Background Image in Master Page [message #1116275] |
Wed, 25 September 2013 07:20 |
Alejandro GG Messages: 5 Registered: September 2013 |
Hi!
I created a library (with name 'new_library') for the purpose of using the master page of this library as a master page for other reports.
In the master page of the library, in the header, i inserted a text element. In the footer, also i inserted a text element.
Finally, I have also established a background image for the master page.
To do this (background image), I have done the following:
Property Editor - Master Page -> Properties -> Advanced -> Simple Master Page -> Background:
Background attachment: scroll
Background color:
Background image: image.bmp
Background image type: URL
Background repeat: No Repeat
Background size height: Auto
Background size width: Auto
Horizontal Position : Center
Vertical Position : Center
Next, I created a report in which I will use this master page.
To do this, once created the report, I have gone to the tab 'Resource Explorer' and then 'Shared Resources->new_library->MasterPages', click on 'MasterPages' and select 'Add to report'.
At design time everything seems fine, putting the background image properly in the report, both tab 'Layout' and the tab 'Master Page', but when I go to the tab 'Preview', the background image is repeated three times: in the header, in the body and in the footer.
I found that if I do not put anything in the header of master page of the library, the background image does not appear in the header. It's the same with the footer.
Does anyone know how to make out the image only once in the body of report?
Re: Background Image in Master Page [message #1117487 is a reply to message #1116275] |
Thu, 26 September 2013 13:56 |
If you can attach a sample library and report that shows the issues, that I can run, that'd be great. Otherwise, just let me know your BIRT version and I'll follow your steps to set it up. Thanks.
Michael
Developer Evangelist, Silanis
FUDForum. Page generated in 0.03253 seconds
