Home » Modeling » GMF (Graphical Modeling Framework) » Diagram partitioning serialization oddities
Diagram partitioning serialization oddities [message #166713] |
Thu, 03 January 2008 13:38 |
Norbert Schöpke Messages: 63 Registered: July 2009 |
Member |
My diagram partitioning basically works alright, but I discovered a problem.
I create my diagrams from some DSL and the initial diagram contains only nodes that can be double-clicked to open
sub-diagrams. The serialized diagram XML code looks like this:
<notation:Diagram xmi:version="2.0" xmlns:xmi="http://www.omg.org/XMI"
xmlns:notation="http://www.eclipse.org/gmf/runtime/1.0.1/notation" xmlns:thetaml="http://www.thetae.com/thetaml"
xmi:id="_mFwX0LlAEdydmZOsfHfFWA" type="ThetaML" name="fm.thetagram" measurementUnit="Pixel">
<styles xmi:type="notation:DiagramStyle" xmi:id="_mFwX0blAEdydmZOsfHfFWA"/>
<element xmi:type="thetaml:ThetaML" href="fm.thetaml#/"/>
</notation:Diagram>
As can be seen, the nodes that represent the children of the root element "ThetaML" are not serialized. What could cause
that? The semantic children are - of course - present in the corresponding model XML (I use separate files for domain
model and diagram notation).
Now, if I open one of the nodes, a sub-diagram is opened in a new editor and added to the XML. That's fine, however, the
first editor (for the root diagram) now shows up to be dirty. Why is that? So I did a little research...
If I focus the root editor, it asks whether I want to load the changes made on the file system.
That shouldn't happen, as it completely confuses the user.
If I say yes, another problem shows up: If I now double-click the same node as before again, GMF doesn't switch to the
already open editor, but opens a completely new sub-diagram, which is - of course - a copy of the first sub-diagram.
The XML looks like this:
<xmi:XMI xmi:version="2.0" xmlns:xmi="http://www.omg.org/XMI"
xmlns:notation="http://www.eclipse.org/gmf/runtime/1.0.1/notation" xmlns:thetaml="http://www.thetae.com/thetaml">
<notation:Diagram xmi:id="_mFwX0LlAEdydmZOsfHfFWA" type="ThetaML" name="fm.thetagram" measurementUnit="Pixel">
</notation:Diagram>
<notation:Diagram xmi:id="_y8MewLlAEdydmZOsfHfFWA" type="ThetaML" measurementUnit="Pixel">
<styles xmi:type="notation:DiagramStyle" xmi:id="_y8MewblAEdydmZOsfHfFWA"/>
<element xmi:type="thetaml:ThetaModel" href="fm.thetaml#//@models.0"/>
</notation:Diagram>
</xmi:XMI>
The XML has changed, now that the second diagram is also serialized. So that explains why the editor is dirty. But
still, shouldn't GMF suppress that? If not, how could I suppress that manually?
Now, if I move any of the nodes in the root diagram by even just one pixel and then save it (before opening any
sub-diagram), the behavior changes and GMF does the correct thing. Meaning: the children nodes get serialized in the
diagram notation, double-clicking always opens the same sub-diagram without duplicating, and the root diagram editor
never gets dirty.
The XML for completeness:
<notation:Diagram xmi:id="_JEjqw7lGEdy45ZMZ1nBdRg" type="ThetaML" name="fm.thetagram" measurementUnit="Pixel">
<children xmi:type="notation:Node" xmi:id="_JJ2acLlGEdy45ZMZ1nBdRg" type="1001">
<children xmi:type="notation:Node" xmi:id="_JJ2adLlGEdy45ZMZ1nBdRg" type="4001"/>
<styles xmi:type="notation:ShapeStyle" xmi:id="_JJ2acblGEdy45ZMZ1nBdRg"/>
<styles xmi:type="notation:HintedDiagramLinkStyle" xmi:id="_JJ2acrlGEdy45ZMZ1nBdRg"
diagramLink="_TJZMwLlGEdy45ZMZ1nBdRg"/>
<layoutConstraint xmi:type="notation:Bounds" xmi:id="_JJ2ac7lGEdy45ZMZ1nBdRg" x="48" y="36"/>
</children>
<children xmi:type="notation:Node" xmi:id="_JJ2adblGEdy45ZMZ1nBdRg" type="1001">
<children xmi:type="notation:Node" xmi:id="_JJ2aeblGEdy45ZMZ1nBdRg" type="4001"/>
<styles xmi:type="notation:ShapeStyle" xmi:id="_JJ2adrlGEdy45ZMZ1nBdRg"/>
<styles xmi:type="notation:HintedDiagramLinkStyle" xmi:id="_JJ2ad7lGEdy45ZMZ1nBdRg"/>
<element xmi:type="thetaml:ThetaModel" href="fm.thetaml#//@models.1"/>
<layoutConstraint xmi:type="notation:Bounds" xmi:id="_JJ2aeLlGEdy45ZMZ1nBdRg" x="259" y="36"/>
</children>
more children nodes
<styles xmi:type="notation:DiagramStyle" xmi:id="_JEjqxLlGEdy45ZMZ1nBdRg"/>
</notation:Diagram>
<notation:Diagram xmi:id="_TJZMwLlGEdy45ZMZ1nBdRg" type="ThetaML" measurementUnit="Pixel">
<styles xmi:type="notation:DiagramStyle" xmi:id="_TJZMwblGEdy45ZMZ1nBdRg"/>
</notation:Diagram>
</xmi:XMI>
(This one has already one sub-diagram open, but before opening it looks practically the same.)
