Re: moving a tag - error "A path under version control is needed for this operation" [message #15838 is a reply to message #15818] |
Mon, 07 April 2008 14:07 |
Originally posted by: alexander.gurov.polarion.org
Hello Edoardo,
It looks like the issue relates to development version of SVN Kit 1.2.0. I
checked described situation additionally with SVN Kit 1.1.6 and JavaHL
1.5.0 and found no problem with these connectors. So, I reported the
problem to SVN Kit authors. As workaround in order to work with SVN 1.5.0
you can use native JavaHL 1.5.0 beta1-based connector.
Re: moving a tag - error "A path under version control is needed for this operation" [message #15907 is a reply to message #15889] |
Mon, 07 April 2008 16:04 |
Edoardo Comar wrote:
> I'll have to look into that then as the 1.14 kit is telling me I cannot
> synchronize my workspace any more!!!
Yes, because SVN 1.5 working copy format is not compatible with SVN 1.4
one.
You have only two options on how to avoid the problem:
1) Use Native JavaHL 1.5.0 or SVN Kit 1.2.0 connector
2) Downgrade working copy to SVN 1.4 format by:
- recheckouting projects
- applying special downgrade script (AFAIK it is placed somewhere on
tigris.org)
If you have SVN server of version 1.5, I think the best way is to use
native JavaHL 1.5.0 or SVN Kit 1.2.0 connectors.
P.S.
Because the issue related to SVN Kit 1.2.0 is already reported to SVN Kit
team, I hope it will not take too much time to be fixed.
FUDForum. Page generated in 0.02711 seconds
