Home » Archived » Sapphire » How to programatically select a node from the outline?
How to programatically select a node from the outline? [message #1099231] Sun, 01 September 2013 06:40 Go to next message
Hello Again Smile
I have a button in the upper right corner of my XML Editor that compares the opened XML file with another one based on a specific set of criteria.
The action then displays a Dialog with the items that have problems or needs to be revised. These items are displayed in a ListViewer.
Now I want user to double click an item in the list, and the tool highlights or selects the appropriate Node for him. Is there a way to highlight or select a Node from the Outline on the left programatically?
Thnx
Re: How to programatically select a node from the outline? [message #1100829 is a reply to message #1099231] Tue, 03 September 2013 12:56 Go to previous messageGo to next message
In your action, you have access to the context Sapphire Part. From there...
MasterDetailsEditorPagePart page = part.nearest( MasterDetailsEditorPagePart.class );
page.outline().setSelectedNode( ... );
Re: How to programatically select a node from the outline? [message #1101207 is a reply to message #1100829] Wed, 04 September 2013 02:23 Go to previous messageGo to next message
This method needs a "MasterDetailsContentNode" object. How to get that from an "IModelElement" object?
UPDATE:
I found it Smile using:
page.outline().getRoot().findNodeByModelElement(element);
ANOTHER UPDATE:
Method "findNodeByModelElement" doesn't search the entire tree. It searches only among children nodes of the caller node.
[Updated on: Wed, 04 September 2013 03:02] by Moderator
Re: How to programatically select a node from the outline? [message #1101530 is a reply to message #1101207] Wed, 04 September 2013 11:23 Go to previous messageGo to next message
It sounds like you found the API that you needed. If you call findNodeByModelElement on the root node, you will search the entire tree.
Re: How to programatically select a node from the outline? [message #1102188 is a reply to message #1101530] Thu, 05 September 2013 09:36 Go to previous messageGo to next message
Konstantin Komissarchik wrote on Wed, 04 September 2013 11:23
Well .. in my case it didn't!
It only searched among the first level children!
Re: How to programatically select a node from the outline? [message #1102628 is a reply to message #1102188] Thu, 05 September 2013 20:14 Go to previous messageGo to next message
Are you certain? You may want to step through the invocation in your scenario. The method in question is definitely recursive...
Re: How to programatically select a node from the outline? [message #1105123 is a reply to message #1102628] Mon, 09 September 2013 07:53 Go to previous message
Sorry, my fault Smile You're correct
Previous Topic:SapphireEditor never dirty without SourceEditor
Next Topic:Enable/disable individual FormEditorPage (or page contents) based on model properties?
Current Time: Fri Mar 21 13:46:50 EDT 2025
Powered by FUDForum. Page generated in 0.03744 seconds
