Home » Modeling » EMF » [CDO] OCL query fails with an SQL statement already in cache
[CDO] OCL query fails with an SQL statement already in cache [message #1098838] |
Sat, 31 August 2013 19:37 |
Having got past the problem of my OCL query failing because an EClass
is not mapped (I rebased to latest git master today), now I get a new
kind of failure.
My more elaborate query today attempts to narrow the scope of matched
objects to those that are in some resource path prefix. For example,
NamedElement.allInstances()->select(e |
e.name = 'Foo' and
e.oclAsType(ecore::EObject).eResource().oclAsType(eresource::CDOResource).path.startsWith('/cdamus/')
(I have to cast a NamedElement to EObject because although NamedElement
is an indirect subtype of ecore::EModelElement, Ecore removed EObject
from the supertypes of EModelElement some releases ago)
The exception that I get in the log seems to show that my OCL query
bombed on an IllegalStateException indicating that an SQL prepared
statement is already in the cache. I don't know the DB layer at all ...
cW
-------- 8< --------
!ENTRY org.eclipse.net4j.db 4 0 2013-08-31 15:22:47.251
!MESSAGE SELECT CDO_CLASS FROM CDO_OBJECTS WHERE CDO_ID=? already in cache
!STACK 0
java.lang.IllegalStateException: SELECT CDO_CLASS FROM CDO_OBJECTS
WHERE CDO_ID=
? already in cache
at
org.eclipse.net4j.internal.db.DBConnection.releasePreparedStatement(DBConnec
tion.java:172)
at
org.eclipse.net4j.internal.db.DBPreparedStatement.close(DBPreparedStatement.
java:95)
at org.eclipse.net4j.db.DBUtil.close(DBUtil.java:425)
at
org.eclipse.emf.cdo.server.internal.db.mapping.horizontal.ObjectTypeTable.ge
tObjectType(ObjectTypeTable.java:99)
at
org.eclipse.emf.cdo.server.internal.db.mapping.horizontal.DelegatingObjectTy
peMapper.getObjectType(DelegatingObjectTypeMapper.java:60)
at
org.eclipse.emf.cdo.server.internal.db.mapping.horizontal.AbstractHorizontal
MappingStrategy.readObjectType(AbstractHorizontalMappingStrategy.java:82)
at
org.eclipse.emf.cdo.server.internal.db.mapping.horizontal.HorizontalMappingS
trategy.readObjectType(HorizontalMappingStrategy.java:194)
at
org.eclipse.emf.cdo.server.internal.db.DBStoreAccessor.readObjectType(DBStor
eAccessor.java:205)
at
org.eclipse.emf.cdo.server.internal.db.DBStoreAccessor.getObjectType(DBStore
Accessor.java:222)
at
org.eclipse.emf.cdo.server.internal.db.DBStoreAccessor.readRevisionByVersion
(DBStoreAccessor.java:270)
at
org.eclipse.emf.cdo.internal.server.Repository.loadRevisionByVersion(Reposit
ory.java:578)
at
org.eclipse.emf.cdo.internal.common.revision.CDORevisionManagerImpl.getRevis
ionByVersion(CDORevisionManagerImpl.java:252)
at
ionByVersion(CDORevisionManagerImpl.java:1)
at
org.eclipse.emf.cdo.server.internal.db.mapping.horizontal.HorizontalBranchin
gClassMapping.handleRevisions(HorizontalBranchingClassMapping.java:867)
at
org.eclipse.emf.cdo.server.internal.db.mapping.AbstractMappingStrategy.handl
eRevisions(AbstractMappingStrategy.java:220)
at
trategy.handleRevisions(HorizontalMappingStrategy.java:210)
at
org.eclipse.emf.cdo.server.internal.db.DBStoreAccessor.handleRevisions(DBSto
reAccessor.java:1084)
at
org.eclipse.emf.cdo.server.ocl.CDOExtentCreator.handleRevisions(CDOExtentCre
ator.java:173)
at
org.eclipse.emf.cdo.server.ocl.CDOExtentCreator.createExtent(CDOExtentCreato
r.java:160)
at
org.eclipse.emf.cdo.server.ocl.CDOExtentCreator$Lazy$1$1.handlePersistentSta
te(CDOExtentCreator.java:318)
at
org.eclipse.emf.cdo.server.ocl.CDOExtentCreator$Lazy$1$1.run(CDOExtentCreato
r.java:262)
Re: [CDO] OCL query fails with an SQL statement already in cache [message #1098845 is a reply to message #1098838] |
Sat, 31 August 2013 19:54 |
Actually, the SQL-statement-already-in-cache thing was a red herring.
