Re: not sure whether we are moving forward or backward? [message #1118773 is a reply to message #1117715] |
Fri, 27 September 2013 19:23 |
In kepler it is even worse. Every time when i try to put a debug point it throws the error and gets shutdown. Now a days working with eclipse is being a tough job.
The following is the stack trace:-
rg.eclipse.swt.SWTError: No more handles
at org.eclipse.swt.SWT.error(SWT.java:4423)
at org.eclipse.swt.SWT.error(SWT.java:4312)
at org.eclipse.swt.SWT.error(SWT.java:4283)
at org.eclipse.swt.widgets.Widget.error(Widget.java:472)
at org.eclipse.swt.widgets.Control.createHandle(Control.java:704)
at org.eclipse.swt.widgets.Label.createHandle(Label.java:199)
at org.eclipse.swt.widgets.Control.createWidget(Control.java:744)
at org.eclipse.swt.widgets.Control.<init>(Control.java:112)
at org.eclipse.swt.widgets.Label.<init>(Label.java:101)
at org.eclipse.ui.texteditor.StatusLineContributionItem.fill(StatusLineContributionItem.java:182)
at org.eclipse.jface.action.SubContributionItem.fill(SubContributionItem.java:59)
at org.eclipse.jface.action.StatusLineManager.update(StatusLineManager.java:327)
at org.eclipse.ui.internal.WorkbenchPage.updateActivations(WorkbenchPage.java:287)
at org.eclipse.ui.internal.WorkbenchPage.access$15(WorkbenchPage.java:265)
at org.eclipse.ui.internal.WorkbenchPage$E4PartListener.partActivated(WorkbenchPage.java:194)
at org.eclipse.e4.ui.internal.workbench.PartServiceImpl$2.run(PartServiceImpl.java:183)
at org.eclipse.e4.ui.internal.workbench.PartServiceImpl.firePartActivated(PartServiceImpl.java:181)
at org.eclipse.e4.ui.internal.workbench.PartServiceImpl.activate(PartServiceImpl.java:595)
at org.eclipse.e4.ui.internal.workbench.PartServiceImpl.activate(PartServiceImpl.java:539)
at org.eclipse.e4.ui.internal.workbench.swt.AbstractPartRenderer.activate(AbstractPartRenderer.java:104)
at org.eclipse.e4.ui.workbench.renderers.swt.ContributedPartRenderer$1.handleEvent(ContributedPartRenderer.java:59)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1057)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1081)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1066)
at org.eclipse.swt.widgets.Shell.setActiveControl(Shell.java:1453)
at org.eclipse.swt.widgets.Shell.WM_MOUSEACTIVATE(Shell.java:2334)
at org.eclipse.swt.widgets.Control.windowProc(Control.java:4655)
at org.eclipse.swt.widgets.Canvas.windowProc(Canvas.java:340)
at org.eclipse.swt.widgets.Decorations.windowProc(Decorations.java:1627)
at org.eclipse.swt.widgets.Shell.windowProc(Shell.java:2075)
at org.eclipse.swt.widgets.Display.windowProc(Display.java:4990)
at org.eclipse.swt.internal.win32.OS.DefWindowProcW(Native Method)
at org.eclipse.swt.internal.win32.OS.DefWindowProc(OS.java:2544)
at org.eclipse.swt.widgets.Scrollable.callWindowProc(Scrollable.java:80)
at org.eclipse.swt.widgets.Control.windowProc(Control.java:4706)
at org.eclipse.swt.internal.win32.OS.PeekMessageW(Native Method)
at org.eclipse.swt.internal.win32.OS.PeekMessage(OS.java:3141)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3754)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$9.run(PartRenderingEngine.java:1113)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:997)
at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:138)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:610)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:567)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:354)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:181)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:636)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:591)
at org.eclipse.equinox.launcher.Main.run(Main.java:1450)
at org.eclipse.equinox.launcher.Main.main(Main.java:1426)
Thanks and Regards,
Muralidhar Yaragalla.
http://yaragalla.blogspot.in
[Updated on: Fri, 27 September 2013 19:31] Report message to a moderator
Re: not sure whether we are moving forward or backward? [message #1121565 is a reply to message #1118773] |
Mon, 30 September 2013 19:14 |
Phil Culberson Messages: 1 Registered: September 2013 |
I was having the same issue and, after much thrashing about, I was able to get past the problem by disabling some programs. I'm not sure which of these two programs were causing the issue, but I disabled both and now Eclipse Kepler is running fine. The two programs are iRotate and DisplayFusion.
I've also seen a post over on Stack Overflow that claims HP Protect Tools may also cause this issue. Here is the text of the answer as I can't insert links yet:
Quote:I have no ideia how, but right after a uninstalled the HP Protect Tools service, the exact same problem stopped in my notebook... using eclipse kepler on Win7 Pro x64.
Hopefully one of these items is the cause of your issues.
Good luck.
[Updated on: Mon, 30 September 2013 20:33] Report message to a moderator
FUDForum. Page generated in 0.03777 seconds
