Home » Eclipse Projects » GEF » why getHeight() returns top+bottom in class Insets?
why getHeight() returns top+bottom in class Insets? [message #167257] Sun, 06 February 2005 21:26 Go to next message
Originally posted by: jianminjin.msn.com
i can't understand this, i think it should be bottom-top,
what's meaning of height here?
Re: why getHeight() returns top+bottom in class Insets? [message #167274 is a reply to message #167257] Sun, 06 February 2005 23:42 Go to previous messageGo to next message
Insets are not a rectangle. Rather the space surrounding one. So, a figure
of size 50, 50 with a line border of 1 would mean the figure's insets are 1,
1, 1, 1 (for all 4 directions). And that means the figure's client area's
size is 48x48. The concept of Insets in draw2d is the same as in AWT. You
can look that up to see if it makes more sense to you (it might be better
documented that draw2d).
"jin" <jianminjin@msn.com> wrote in message
news:cu6jla$h7a$1@www.eclipse.org...
Re: why getHeight() returns top+bottom in class Insets? [message #167297 is a reply to message #167274] Mon, 07 February 2005 01:41 Go to previous message
i understand now , thanks for ur explaination :D
Previous Topic:Complex Command tip needed
Next Topic:Problem with Local / absolute coordinates
Current Time: Tue Jul 15 07:33:12 EDT 2025
Powered by FUDForum. Page generated in 0.48985 seconds
