Re: Error when with classifier reference in EnumerationLiterals [message #1218691 is a reply to message #1105327] |
Fri, 29 November 2013 11:42  |
Denis Nikiforov Messages: 334 Registered: August 2013 |
I have exactly the same problem. RSA 7.5 sets classifier reference in an exported XMI-file.
Parser throws an exception:
Caused by: org.eclipse.emf.ecore.xmi.IllegalValueException: Value 'org.eclipse.uml2.uml.internal.impl.EnumerationImpl@323bfd7a (name: AnimalIdKindCodeType, visibility: <unset>) (isLeaf: false, isAbstract: false, isFinalSpecialization: false)' is not legal. (file:/C:/Work/workspace/OclToXPath/model2/SMDataModel.uml, 729, 78)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.setFeatureValue(XMLHandler.java:2671)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.handleForwardReferences(XMLHandler.java:1156)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.handleForwardReferences(XMLHandler.java:1037)
at org.eclipse.uml2.uml.internal.resource.UMLHandler.endElement(UMLHandler.java:47)
at com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser.endElement(AbstractSAXParser.java:606)
at com.sun.org.apache.xerces.internal.parsers.AbstractXMLDocumentParser.emptyElement(AbstractXMLDocumentParser.java:183)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImpl.scanStartElement(XMLDocumentFragmentScannerImpl.java:1303)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImpl$FragmentContentDriver.next(XMLDocumentFragmentScannerImpl.java:2717)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentScannerImpl.next(XMLDocumentScannerImpl.java:607)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImpl.scanDocument(XMLDocumentFragmentScannerImpl.java:489)
at com.sun.org.apache.xerces.internal.parsers.XML11Configuration.parse(XML11Configuration.java:835)
at com.sun.org.apache.xerces.internal.parsers.XML11Configuration.parse(XML11Configuration.java:764)
at com.sun.org.apache.xerces.internal.parsers.XMLParser.parse(XMLParser.java:123)
at com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser.parse(AbstractSAXParser.java:1210)
at com.sun.org.apache.xerces.internal.jaxp.SAXParserImpl$JAXPSAXParser.parse(SAXParserImpl.java:568)
at com.sun.org.apache.xerces.internal.jaxp.SAXParserImpl.parse(SAXParserImpl.java:302)
at org.eclipse.emf.ecore.xmi.impl.XMLLoadImpl.load(XMLLoadImpl.java:175)
at org.eclipse.emf.ecore.xmi.impl.XMLResourceImpl.doLoad(XMLResourceImpl.java:253)
at org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(ResourceImpl.java:1518)
at org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(ResourceImpl.java:1297)
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLoad(ResourceSetImpl.java:259)
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLoadHelper(ResourceSetImpl.java:274)
... 3 more
Caused by: java.lang.UnsupportedOperationException
at org.eclipse.emf.common.util.BasicEList$UnmodifiableEList.move(BasicEList.java:1009)
at org.eclipse.emf.ecore.xmi.impl.XMLHelperImpl.setValue(XMLHelperImpl.java:1189)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.setFeatureValue(XMLHandler.java:2666)
... 24 more
When I remove classifier attribute manually, everithing works.
I think it's a bug in Eclipse, because according to UML Specification classifier attribute is required.
[Updated on: Fri, 29 November 2013 11:47] Report message to a moderator
FUDForum. Page generated in 0.02180 seconds
