Re: How can I get the OPML file? [message #15693 is a reply to message #15599] |
Thu, 24 April 2008 06:39 |
Hi Henrik,
Given that the OPML file is sometimes generated from meta-data that is external to the component
(i.e. a POM file in a Maven repo or an IU in a p2), you cannot rely on that the OPML is present in
the component so the only file that exists is the one that the Buckminster meta-data manager is
caching internally. For several reasons, I'd like to view this meta-data cache as a black-box. One
reason is that we have had thoughts of moving it into some kind of SQL or OODB storage. Another is
that while the file is XML based today, there are ways to make a SAX ContentHandler produce
something that is a lot quicker and more compact then XML.
I think the best approach is to use a temp file unless there is some way to use a stream directly.
Thomas Hallgren
Henrik Lindberg wrote:
> I want to get the OPML of a resolution as a file. I understand that I
> can write it out to any file, but I think the OPML is already stored in
> a file somewhere. I need this file to be able to pass it on to a
> bookmark importer funcion.
> Is it possible to get this file? Or do I have to write it out to a tmp
> file before importing and then deleting the tmp file?
> Regards
> - henrik
FUDForum. Page generated in 0.03118 seconds
