[p2] List IUs of installation plan [message #1106775] |
Wed, 11 September 2013 14:27 |
I'd like to do some optimization of a big p2 repository mirroring much
stuff from Eclipse.org. I'm pretty sure some of this stuff is useless,
so I'd like to clean it and keep only what's useful.
So I'm wondering whether there is a tool that takes as input one or
several p2 repo, a set of root IUs and then lists all the IU that will
be installed (so it would also list all dependencies).
I'm aware this is something we can do with p2 director on a very clean
Eclipse Platform, but that would download all the artifacts, which is
time-consuming and which doesn't improve the quality of the results.
Does anyone know/have something of this kind available?
Thanks in advance.
Mickael Istria
My job: http://www.jboss.org/tools
My blog: http://mickaelistria.wordpress.com
My Tweets: http://twitter.com/mickaelistria
Re: [p2] List IUs of installation plan [message #1108310 is a reply to message #1107552] |
Fri, 13 September 2013 17:14 |
On 09/12/2013 05:30 PM, Pascal Rapicault wrote:
> You last comment confuses me. It is true that running the slicer is
> equivalent to installing your software on top of a minimal p2/platform,
> except that then you don't have to gather the list of IUs manually and
> do some post processing afterward.
That's true. This requires to know and maintain the list of root IUs.
Or to use UI and the "Select all" button, but then the "host" product
wouldn't be that minimal...
> I assume that in the end you want a metadata repo that contains only the
> metadata necessary to install your root IUs right?
Yes, that's what I want.
> At this point it does not look like the mirror task allows to bypass the
> download but this should be pretty straightforward to add.
Ok. Should I go for a feature request?
Mickael Istria
FUDForum. Page generated in 0.02129 seconds