Could some GMF guru please shed some light onto this?
Many people use diagram partitioning in one form or another, so I wonder whether other people have seen this bugger before?
Thanks for your attention if you read this post til here ;)
Norbert Schoepke
Re: Diagram partitioning serialization oddities [message #166899 is a reply to message #166713] |
Fri, 04 January 2008 14:29 |
Axel Guckelsberger Messages: 354 Registered: July 2009 |
Hi Norbert,
I also have to cope with some of the problems you mentioned.
For example one has to enforce that the main model gets saved once
before a sub editor is opened.
This results from different editing domains, read this topic for more
information:
http://dev.eclipse.org/newslists/news.eclipse.modeling.gmf/m sg09047.html
You might have a look at this bug targeted for 2.1 which relates to
this: https://bugs.eclipse.org/bugs/show_bug.cgi?id=172480
If you want to try out my intermediate results for diagram partitioning
you may visit http://modulestudio.de/ and download the preview version.
Greetings,
Axel
Norbert Schöpke schrieb:
> Hi
> </notation:Diagram>
> </notation:Diagram>
> </notation:Diagram>
> </xmi:XMI>
> never gets dirty.
> </children>
> </children>
> more children nodes
> </notation:Diagram>
> </notation:Diagram>
> </xmi:XMI>
> Norbert Schoepke
Re: Diagram partitioning serialization oddities [message #167276 is a reply to message #166899] |
Tue, 08 January 2008 09:14 |
Originally posted by: trommas.yahoo.com
--------------070100030906010300050002
Axel Guckelsberger wrote:
> Hi Norbert,
Is there a way to "auto-save"? That would be great! I don't want my
users to have to click yes in the save dialog all the time...
I downloaded it and tried to run it, but it failed to start. I'm
attaching the log.
Best Regards,
Tomas Zijdemans
name="1199778943968.log"
Content-Disposition: inline;
filename="1199778943968.log"
!SESSION 2008-01-08 08:55:43.718 -----------------------------------------------
eclipse.buildId=unknown
java.version=1.5.0_12
Command-line arguments: -os win32 -ws win32 -arch x86
!ENTRY org.eclipse.osgi 4 0 2008-01-08 08:55:44.625
!MESSAGE Application error
!STACK 1
org.eclipse.core.runtime.CoreException: Plug-in de.guite.modulestudio.gmf.msmain was unable to load class de.guite.modulestudio.gmf.msmain.application.ModuleStudioApp lication.
at org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI .throwException(RegistryStrategyOSGI.java:180)
at org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI .createExecutableExtension(RegistryStrategyOSGI.java:164)
at org.eclipse.core.internal.registry.ExtensionRegistry.createE xecutableExtension(ExtensionRegistry.java:788)
at org.eclipse.core.internal.registry.ConfigurationElement.crea teExecutableExtension(ConfigurationElement.java:243)
at org.eclipse.core.internal.registry.ConfigurationElementHandl e.createExecutableExtension(ConfigurationElementHandle.java: 51)
at org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:165)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:106)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:76)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:363)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:176)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 508)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:447)
at org.eclipse.equinox.launcher.Main.run(Main.java:1173)
org.eclipse.core.runtime.CoreException[1]: java.lang.UnsupportedClassVersionError: Bad version number in .class file
at java.lang.ClassLoader.defineClass1(Native Method)
at java.lang.ClassLoader.defineClass(Unknown Source)
at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.def ineClass(DefaultClassLoader.java:161)
at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.defineC lass(ClasspathManager.java:501)
at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findCla ssImpl(ClasspathManager.java:471)
at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLoc alClassImpl(ClasspathManager.java:430)
at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLoc alClass(ClasspathManager.java:413)
at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.fin dLocalClass(DefaultClassLoader.java:189)
at org.eclipse.osgi.framework.internal.core.BundleLoader.findLo calClass(BundleLoader.java:340)
at org.eclipse.osgi.framework.internal.core.BundleLoader.findCl assInternal(BundleLoader.java:408)
at org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:369)
at org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:357)
at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loa dClass(DefaultClassLoader.java:83)
at org.eclipse.osgi.framework.internal.core.BundleLoader.loadCl ass(BundleLoader.java:289)
at org.eclipse.osgi.framework.internal.core.BundleHost.loadClas s(BundleHost.java:227)
at org.eclipse.osgi.framework.internal.core.AbstractBundle.load Class(AbstractBundle.java:1269)
at org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI .createExecutableExtension(RegistryStrategyOSGI.java:160)
--------------070100030906010300050002--
Current Time: Thu Apr 25 04:42:43 GMT 2024
Powered by FUDForum. Page generated in 0.03501 seconds
