Re: Pass dataset value to BirtNavigationBar.js [message #1100956 is a reply to message #1100468] |
Tue, 03 September 2013 21:02 |
You could try something like this:
In your NavigationbarFragment.jsp, you could put <TD> <div id='totalRows' /> </TD> between the pages and nav buttons <TD>'s. In your table's dataSet, add a computed column called "totalRows" that uses the count aggregation to return the number of rows. Then, at the top of your report, put a HTML text box bound to your table dataSet with the contents:
<script>
temp = <VALUE-OF>row["totalRows"]</VALUE-OF>;
document.getElementById('totalRows').innerHTML = "Total: " + temp;
</script>
This will find the div you placed in the navigationbarfragment and change it to say your total number of rows. Hope this helps.
Michael
Developer Evangelist, Silanis
FUDForum. Page generated in 0.02569 seconds