The problem is that when OCL accesses the 'path' feature of a
CDOResource, eGet with the 'path' EAttribute returns null, whereas
invocation (in the debugger) of the CDOResourceNode::getPath() accessor
method returns the resource's correct path.
So, Ecore reflection to get CDOResourceNode::path doesn't work, but
CDOResourceNode::getPath() does.
cW
On 2013-08-31 19:37:21 +0000, Christian W. Damus said:
> kind of failure.
> e.name = 'Foo' and
> cW
> !STACK 0
> WHERE CDO_ID=
> ? already in cache
> at
> tion.java:172)
> at
> java:95)
> at
> at
> at
> at
> at
> eAccessor.java:205)
> at
> Accessor.java:222)
> at
> at
> ory.java:578)
> at
> at
> at
> at
> at
> at
> at
> ator.java:173)
> at
> r.java:160)
> at
> at
> r.java:262)
Re: [CDO] OCL query fails with an SQL statement already in cache [message #1098853 is a reply to message #1098845] |
Sat, 31 August 2013 20:09 |
The CDOResourceNode::path feature is transient and derived from folder
and name.
Adding the following to CDOResourceNodeImpl fixes the problem. Is
there a better way?
cW
public Object eGet(int featureID, boolean resolve, boolean coreType)
switch (featureID)
case EresourcePackage.CDO_RESOURCE_NODE__PATH:
return getPath();
default:
return super.eGet(featureID, resolve, coreType);
public void eSet(int featureID, Object newValue)
switch (featureID)
setPath((String)newValue);
break;
default:
super.eSet(featureID, newValue);
break;
> cW
>> Hi,
>> kind of failure.
>> e.name = 'Foo' and
>> cW
>> !STACK 0
>> WHERE CDO_ID=
>> ? already in cache
>> at
>> tion.java:172)
>> at
>> java:95)
>> at
>> at
>> at
>> at
>> at
>> eAccessor.java:205)
>> at
>> Accessor.java:222)
>> at
>> at
>> ory.java:578)
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> ator.java:173)
>> at
>> r.java:160)
>> at
>> at
>> r.java:262)
Re: [CDO] OCL query fails with an SQL statement already in cache [message #1099109 is a reply to message #1098853] |
Sun, 01 September 2013 06:04 |
Am 31.08.2013 22:09, schrieb Christian W. Damus:
> The CDOResourceNode::path feature is transient and derived from folder and name.
> Adding the following to CDOResourceNodeImpl fixes the problem. Is there a better way?
I don't think so. I wonder why the EMF generator didn't generate these eGet/eSet methods. I've added another pair for
CDOResource::uri.
416298: CDOResourceNodes do not support reflective access to derived path attribute
https://bugs.eclipse.org/bugs/show_bug.cgi?id=416298
https://git.eclipse.org/r/#/c/16022/
Cheers
/Eike
http://www.esc-net.de
> cW
> @Override
> switch (featureID)
> return getPath();
> default:
> @Override
> switch (featureID)
> break;
> default:
> break;
>> The problem is that when OCL accesses the 'path' feature of a CDOResource, eGet with the 'path' EAttribute returns
>> null, whereas invocation (in the debugger) of the CDOResourceNode::getPath() accessor method returns the resource's
>> correct path.
>> So, Ecore reflection to get CDOResourceNode::path doesn't work, but CDOResourceNode::getPath() does.
>> cW
>>> Hi,
>>> Having got past the problem of my OCL query failing because an EClass is not mapped (I rebased to latest git master
>>> today), now I get a new kind of failure.
>>> My more elaborate query today attempts to narrow the scope of matched objects to those that are in some resource
>>> e.name = 'Foo' and
>>> e.oclAsType(ecore::EObject).eResource().oclAsType(eresource::CDOResource).path.startsWith('/cdamus/') )
>>> (I have to cast a NamedElement to EObject because although NamedElement is an indirect subtype of
>>> ecore::EModelElement, Ecore removed EObject from the supertypes of EModelElement some releases ago)
>>> The exception that I get in the log seems to show that my OCL query bombed on an IllegalStateException indicating
>>> that an SQL prepared statement is already in the cache. I don't know the DB layer at all ...
>>> cW
>>> !STACK 0
>>> java.lang.IllegalStateException: SELECT CDO_CLASS FROM CDO_OBJECTS WHERE CDO_ID=
>>> ? already in cache
>>> at org.eclipse.net4j.internal.db.DBConnection.releasePreparedStatement(DBConnec
>>> tion.java:172)
>>> at org.eclipse.net4j.internal.db.DBPreparedStatement.close(DBPreparedStatement.
