Package with uri "ChartModel" not found [message #1110045] |
Mon, 16 September 2013 09:32 |
ASHISH KUMAR Messages: 6 Registered: July 2013 |
Hi All
I am facing an issue to generate the pdf report , normally pdf report is generated vary fine but when i integrate it with quartz then pdf is generated with tabular data only , chatrs is not coming in generated pdf report.
I got the following errors:-
Sep 16, 2013 2:02:00 PM org.eclipse.birt.report.engine.api.impl.ReportEngine
FINE: ReportEngine created. EngineConfig: EngineConfig: org.eclipse.birt.report.engine.api.EngineConfig.scriptObjects={};BIRT_HOME= ;logLevel=ALL;org.eclipse.birt.report.engine.api.EngineConfig.emitterConfigs={html=org.eclipse.birt.report.engine.api.HTMLEmitterConfig@a1a04e};org.eclipse.birt.report.engine.api.EngineConfig.statusHandler=org.eclipse.birt.report.engine.api.DefaultStatusHandler@1236655;logDest=C:/ASMPlatform/Reports/schedulerLog;
FINE: ReportEngine.openReportDesign: designName=C:/ASMPlatform\reports\Companies\default\sam\dd\dd_is\default\Completion Status\1.DD Status by Count.rptdesign
Sep 16, 2013 2:02:16 PM null deserialize
WARNING: Exception
org.eclipse.emf.ecore.resource.Resource$IOWrappedException: Package with uri 'http://www.birt.eclipse.org/ChartModel' not found. (file:///C:/personal/software/Jboss/jboss-5.1.0.GA/jboss-5.1.0.GA/bin/test.chart, 1, 367)
at org.eclipse.emf.ecore.xmi.impl.XMLLoadImpl.handleErrors(XMLLoadImpl.java:77)
at org.eclipse.emf.ecore.xmi.impl.XMLLoadImpl.load(XMLLoadImpl.java:185)
at org.eclipse.emf.ecore.xmi.impl.XMLResourceImpl.doLoad(XMLResourceImpl.java:253)
at org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(ResourceImpl.java:1518)
at org.eclipse.birt.chart.model.impl.SerializerImpl.fromXml(SerializerImpl.java:465)
at org.eclipse.birt.chart.reportitem.ChartReportItemImpl.deserialize(ChartReportItemImpl.java:295)
at org.eclipse.birt.report.model.extension.PeerExtensibilityProvider.initializeReportItem(PeerExtensibilityProvider.java:580)
at org.eclipse.birt.report.model.elements.ExtendedItem.initializeReportItem(ExtendedItem.java:307)
at org.eclipse.birt.report.model.parser.ExtendedItemState.end(ExtendedItemState.java:155)
at org.eclipse.birt.report.model.util.XMLParserHandler.endElement(XMLParserHandler.java:186)
at org.apache.xerces.parsers.AbstractSAXParser.endElement(Unknown Source)
at org.apache.xerces.impl.XMLDocumentFragmentScannerImpl.scanEndElement(Unknown Source)
at org.apache.xerces.impl.XMLDocumentFragmentScannerImpl$FragmentContentDispatcher.dispatch(Unknown Source)
at org.apache.xerces.impl.XMLDocumentFragmentScannerImpl.scanDocument(Unknown Source)
at org.apache.xerces.parsers.XML11Configuration.parse(Unknown Source)
at org.apache.xerces.parsers.XMLParser.parse(Unknown Source)
at org.apache.xerces.parsers.AbstractSAXParser.parse(Unknown Source)
at org.apache.xerces.jaxp.SAXParserImpl$JAXPSAXParser.parse(Unknown Source)
at org.apache.xerces.jaxp.SAXParserImpl.parse(Unknown Source)
at org.eclipse.birt.report.model.parser.ModuleReader.readModule(ModuleReader.java:98)
at org.eclipse.birt.report.model.parser.DesignReader.read(DesignReader.java:88)
at org.eclipse.birt.report.model.core.DesignSessionImpl.openDesign(DesignSessionImpl.java:309)
at org.eclipse.birt.report.model.api.SessionHandleImpl.openDesign(SessionHandleImpl.java:294)
at org.eclipse.birt.report.engine.parser.ReportParser.getDesignHandle(ReportParser.java:158)
at org.eclipse.birt.report.engine.api.impl.ReportEngineHelper.getReportDesignHandle(ReportEngineHelper.java:255)
at org.eclipse.birt.report.engine.api.impl.ReportEngineHelper.openReportDesign(ReportEngineHelper.java:274)
at org.eclipse.birt.report.engine.api.impl.ReportEngineHelper.openReportDesign(ReportEngineHelper.java:196)
at org.eclipse.birt.report.engine.api.impl.ReportEngineHelper.openReportDesign(ReportEngineHelper.java:130)
at org.eclipse.birt.report.engine.api.impl.ReportEngine.openReportDesign(ReportEngine.java:310)
at org.eclipse.birt.report.engine.api.ReportEngine.openReportDesign(ReportEngine.java:12org.quartz.simpl.SimpleThreadPool$WorkerThread.run(SimpleThreadPool.java:563)
Caused by: org.eclipse.emf.ecore.xmi.PackageNotFoundException: Package with uri 'http://www.birt.eclipse.org/ChartModel' not found. (file:///C:/personal/software/Jboss/jboss-5.1.0.GA/jboss-5.1.0.GA/bin/test.chart, 1, 367)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.getPackageForURI(XMLHandler.java:2599)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.getFactoryForPrefix(XMLHandler.java:2429)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.createObjectByType(XMLHandler.java:1306)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.createTopObject(XMLHandler.java:1475)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.processElement(XMLHandler.java:1026)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.startElement(XMLHandler.java:1008)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.startElement(XMLHandler.java:719)
at org.apache.xerces.parsers.AbstractSAXParser.startElement(Unknown Source)
at org.apache.xerces.impl.dtd.XMLDTDValidator.startElement(Unknown Source)
at org.apache.xerces.impl.XMLDocumentFragmentScannerImpl.scanStartElement(Unknown Source)
at org.apache.xerces.impl.XMLDocumentScannerImpl$ContentDispatcher.scanRootElementHook(Unknown Source)
at org.eclipse.emf.ecore.xmi.impl.XMLLoadImpl.load(XMLLoadImpl.java:175)
... 34 more
Sep 16, 2013 2:02:16 PM org.eclipse.birt.report.engine.api.impl.ReportEngine
FINE: ReportEngine.createRunAndRenderTask: reportRunnable=org.eclipse.birt.report.engine.api.impl.ReportRunnable@1de6f35
Sep 16, 2013 2:02:25 PM org.eclipse.birt.data.engine.api.DataEngineContext DataEngineContext
FINER: ENTRY 3 [object Object] null null org.eclipse.birt.report.engine.executor.ApplicationClassLoader@58e6a4
[Updated on: Mon, 16 September 2013 10:10] Report message to a moderator
FUDForum. Page generated in 0.02960 seconds
