Home » Modeling » Graphiti » Outline view not available in plugin
Outline view not available in plugin [message #1118353] Fri, 27 September 2013 10:17 Go to next message
Daniele DN is currently offline Daniele DNFriend
Hi all,
I am running my project as a plugin and I need an Outline view (as tree view) of elements added in my graphiti diagram. I tried to follow the "Common example" to do this, taking care of adding the extension point "org.eclipse.ui.navigator.navigatorContent" with my own GFEmfLabelProvider, RenameActionProvider and ElementNode, but the Outline task in plugin is always not available or it shows some information like in the attached output picture.
So I would kindly ask you for a better solution.
Daniele
Re: Outline view not available in plugin [message #1120688 is a reply to message #1118353] Sun, 29 September 2013 22:40 Go to previous message
I solved my problem. I forgot to specify my own GFEmfTreeContentProvider in plugin.xml. I'm pretty new in Eclipse plugin generation and I'm sorry also because I had a wrong idea about what my code would have produced.
Thanks anyway Very Happy
Daniele
Previous Topic:How to define a selection provider for my editor ?
Next Topic:How to disable multi selection of elements in graphiti
Current Time: Sun Jul 25 21:31:38 GMT 2021
Powered by FUDForum. Page generated in 0.01891 seconds
