Home » Modeling » M2T (model-to-text transformation) » [Acceleo] Run maven plugin as part of build
[Acceleo] Run maven plugin as part of build [message #1107446] Thu, 12 September 2013 12:07 Go to next message
Ralph Gerbig is currently offline Ralph GerbigFriend
I use the maven plugin of acceleo for compiling my transformation as part of a maven tycho build. Everything is fine as long as I start the build from the folder in which the POM of the Acceleo build is located. Now I want to run the compilation as part of a bigger build. I get the following error when starting maven from my parent pom:
[ERROR] Failed to execute goal org.eclipse.acceleo:maven:3.2.1:acceleo-compile(default-cli) on project parent: The parameters 'useBinaryResources', 'usePlatformResourcePath' for goal org.eclipse.acceleo:maven:3.2.1:acceleo-compile are missing or invalid -> [Help 1]
What can I do to get around this?
Ralph
Re: [Acceleo] Run maven plugin as part of build [message #1107462 is a reply to message #1107446] Thu, 12 September 2013 12:37 Go to previous message
I found the solution...
http://wiki.eclipse.org/Acceleo/Maven#Plugin_Management_.28parent_and_children_pom.xml.29
Ralph
Previous Topic:JET Editor
Next Topic:Debugging during code generation
Current Time: Thu Oct 21 02:03:18 GMT 2021
Powered by FUDForum. Page generated in 0.01682 seconds
