Home » Newcomers » Newcomers » Problems starting Eclipse after Java 7 install(Problems starting Eclipse after Java 7 install)
icon9.gif  Problems starting Eclipse after Java 7 install [message #1117277] Thu, 26 September 2013 09:12 Go to next message
Ian O\'Sullivan is currently offline Ian O\'SullivanFriend
When I start Eclipse I'm told I've no JVM. So I followed the instructions here: http://wiki.eclipse.org/Eclipse.ini.
I added
-vm
C:\Program Files (x86)\Java\jre7\bin\javaw.exe
just above the -vmargs entry.
Unfortunately this hasn't worked for me. It has just resulted in an 'exit code=13' problem. See the attached screenshot for error.
Please help. I miss Eclipse and don't like having to use Dreamweaver again.
TY
Ian.
Re: Problems starting Eclipse after Java 7 install [message #1117504 is a reply to message #1117277] Thu, 26 September 2013 14:12 Go to previous messageGo to next message
Russell Bateman is currently offline Russell BatemanFriend
On 9/26/2013 5:25 AM, Ian O'Sullivan wrote:
> Hi
> I added
> -vm
> TY
> Ian.
You're trying to launch 64-bit Eclipse on a 32-bit JRE.
Re: Problems starting Eclipse after Java 7 install [message #1117526 is a reply to message #1117504] Thu, 26 September 2013 14:36 Go to previous messageGo to next message
Thanks Russell.
So I should uninstall Eclipse and Install 32-bit version? Should that fix it?
Ian.
Re: Problems starting Eclipse after Java 7 install [message #1117532 is a reply to message #1117526] Thu, 26 September 2013 14:44 Go to previous messageGo to next message
On 9/26/2013 8:36 AM, Ian O'Sullivan wrote:
> Thanks Russell.
> fix it?
> Ian.
If your Windows platform is 64-bit, then keep Eclipse and go get a
64-bit JRE.
Re: Problems starting Eclipse after Java 7 install [message #1117540 is a reply to message #1117532] Thu, 26 September 2013 14:55 Go to previous messageGo to next message
Russell... TY for your help. Installed 64-bit it's working again.
Much appreciated.
Ian.
Re: Problems starting Eclipse after Java 7 install [message #1127336 is a reply to message #1117277] Sun, 06 October 2013 14:47 Go to previous message
Francesco Maspero is currently offline Francesco MasperoFriend
Hallo, I had the same problem, and following the instruction was able to fix.
But now I receive this error message. What is it? Is it a wrong Java release?
Francesco
Previous Topic:Test Driven Development Organization
Next Topic:Eclipse Not Displaying Install New Software
Current Time: Tue Apr 13 06:07:42 GMT 2021
Powered by FUDForum. Page generated in 0.03400 seconds