>>> java:95)
>>> at org.eclipse.emf.cdo.server.internal.db.mapping.horizontal.ObjectTypeTable.ge
>>> at org.eclipse.emf.cdo.server.internal.db.mapping.horizontal.DelegatingObjectTy
>>> at org.eclipse.emf.cdo.server.internal.db.mapping.horizontal.AbstractHorizontal
>>> at org.eclipse.emf.cdo.server.internal.db.mapping.horizontal.HorizontalMappingS
>>> at org.eclipse.emf.cdo.server.internal.db.DBStoreAccessor.readObjectType(DBStor
>>> eAccessor.java:205)
>>> at org.eclipse.emf.cdo.server.internal.db.DBStoreAccessor.getObjectType(DBStore
>>> Accessor.java:222)
>>> at org.eclipse.emf.cdo.server.internal.db.DBStoreAccessor.readRevisionByVersion
>>> at org.eclipse.emf.cdo.internal.server.Repository.loadRevisionByVersion(Reposit
>>> ory.java:578)
>>> at org.eclipse.emf.cdo.internal.common.revision.CDORevisionManagerImpl.getRevis
>>> at org.eclipse.emf.cdo.server.internal.db.mapping.horizontal.HorizontalBranchin
>>> at org.eclipse.emf.cdo.server.internal.db.mapping.AbstractMappingStrategy.handl
>>> at org.eclipse.emf.cdo.server.internal.db.DBStoreAccessor.handleRevisions(DBSto
>>> at org.eclipse.emf.cdo.server.ocl.CDOExtentCreator.handleRevisions(CDOExtentCre
>>> ator.java:173)
>>> at org.eclipse.emf.cdo.server.ocl.CDOExtentCreator.createExtent(CDOExtentCreato
>>> r.java:160)
>>> at org.eclipse.emf.cdo.server.ocl.CDOExtentCreator$Lazy$1$1.handlePersistentSta
>>> at org.eclipse.emf.cdo.server.ocl.CDOExtentCreator$Lazy$1$1.run(CDOExtentCreato
>>> r.java:262)
Cheers
/Eike
Re: [CDO] OCL query fails with an SQL statement already in cache [message #1438188 is a reply to message #1436877] |
Sun, 05 October 2014 17:23 |
Ed Willink Messages: 7655 Registered: July 2009 |
I can imagine two possible things may be contributing.
The domain of allInstances() is undefined. The LazyExtentMap for the
Ecore OCL in use by CDO takes a Resource-based view, but CDO may have a
different derivation. A warm CDO may have moved from one Resource to
another and perhaps the ExtentMap is stale. (The Pivot OCL takes a
ResourceSet-based view.)
Unreasonable messages that EClasses cannot be found are often due to
metamodel schizophrenia; you are using the EClass loaded in one model
while the tooling is using another. A warm CDO may have reloaded one
model leaving something stale. (The Pivot OCL's ProjectMap reuses
already loaded models rather than creating rivals.) If the failure
occurs on a cold CDO you are probably loading one model as http:/... (ie
a Java code generated mdel) and another as platform:/resource/...
If you are really determined you can create a third load for
platform:/plugin/... with even more variants if URI normalisation
malfunctions.
For all of the above, a log of Resource loading and unloading, and a log
of eContainer changes on EClasses named "Diagram" may provide some
insight; instrument eBasicSetContainer.
Ed Willink
On 03/10/2014 15:50, Laurent Le Moux wrote:
> Hi Christian and Eike,
> Sorry to bring this post on top of the list again...
> I'm facing a strange problem with OCL queries for a couple of months now.
> I'm using CDO 4.3 shipped with Eclipse Modeling Luna 4.4.0.
> I'm basically using the following three queries :
> applicationv2::Application.allInstances()->select(a:applicationv2::Application|not
> a.invokes->intersection(self.defines)->isEmpty())
> mm::pictograms::PictogramLink.allInstances()->select(pl:mm::pictograms::PictogramLink|pl.businessObjects->includes(self))
> mm::pictograms::Diagram.allInstances()->select(d:mm::pictograms::Diagram
> | d.children.link.businessObjects->includes(self))
> The first one is ok.
> The second and third ones are querying the Graphiti model and fail or
> not, depending on how they are executed.
> Starting from a "cold" CDO server (that is a non-empty repository that I
> just restarted), these queries fail when executed as first thing.
> Whereas they run fine when executed after that Graphiti diagrams stored
> in CDO have been loaded in my RCP application editor.
