[ATL] problems to reference remote rules [message #15992] |
Mon, 14 May 2007 19:40 |
Originally posted by: marciofsoliveira.gmail.com
I'm trying to associate n elements in diferent rules.
In order to do that, I'm using the thisModule.resolveTemp() as I have
seem in the ATL User Manual and other sample codes. However, I'm having
the folowing error message:
"ERROR: could not find operation getNamedTargetFromSource on Void
having supertypes: [OclAny]"
The folloing rules ilustrate what I'm tring to do:
rule ClassToBlock{
from
class : uml!Class
to
block: myMetamodel!Block(
name<-class.name
rule ModelToModel {
from
uml_model : uml!Model
to
system : myMetamodel!System (
name <-uml_model.name,
blocks<- thisModule.resolveTemp(uml!Class, 'subsystem')
simulink_model : myMetamodel!Model(
name<-uml_model.name,
system<-system
Using these rules I would like to make system to point for a
collection of blocks.
Thanks in advance
Marcio Oliveira
Re: [ATL] problems to reference remote rules [message #16010 is a reply to message #15992] |
Tue, 15 May 2007 06:11 |
Frédéric Jouault Messages: 572 Registered: July 2009 |
Thank you for prefixing the subject of your post with [ATL]. However,
this question would fit better in the eclipse.modeling.m2m newsgroup,
which I added in copy of my answer.
> rule ClassToBlock{
> from
> class : uml!Class
> to
> name<-class.name
> rule ModelToModel {
> from
> to
> system<-system
Why don't you write something like:
blocks <- uml_model.allClasses
(depending on your metamodel, you may need to define the recursive
"allClasses" attribute helper to retrieve all the classes directly and
indirectly contained in uml_model)
or (without needing a helper, but only working if there is a single
uml!Model in your source model):
blocks <- uml!Class.allInstancesFrom('IN')
where IN is the name of your source model.
Because there is only one element created for each class in rule
ClassToBlock, you do not need resolveTemp: ATL will automatically
resolve the classes into blocks for you ;-).
Frédéric Jouault
FUDForum. Page generated in 0.01935 seconds
