Home » Eclipse Projects » BIRT » unable to display image in Excel output in BIRT 4.3.0(BIRT 4.3.0 image issue in excel)
unable to display image in Excel output in BIRT 4.3.0 [message #1100469] Tue, 03 September 2013 06:38 Go to next message
javid shaik is currently offline javid shaikFriend
Hello guru's,
I am using BIRT 4.3.0 , when i am running the report in Excel(Xls) the image in the report output is not getting displayed. even i have "uk.co.spudsoft.birt.emitters.excel_4.3.0.v201306091613" emitter installed .
can anyone guide me please........
Awaiting for your outputs....
Javid
Re: unable to display image in Excel output in BIRT 4.3.0 [message #1100957 is a reply to message #1100469] Tue, 03 September 2013 21:03 Go to previous messageGo to next message
Michael Williams is currently offline Michael WilliamsFriend
The spudsoft emitter should work for images. Is this for all images for you? Can you attach an example that I can run where this is not working for you? Thanks!
Michael
Developer Evangelist, Silanis
Re: unable to display image in Excel output in BIRT 4.3.0 [message #1103091 is a reply to message #1100957] Fri, 06 September 2013 11:19 Go to previous messageGo to next message
Hi Michael,
Thanks for response....
As i said "uk.co.spudsoft.birt.emitters.excel_4.3.0.v201306091613" is already installed
when i am running the report in XLS: image(present inheader) is not dispalying and Date& time(present in footer) is not displaying.
when i am running the report in XLSX: Image is displaying in header but with very large size and Date& time(present in footer) is not displaying.
when i am running the report in XLS_SPUDSOFT:getting following error "+ org.eclipse.birt.report.service.api.ReportServiceException: Error happened while running the report."
can u please guide me with ur valuable suggestions
Javid
Re: unable to display image in Excel output in BIRT 4.3.0 [message #1103364 is a reply to message #1103091] Fri, 06 September 2013 17:12 Go to previous message
Yes, the spudsoft emitter comes with BIRT 4.3, so it's definitely installed already. I see what you're talking about though. It appears to be saying it cannot find DigestUtils.jar which is a part of the apache codec jar, which is there. Please log a bug for this in the bugzilla and post the bug info in here for future reference. I'll see if I can find a way around it for now. I'll let you know if I do.
Michael
Previous Topic:Configure Oracle JDBC OCI Datasource
Next Topic:Dataset truncate string columns
Current Time: Tue Oct 19 16:15:21 GMT 2021
Powered by FUDForum. Page generated in 0.01933 seconds
