Home » Eclipse Projects » GEF » MySelectionAction.getSelectedObjects() is always empty
MySelectionAction.getSelectedObjects() is always empty [message #166621] Wed, 02 February 2005 09:04 Go to next message
Originally posted by: sinleeh.nowhere.com
Dear All,
Please pardon this newbie question.
I was trying to display a context menu for a GEF editpart. Using
LogicEditor as a guide,
(1) I define an MySelectionAction that inherits from a SelectionAction,
(2) added it to the context menu MyContextMenuProvider (child of
ContextMenuProvider) in buildContextMenu()
When running my GEF plugin I can see the context menu displaying an entry
for MySelectionAction. However, when I try to query its
getSelectedObjects(), the list is always empty. I am sure I miss something
and will be grateful if someone can point it out to me.
Thanking you in advance and best regards,
Sinleeh
Re: MySelectionAction.getSelectedObjects() is always empty [message #166654 is a reply to message #166621] Wed, 02 February 2005 10:45 Go to previous messageGo to next message
Actions should not hook themselves to notifiers because it leads to memory
leaks. Our approach is for the editor to manage actions and listen to
selection, then call update() on the selection action. See
GraphicalEDitor#selectionChanged().
"Sinleeh" <sinleeh@nowhere.com> escreveu na mensagem
news:ctqmlr$es8$1@www.eclipse.org...
> Dear All,
> Sinleeh
Re: MySelectionAction.getSelectedObjects() is always empty [message #166662 is a reply to message #166654] Wed, 02 February 2005 12:11 Go to previous messageGo to next message
Dear Randy et al,
Thanks for the advice. I reworked the relevent part but still the same
problem exists. I include what I think is the relevent parts only. If
there is something else needed, then it is safe to assume that I missed
it. As you can see, the code is based on LogicEditor. When I run
MyPipelineEditor, I manage to get the context menu and see the menuitem
for my Action, i.e. "Parameters ..." but it is always grey-out as
MyParameterAction. calculateEnabled() will always return false since
either getSelectedObjects() or getSelection always return empty or null.
Any help appreciated.
Cinly
public class MyPipelineEditor extends GraphicalEditorWithPalette {
protected void configureGraphicalViewer() {
super.configureGraphicalViewer();
GraphicalViewer viewer = getGraphicalViewer();
ContextMenuProvider provider
= new MyContextMenuProvider(viewer, getActionRegistry());
viewer.setContextMenu(provider);
getSite().registerContextMenu("mymenu", provider, viewer);
protected void createActions() {
super.createActions();
ActionRegistry registry = getActionRegistry();
IAction action = new GFXParameterAction((IWorkbenchPart)this,
registry.registerAction(action);
getSelectionActions().add(action.getId());
public class MyParameterAction extends SelectionAction {
static public String ID = "GFX Parameter Action";
public MyParameterAction(IWorkbenchPart part) {
super(part);
setId(ID);
setText("Parameters ...");
/* (non-Javadoc)
* @see
org.eclipse.gef.ui.actions.WorkbenchPartAction#calculateEnab led()
protected boolean calculateEnabled() {
//EITHER USE THIS SECTION
Object selected = getSelection(); //always equals null
if(selected == null) return false;
//OR THIS SECTION
if(getSelectedObjects().isEmpty) return false; //always return false
public class GFXContextMenuProvider extends ContextMenuProvider {
private ActionRegistry actionRegistry;
public GFXContextMenuProvider(EditPartViewer viewer, ActionRegistry
registry) {
super(viewer);
setActionRegistry(registry);
public void buildContextMenu(IMenuManager menu) {
menu.add(new Separator("GFX_PARAMETER"));
menu.add(new Separator(IWorkbenchActionConstants.MB_ADDITIONS));
menu.appendToGroup("GFX_PARAMETER",
getActionRegistry().getAction(GFXParameterAction.ID));
public ActionRegistry getActionRegistry() {
return actionRegistry;
public void setActionRegistry(ActionRegistry actionRegistry) {
this.actionRegistry = actionRegistry;
>> Dear All,
>> Sinleeh
Oops.. error in posted source code [message #166670 is a reply to message #166662] Wed, 02 February 2005 12:21 Go to previous message
I found a few inconsistency in the code I submitted. Essentially I tried
to make it more userfriendly by removing replacing names to generic names
but obviously I failed this time.
Please note that
MyContextMenuProvider is the same as GFXContextMenuProvider
and
MyParameterAction is the same as GFXParameterAction
Sorry for the inconvience. Corrected code posted here:
IAction action = new MyParameterAction((IWorkbenchPart)this,
super(part);
setId(ID);
//OR THIS SECTION
false
public class MyContextMenuProvider extends ContextMenuProvider {
public MyContextMenuProvider(EditPartViewer viewer, ActionRegistry
registry) {
super(viewer);
getActionRegistry().getAction(MyParameterAction.ID));
Previous Topic:draw2d and text anti-aliasing
Next Topic:SnapToGuides.KEY_VERTICAL_GUIDE never set in >>request.getExtendedData()<<
Current Time: Sun Jul 20 16:24:58 EDT 2025
Powered by FUDForum. Page generated in 0.03721 seconds
