, r.height - 40);
g.drawRectangle(r);
My problem is, when I add figures at the edges, the frame and the editor
expands, which is desired, but my figure intersects the frame. How can I
validate and expand the frame at this point so that the figure lies withing
the frame and not over it.
Thanks in advance,
Binti
Re: Frame on editor problem [message #170392 is a reply to message #170330] Fri, 04 March 2005 00:27 Go to previous messageGo to next message
Originally posted by: huangjun.cs.umb.edu
If I understand you correctly...
when you do sth to your models to impl adding a child figure onto your
frame, do you recalculate the size of the frame?
Best,
Jun
"Binti Sepaha" <binti@ksu.edu> wrote in message
news:d07f6p$k68$2@www.eclipse.org...
> Hi all,
figure
> appears on it.
> setOpaque(true);
> g.setLineWidth(2);
> g.drawRectangle(r);
withing
> Thanks in advance,
> Binti
Re: Frame on editor problem [message #170399 is a reply to message #170392] Fri, 04 March 2005 00:38 Go to previous messageGo to next message
Sorry. Just have a look at logic example...
Do you set a FreeformLayout instance as the LayoutManager of the frame?
"hunj" <huangjun@cs.umb.edu> wrote in message
news:d08rj5$2ji$1@www.eclipse.org...
> Best,
> Jun
> > Hi all,
a
which
> figure
> > appears on it.
> > setOpaque(true);
> > g.setLineWidth(2);
> > g.drawRectangle(r);
> withing
> > Thanks in advance,
> > Binti
Re: Frame on editor problem [message #170454 is a reply to message #170399] Fri, 04 March 2005 09:13 Go to previous message
As I mentioned the schemafigure extends a freeform layer and it extends when
the model becomes largea and the frame on it expands as well. I am trying to
recalculate the size of the frame and resetting its bounds, but it is not
doing so....i try to get the freeformextent and set it again. even if I use
setsize or setpreferred size for schema figure it does not show....it is
only following the default behaviour of expansion vertically and
horizontally upon adding childs. How can I control this behaviour?
Thanks in advance,
Binti
news:d08s8h$58i$1@www.eclipse.org...
>> Best,
>> Jun
>> > Hi all,
> a
> which
>> figure
>> > appears on it.
>> > setOpaque(true);
>> > g.setLineWidth(2);
>> > g.drawRectangle(r);
>> > editor
>> > I
>> withing
>> > Thanks in advance,
>> > Binti
Previous Topic:How to delete an editpart from the diagram
Next Topic:Visual folding editor - how?
Current Time: Mon Jul 14 15:56:11 EDT 2025
Powered by FUDForum. Page generated in 0.07936 seconds
