EObjectValidator.validate() is called multiple times for models that are based on several packages [message #1117290] |
Thu, 26 September 2013 09:26 |
Maarten Bezemer Messages: 117 Registered: February 2012 |
I am using models that are based on multiple ecore packages.
For each package I have multiple (combined) EVL validation rules registered.
The combined EVL rules start off with the default EObjectValidator.
Since I have multiple ecore packages, not all rules are combined since they are registered to their corresponding package. (Which is a good thing!)
I manually find the used packages, and invoke the validation rules of each of these packages.
This results in the EObjectValidator rules getting activated multiple times. This is a waste of time and this result in errors on circular contained objects (because EObjectValidator does not expect to be called multiple times with the same context).
EObjectValidator sets ROOT_OBJECT to detect these circular containment problems.
When CompositeEValidator#validate(EClass, EObject, DiagnosticChain, Map<Object, Object>) gets modifies to check for this context entry just before the EObjectValidator gets invoked, so it can be skipped, the problem is solved.
Is this an acceptable solution and should I open a bug report and provide such a patch? Or is this too much of a 'hack'?
Maarten
Re: EObjectValidator.validate() is called multiple times for models that are based on several packag [message #1117833 is a reply to message #1117290] |
Thu, 26 September 2013 21:24 |
Hi Maarten,
Please see comments below.
I'm not sure I understand what "manually" means in this context
"circular contained objects" sounds scary
I'm not sure I can fully appreciate the nature of the problem. A minimal example and a description of what's expected/observed in the bugzilla would help a lot - a patch would be fantastic
Dimitris
FUDForum. Page generated in 0.03322 seconds
