ValueConverter class is not getting called during runtime [message #1109283] |
Sun, 15 September 2013 06:14 |
Ashwini Nayak Messages: 19 Registered: July 2013 |
I am new to xtext and facing several issues while working on it. I have explained the issue below:
sample.xtext
Variable:
"variable" name=QualifiedName ("[" array=[Array] "]")? "{"
("description" description=STRING)?
("indexStartBit" (indexStartBit=NumberLiteral )|("index" indexStartBit=Index))
Index returns NumberLiteral:
{NumberLiteral} (INT | Double | IntRange | DoubleRange)
Double returns ecore::EDouble:
(INT '.' INT)
IntRange:
(INT '-' INT)
DoubleRange:
(Double '-' Double)
NumberLiteral returns Expression:
{NumberLiteral} value=Number
Numberhidden():
HEX | ('-')? (INT | DECIMAL) ('.' (INT | DECIMAL))?;
sample.xcore
class Variable {
String name
refers Array array
String description
contains resolving Expression indexStartBit
class NumberLiteral extends Expression
String value
The requirement is: In my dsl editor, I should be allowed to enter either "indexStartBit" or "index". When I enter a value for "indexStartBit", the value will be directly stored in the "indexStartBit" field. But, when I enter a value for "index", the index value should be converted to "indexStartbit" and stored in the field, "indexStartBit"(since there is no field called "index" in my xcore).
I have written a ValueConverter class for the rule Index.
I will be converting the value of "index" to "indexStartBit" in my Valueconverter class.
ValueConverter class:
public class ValueConvertor extends AbstractDeclarativeValueConverterService {
@ValueConverter(rule = "Index")
public IValueConverter<Integer> IndexValues() {
return new IValueConverter<Integer>() {
public Integer toValue(final String string, final INode node) throws ValueConverterException {
//my code goes here
I have binded the Valueconverter class by writing the below code in my RuntimeModule class.
public Class<? extends IValueConverterService> bindIValueConverterService() {
return ValueConvertor.class;
But, my ValueConverter class does not get called during runtime. Can anybody tell me if I there is something wrong in my "Index" rule? What do I need to change in my grammar so that my ValueConverter class gets called when I type a value for "index" in my editor.
Thanks in advance
[Updated on: Sun, 15 September 2013 06:16] Report message to a moderator
FUDForum. Page generated in 0.02793 seconds
