Home » Modeling » Graphiti » how can get all business object from diagram(how can get all business object from diagram)
how can get all business object from diagram [message #1101336] Wed, 04 September 2013 10:16 Go to next message
xiao yu zhou is currently offline xiao yu zhouFriend
Hi gays
Now I have a problem,I just want to know whether there are apis to get business object from diagram in graphiti.I look forward for your help.
Re: how can get all business object from diagram [message #1101362 is a reply to message #1101336] Wed, 04 September 2013 11:09 Go to previous messageGo to next message
PALANI SANKAR is currently offline PALANI SANKARFriend
Member
Hi Xiao
Try these methods getFeatureProvider().getBusinessObjectForPictogramElement(getDiagram());
getFeatureProvider().getAllBusinessObjectsForPictogramElement(getDiagram())
Hope this helps.
Palani
Palani
Re: how can get all business object from diagram [message #1102922 is a reply to message #1101362] Fri, 06 September 2013 07:48 Go to previous messageGo to next message
Hi,PALANI SANKAR
Thank you for your advice for these methods ,but these methods did not give me a help.I can only get an empty array. I do not know why. I also tried getPictogramLinks() method on diagram,this method can help me to get all links and then get all business objs,but by this I get more than what I need. I know get the objs by filtering, but I think there should be a method provided by Graphiti to get domain model objs in an elegant way.
[Updated on: Fri, 06 September 2013 07:51]
Report message to a moderator
Re: how can get all business object from diagram [message #1104592 is a reply to message #1102922] Sun, 08 September 2013 16:51 Go to previous messageGo to next message
Hallvard Traetteberg is currently offline Hallvard TraettebergFriend
> getFeatureProvider().getBusinessObjectForPictogramElement(getDiagram()) and
> getFeatureProvider().getAllBusinessObjectsForPictogramElement(getDiagram()),but
This code gives you the business object(s) directly related to the
diagram itself, which is a PictogramElement. Sometimes this is the root
object of your model, but not always. You must use a PictogramElement
further down the Shape containment hierarchy.
I do
Re: how can get all business object from diagram [message #1811331 is a reply to message #1104592] Sat, 31 August 2019 09:59 Go to previous message
deerein kelerin is currently offline deerein kelerinFriend
Besides showing the objects' state at a particular point in time, an object diagram can also be used to represent the occurrences of interactions between classes in runtime. The result looks a bit like a communication diagram. The figure below provides an example of such a class diagram and its corresponding object diagram:
Previous Topic:getPictogramElementForBusinessObject returns wrong business object
Next Topic:Extending the Graphiti Metamodel
Current Time: Mon Jan 18 23:16:09 GMT 2021
Powered by FUDForum. Page generated in 0.02600 seconds