> I either get the same message a Christian on the server side with query
> n°2 :
> !ENTRY org.eclipse.net4j.db 4 0 2014-10-03 14:42:16.279
> !STACK 0
> Or the following one, on the client side with query n°3 :
> java.lang.RuntimeException: org.eclipse.net4j.util.WrappedException:
> Problem executing OCL query:
> Caused by: org.eclipse.ocl.SemanticException: Unknown type ([mm,
> pictograms, Diagram])
> at org.eclipse.ocl.util.OCLUtil.checkForErrors(OCLUtil.java:352)
> at org.eclipse.ocl.util.OCLUtil.checkForErrors(OCLUtil.java:322)
> at
> org.eclipse.ocl.internal.helper.HelperUtil.checkForErrors(HelperUtil.java:512)
> at
> org.eclipse.ocl.internal.helper.HelperUtil.parseQuery(HelperUtil.java:159)
> at
> org.eclipse.ocl.internal.helper.OCLHelperImpl.createQuery(OCLHelperImpl.java:170)
> at
> org.eclipse.emf.cdo.server.ocl.OCLQueryHandler.createQuery(OCLQueryHandler.java:230)
> Christian already had a look in another post as well as Ed Willink on
> the OCL side :
> http://www.eclipse.org/forums/index.php/t/760318/
> Ed asked me to open the following bug report but I could unfortunetaly
> not help him much to reproduce the problem :
> https://bugs.eclipse.org/bugs/show_bug.cgi?id=435807
> I hope one of you can help because I can not figure out what to do...
> Kind regards,
> Laurent
Re: [CDO] OCL query fails with an SQL statement already in cache [message #1444776 is a reply to message #1440551] |
Tue, 14 October 2014 14:37 |
Laurent Le Moux Messages: 184 Registered: September 2011 |
Hi again,
Println is widely documented. Whereas I found only the API and 3 basic examples on how to use BasicEObjectImpl :
http://download.eclipse.org/modeling/emf/emf/javadoc/2.5.0/org/eclipse/emf/ecore/impl/BasicEObjectImpl.html
http://www.programcreek.com/java-api-examples/index.php?api=org.eclipse.emf.ecore.impl.BasicEObjectImpl
From these examples and the protected constructor, my first guess was that objects like a CDOResource could be cast as BasicEObjectImpl.
But, eBasicSetContainer() seems to be based on a notification mechanism (thus something more elaborated than a println...).
By the way, the source code indicates that eBasicSetContainer(InternalEObject newContainer, int newContainerFeatureID) throws an UnsupportedOperationException...
https://eclipse.googlesource.com/emf/org.eclipse.emf/+/a1ba85bc37a6dfa3cc9d9ea2e06af978a3acc929/plugins/org.eclipse.emf.ecore/src/org/eclipse/emf/ecore/impl/BasicEObjectImpl.java
That's the reason why, I am (kindly) asking for a little bit more information than just a method name...
For now, as I'm not able to use BasicEObjectImpl, I tried to get more details about my problem.
The query fails on a cold server but is normally executed once a Graphiti diagram has been open in my application editor (i.e. has been loaded from CDO).
I found another topic with a similar problem. But it remained unanswered :
http://www.eclipse.org/forums/index.php/t/627850/
Basically, the idea seems to be that packages useful for OCL are not available in the CDO package registry.
