64 bit Problem [message #1111584] |
Wed, 18 September 2013 12:17 |
Heinz Christoph Dau-Schmidt Messages: 14 Registered: July 2013 |
I have installed Jubula 7.1.00055 64 bit (respectively Autagent) on my Linux (Ubuntu 64bit) Server. 32 Bit Librarys were succesfully installed too (apt-get install ia32-libs).
But if I want to start Autagent, the following error message appears:
root@jenkins:/usr/local/jubula_7.1.00055/server# ./autagent -v
Autagent-lin:
JVM terminated. Exit code=13
/usr/local/jubula_7.1.00055/server//../jre/bin/java
-server
-Xms128m
-Xmx1024m
-client
-XX:MaxPermSize=256m
-jar /usr/local/jubula_7.1.00055/server/plugins/org.eclipse.equinox.launcher_1.3 .0.v20120522-1813.jar
-os linux
-ws gtk
-arch x86
-showsplash
-launcher /usr/local/jubula_7.1.00055/server/autagent-lin
-name Autagent-lin
--launcher.library /usr/local/jubula_7.1.00055/server/plugins/org.eclipse.equino x.launcher.gtk.linux.x86_1.1.200.v20120913-144807/eclipse_1502.so
-startup /usr/local/jubula_7.1.00055/server/plugins/org.eclipse.equinox.launcher _1.3.0.v20120522-1813.jar
--launcher.overrideVmargs
-exitdata 38005
-v
-vm /usr/local/jubula_7.1.00055/server//../jre/bin/java
-vmargs
-server
-Xms128m
-Xmx1024m
-client
How can I solve this?
[Updated on: Wed, 18 September 2013 12:23] Report message to a moderator
Re: 64 bit Problem [message #1111590 is a reply to message #1111584] |
Wed, 18 September 2013 12:28 |
Can it be, that this problem occurs, because of different java versions?
JRE Version on my Server (java -version):
java version "1.7.0_25"
OpenJDK Runtime Environment (IcedTea 2.3.10) (7u25-2.3.10-1ubuntu0.12.04.2)
OpenJDK 64-Bit Server VM (build 23.7-b01, mixed mode)
JRE Version in jubula_7.1.00055/jre/bin:
java version "1.6.0_45"
Java(TM) SE Runtime Environment (build 1.6.0_45-b06)
Java HotSpot(TM) 64-Bit Server VM (build 20.45-b01, mixed mode)
##Edit##
Okay I solved this issue now. The 32bit version of Jubula works.
But now, if I start AUtAgent on Ubuntu via Putty (SSH Client) a new issue occurs:
java.awt.HeadlessException:
No X11 DISPLAY variable was set, but this program performed an operation which requires it.
I can't find any informations in Jubula Documentation about this.
Because of this, is it neccessary to use X11 Server to start AUTAgent?
Or can I use XframeBuffer (http://packages.ubuntu.com/de/lucid/xvfb) too?
Is somewhere here who has experience with it?
[Updated on: Wed, 18 September 2013 20:20] Report message to a moderator
FUDForum. Page generated in 0.02621 seconds
