Home » Archived » BIRT » Date Format and eliminate string(Date Format)
Date Format and eliminate string [message #1102306] Thu, 05 September 2013 16:14 Go to next message
JP Redro is currently offline JP RedroFriend
Experts,
I am working on the report with XML file as Data Source, in that i have a tag as date. This has format as '2013-09-05' but i need this as '05-SEP-2013'.
I have tried with data type as Date and applied Format date in properties as dd-MMM-YY
then i am getting as '05-Sep-2013'.. But i required month in UPPER CASE. Please suggest me.
Also i want to eliminate the number in the string column..
Ex: WELCOME-123
i want to delete -123 and print only WELCOME
This string is dynamic....
Thanks.
JP
JP
Re: Date Format and eliminate string [message #1102770 is a reply to message #1102306] Fri, 06 September 2013 03:56 Go to previous messageGo to next message
Michael Williams is currently offline Michael WilliamsFriend
Take a look at this report. It was made in BIRT 4.3.
Michael
Developer Evangelist, Silanis
Re: Date Format and eliminate string [message #1106159 is a reply to message #1102770] Tue, 10 September 2013 19:40 Go to previous messageGo to next message
Williams,
Thanks It's works.
JP
Re: Date Format and eliminate string [message #1106183 is a reply to message #1106159] Tue, 10 September 2013 20:13 Go to previous message
Not a problem!
Michael
Previous Topic:schema name in DataSet
Next Topic:Error while opening a .rptdesign file in Eclipse Juno
Current Time: Wed Sep 27 11:57:59 GMT 2023
Powered by FUDForum. Page generated in 0.02190 seconds