Hereafter is a log of the package registry for a cold server :
Key : http://user/1.0, Package : user.impl.UserPackageImpl@244bb9 (name: user) (nsURI: http://user/1.0, nsPrefix: user)
Key : http://eclipse.org/graphiti/mm, Package : CDOPackageInfo[packageURI=http://eclipse.org/graphiti/mm, parentURI=null]
Key : http://eclipse.org/graphiti/mm/algorithms/styles, Package : CDOPackageInfo[packageURI=http://eclipse.org/graphiti/mm/algorithms/styles, parentURI=http://eclipse.org/graphiti/mm/algorithms]
Key : http://lemoux.fr/modeling/framework/commons/metadata/commit, Package : CDOPackageInfo[packageURI=http://lemoux.fr/modeling/framework/commons/metadata/commit, parentURI=null]
Key : http://service/2.0, Package : servicev2.impl.Servicev2PackageImpl@1ca6954 (name: servicev2) (nsURI: http://service/2.0, nsPrefix: servicev2)
Key : http://www.eclipse.org/emf/CDO/security/4.1.0, Package : org.eclipse.emf.cdo.security.impl.SecurityPackageImpl@127fa03 (name: security) (nsURI: http://www.eclipse.org/emf/CDO/security/4.1.0, nsPrefix: security)
Key : http://repositorystructure/2.0, Package : repositorystructurev2.impl.Repositorystructurev2PackageImpl@62b39f (name: repositorystructurev2) (nsURI: http://repositorystructure/2.0, nsPrefix: repositorystructurev2)
Key : http://eclipse.org/graphiti/mm/algorithms, Package : CDOPackageInfo[packageURI=http://eclipse.org/graphiti/mm/algorithms, parentURI=http://eclipse.org/graphiti/mm]
Key : http://www.eclipse.org/emf/CDO/Eresource/4.0.0, Package : org.eclipse.emf.cdo.eresource.impl.EresourcePackageImpl@145d424 (name: eresource) (nsURI: http://www.eclipse.org/emf/CDO/Eresource/4.0.0, nsPrefix: eresource)
Key : http://lemoux.fr/modeling/framework/commons/metadata/configuration, Package : metadata.configuration.impl.ConfigurationPackageImpl@b72ce1 (name: configuration) (nsURI: http://lemoux.fr/modeling/framework/commons/metadata/configuration, nsPrefix: co)
Key : http://www.eclipse.org/emf/2002/Ecore, Package : CDOPackageInfo[packageURI=http://www.eclipse.org/emf/2002/Ecore, parentURI=null]
Key : http://www.eclipse.org/emf/CDO/expressions/4.3.0, Package : CDOPackageInfo[packageURI=http://www.eclipse.org/emf/CDO/expressions/4.3.0, parentURI=null]
Key : http://application/2.0, Package : applicationv2.impl.Applicationv2PackageImpl@7e9bed (name: applicationv2) (nsURI: http://application/2.0, nsPrefix: applicationv2)
Key : http://www.eclipse.org/emf/CDO/Etypes/4.0.0, Package : CDOPackageInfo[packageURI=http://www.eclipse.org/emf/CDO/Etypes/4.0.0, parentURI=null]
Key : http://eclipse.org/graphiti/mm/pictograms, Package : CDOPackageInfo[packageURI=http://eclipse.org/graphiti/mm/pictograms, parentURI=http://eclipse.org/graphiti/mm]
And for one from which a diagram has been loaded and my OCL query succefully executed :
Key : http://eclipse.org/graphiti/mm/algorithms/styles, Package : org.eclipse.graphiti.mm.algorithms.styles.impl.StylesPackageImpl@1737e47 (name: styles) (nsURI: http://eclipse.org/graphiti/mm/algorithms/styles, nsPrefix: st)
Key : http://lemoux.fr/modeling/framework/commons/metadata/commit, Package : metadata.commit.impl.CommitPackageImpl@1a4071a (name: commit) (nsURI: http://lemoux.fr/modeling/framework/commons/metadata/commit, nsPrefix: cm)
Key : http://eclipse.org/graphiti/mm/algorithms, Package : org.eclipse.graphiti.mm.algorithms.impl.AlgorithmsPackageImpl@8d116e (name: algorithms) (nsURI: http://eclipse.org/graphiti/mm/algorithms, nsPrefix: al)
Key : http://eclipse.org/graphiti/mm/pictograms, Package : org.eclipse.graphiti.mm.pictograms.impl.PictogramsPackageImpl@1d62a85 (name: pictograms) (nsURI: http://eclipse.org/graphiti/mm/pictograms, nsPrefix: pi)
I tried to "force" package registration as follow, but it makes no change :
CDOPackageRegistry packageRegistry = transaction.getSession().getPackageRegistry();
Iterator<Entry<String, Object>> it = packageRegistry.entrySet().iterator();
while (it.hasNext()) {
Entry<String, Object> item = it.next();
if ((item.getValue() instanceof MmPackage) || (item.getValue() instanceof AlgorithmsPackage)
|| (item.getValue() instanceof PictogramsPackage))
it.remove();
packageRegistry.putEPackage(MmPackage.eINSTANCE);
packageRegistry.putEPackage(AlgorithmsPackage.eINSTANCE);
packageRegistry.putEPackage(PictogramsPackage.eINSTANCE);
// Look for all diagrams where the element appears
String diagramsQuery = "mm::pictograms::Diagram.allInstances()->select(d:mm::pictograms::Diagram | "
+ "d.children.link.businessObjects->includes(self))";
CDOQuery cqDiagrams = transaction.createQuery("ocl", diagramsQuery, element.cdoID(), true);
final List<Diagram> diagrams = cqDiagrams.getResult(Diagram.class);
The OCL query is still failing on a cold server..
Hope someone can help...
Laurent
Current Time: Fri Apr 19 06:25:20 GMT 2024
Powered by FUDForum. Page generated in 0.02921 seconds
